Best Battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jalzate44, Jan 14, 2022.
  1. May 16, 2022 at 7:45 PM
    #121
    AZTundra
    Paul
    Phoenix, AZ
    No issues whatsoever.
    HulkSmurf14 and OhEmmBee[QUOTED] like this.
  2. May 17, 2022 at 3:08 AM
    #122
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Anyone here that could source the hkb diode fuse from Australia without going through them? Seems like they're not taking any orders until the end of the year cause of COVID or some sort.
  3. May 17, 2022 at 3:34 AM
    #123
    GNTundra
    Gino
    2013 White
    Odysseys are my favorite. Over the years Ive run several brands. Used to run 6 in my 18 wheeler. From Montana to Wyoming down to Arizona and California. They took a licking.
    Y0TA PR0 and reywcms like this.
  4. May 17, 2022 at 4:43 AM
    #124
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    Update: After 2 months changing to the GM diode, have no issues so far. I monitor the truck when it sit in the driveway voltage reads at 12.8, whenever I start the truck the voltage went up to 14.5 then drops to 13.8-14.2 after I drive the truck around.
    RitcheyRch, HulkSmurf14 and OhEmmBee like this.
  5. May 20, 2022 at 7:46 AM
    #125
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I was nervous to install the diode and did some researching. Decided to buy the optima 400 charger. Mine is a daily driver and I don’t have a ton of electrical components to worry about but occasionally will need to use the outlets while camping and such. So I will just use the optima charger overnight while it sits on days where I know I will be using it. Might increase the lifespan, might not.
    FYI - for anyone interested, advance auto parts excludes any coupons and such from the purchase of this charger. But if you order from autozone you get 20% off anything over $100 so this cost just over $100 for me shipped. Use code MAYSAVINGS
    https://www.autozone.com/test-scan-...ormance-maintainer-battery-charger/543782_0_0
  6. May 20, 2022 at 8:50 AM
    #126
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    I had one of those on my first tacoma for about 4 years, then when I traded in for my second tacoma I swapped it out and ran it on my second tacoma another year. I should have swapped it out and ran it on my Tundra as well.
    jachal likes this.
  7. May 20, 2022 at 9:09 AM
    #127
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    If it brings the cells to saturation without zealously overcharging then you will definitely get more runtime as opposed to never saturating the cells.
    shawn474[QUOTED] and texasrho83 like this.
  8. May 20, 2022 at 6:14 PM
    #128
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I looked at the Odyssey but decided it was too pricey. Ended up with a Diehard 24F AGM for under $200. Works great. Bought the diode and fuse holders but haven’t used them. Also get one of Coupe’s adjustable battery holders
    HulkSmurf14 likes this.
  9. May 20, 2022 at 7:11 PM
    #129
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    If it's an AGM, throw the diode in. If not, there's no need.
  10. Jun 14, 2022 at 7:57 AM
    #130
    dkrou
    dkrou New Member
    dan
    2019 tundra
    That is the only one I would use personally...have had mine two years with no issue.
  11. Jun 23, 2022 at 11:13 PM
    #131
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    I had a trickle charger for my AGM X2 but after having to plug it in all the time I ended up getting the HKB. Had it in since March. Got around 14.5 to 14.6 at start up. I took it out a couple of weeks ago because I went to Toyota to check my AC. Didn't want to void the warranty. The fuse HKB ended up in a bag with a cup of liquid (wasn't me). Spilled all over the fuse. Is this fuse salvageable or do I get a new one?, getting around 14.2 st startup now.
  12. Jun 24, 2022 at 5:28 AM
    #132
    HulkSmurf14
    2014 Tundra Limited
    Fuse should be good with some cleaning...just make sure it's dry before you throw it back in...HKB does a good job at making these last with the epoxy they use. Meant to withstand heat/cold and moisture...
    Saltyhero13 and 2point5seconds like this.
  13. Jun 24, 2022 at 5:49 AM
    #133
    2point5seconds
    Sensei
    Nor Cal
    That's what I was hoping. I put it back in last night so I'll see how it goes today. Hoping to see 14.4-14.7. I may need to test the alternator voltage to see.
