Best bed divider?
Discussion in '3rd Gen Tundras (2014-2021)' started by mbcross, Oct 22, 2017.
  1. Oct 22, 2017 at 4:54 PM
    mbcross
    mbcross [OP] New Member
    2017 CrewMax
    What are you guys using to keep stuff from sliding all over your bed?
  2. Oct 22, 2017 at 7:15 PM
    tdosthp
    tdosthp New Member
    2014 Tundra
    I have the Bak Box 2 and the Undercover Swing cases. Also purchased the cargo net (bag) for a Tacoma and us it toward the tailgate. The Tacoma version fits between the Undercover Swing cases perfectly.
    Sunnier likes this.
  3. Oct 22, 2017 at 7:18 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I just use one of those load bars. It works and gets out of the Way when needed.
  4. Oct 22, 2017 at 7:35 PM
    mbcross
    2017 CrewMax
    Thought about the load bar..where's a good place to find one?
  5. Oct 22, 2017 at 8:41 PM
    BOBONTUESDAY
    2016 Limited Trd
    I picked mine up at home depot just happened to see it for half off, best thing I've bought for the bed of the truck. Make sure you buy the one that's like a ratchet strap and not the ones that are like shower line holders. This is the exact one I've got. It's taken a beating but still works great.
    https://www.amazon.com/gp/aw/d/B000...s=load+bar&dpPl=1&dpID=41W6VM-qcfL&ref=plSrch
    showtime240 likes this.
  6. Oct 23, 2017 at 8:26 AM
    mbcross
    2017 CrewMax
    Thank you..gonna check it out!
  7. Oct 23, 2017 at 8:38 AM
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    I just cut a 2x10 board to fit. It's a good temporary / permanent fix.
    Quebec likes this.
  8. Oct 23, 2017 at 9:26 AM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    I got mine on Amazon and it works great!
    +1
  9. Oct 23, 2017 at 10:09 AM
    NewImprovedRon
    NewImprovedRon Hey! Get off my grass!
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    I use the OEM Toyota bed divider and it works great. It utilizes the OEM deck rail system.
    Big J likes this.
  10. Oct 23, 2017 at 10:25 AM
    Johnathand
    Johnathand New Member
    Johnathan
    16 Platinum
    OEM bed divider . Its great overall, has rails tracks on top for a bike fork mount or anything else. Its a versatile option. But overpriced.
    mbahr likes this.
  11. Oct 23, 2017 at 10:26 AM
    mbcross
    2017 CrewMax
    I really like that also, but since I put my bakflip cover on my bed, I had to lower my track system.
    NewImprovedRon likes this.
  12. Oct 23, 2017 at 11:14 AM
    NewImprovedRon
    Ron
    Bentonville, AR
    A load lock bar works pretty well especially if you don't have a plastic bed liner, which can be slippery for the load lock rubber feet.