    HulkSmurf14[QUOTED] likes this.
  14. Jun 24, 2022 at 8:27 AM
    #134
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    Link to that USB charger that you replaced this with?
    HulkSmurf14 and Moe2o4[QUOTED] like this.
  15. Jun 24, 2022 at 8:40 AM
    #135
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
  16. Jun 25, 2022 at 1:02 PM
    #136
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    Bought my truck new in April 2021. Decided to test my battery this morning with my tester and it registered @ 451 CCA 32% life left.
  17. Jun 25, 2022 at 4:33 PM
    #137
    HulkSmurf14
    2014 Tundra Limited
    Haha nice one Toyota! AGM time!
    Giskk and Saltyhero13 like this.
  18. Jun 25, 2022 at 8:47 PM
    #138
    2point5seconds
    Sensei
    Nor Cal
    You were correct. Cleaned it up with some alcohol wipes and let it dry. Next day put it back in and got 14.7 at start up. So, just to let everyone know, if you get that fuse wet, it's still salvageable. Been driving around for a few days and still seems to be working. Was sweating have to maybe buy another one at the price. LOL
  19. Jun 29, 2022 at 9:49 AM
    #139
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    When voltage is ~14.5v then it’s in a charging stage.
    When voltage is ~14v then it’s in float stage, meaning the battery is fully charged and it’s just topping it off.
  20. Jun 29, 2022 at 6:58 PM
    #140
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Is there a down side of putting the diode in when you're not running an AGM battery? I have radio gear that runs 24/7 and the extra voltage would make sure the battery doesn't run down as quickly when the truck isn't driven daily.
  21. Jun 29, 2022 at 8:21 PM
    #141
    Cruzer
    Cruz
    Sunnyvale, CA
    Yes. You would be overcharging and risk damaging the battery.
    Randy Morton[QUOTED] likes this.
  22. Jul 2, 2022 at 10:26 AM
    #142
    TXBrit
    TXBrit New Member
    Weatherford TX
    2019 MGM Platinum
    Made by Exide I believe, best part is there is always a Walmart close by to warranty the battery wherever you are.
  23. Aug 4, 2022 at 1:29 PM
    #143
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @HulkSmurf14 @AZTundra @Moe2o4
    My fuse box looks different than those that have been posted. My tundra is a 2015 Pro. Is there a way to be sure that I have the diode orientation correct?847EAB96-8262-4DCA-84E2-B63D4594CF32.jpg
    NewImprovedRon and AZTundra like this.
  24. Aug 4, 2022 at 1:44 PM
    #144
    AZTundra
    Paul
    Phoenix, AZ
    If you install the diode backwards you'll get a battery indicator light on your dashboard. If you do just flip it around and reinstall in the other direction.
  25. Aug 6, 2022 at 8:50 AM
    #145
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’ve got some extra diodes if you are interested. PM me
    reywcms, NewImprovedRon and AZTundra like this.
  26. Mar 14, 2023 at 7:19 PM
    #146
    Dawoofles
    Dawoofles New Member
    Cheyenne, WY
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Dremel nail grinder works perfect on trimming the GM diode. Cuts through like butter.
    gosolo likes this.
  27. Nov 25, 2024 at 6:06 PM
    #147
    camron1039
    camron1039 New Member
    Camron
    2021 Tundra Platinum
    Reviving an old one here. I’m in a 2021 with the original battery, looking to replace soon and was thinking of going with the AGM style battery.
    We typically just drive the truck on Sundays and anytime I need a truck so it sits on a trickle charger 24/7. Based on that can I get by without the diode?
    Thanks!
  28. Nov 25, 2024 at 6:19 PM
    #148
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep.
    camron1039[QUOTED] likes this.
  29. Nov 25, 2024 at 6:28 PM
    #149
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    This time I went with a Duracell AGM from batteries plus, been very happy with it. It does have a lower float voltage than I remember from the one I got a couple years ago too. No diode this time around.
  30. Nov 26, 2024 at 2:48 AM
    #150
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    How long have you had it? And what is the float voltage on this battery? I'm assuming it's the 27F?
