Best Battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jalzate44, Jan 14, 2022.
  1. Apr 6, 2022 at 8:34 AM
    #91
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    A positive side effect of having the diode: faster phone charging
    HulkSmurf14 and Moe2o4 like this.
  2. Apr 6, 2022 at 8:36 AM
    #92
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Sweet well just ordered that 4 pack off Amazon, But going to check out the voltage when I go out in a little bit to see what it sits at running! So hopefully they outa come in a few days!
  3. Apr 6, 2022 at 8:50 AM
    #93
    Warreng
    Warreng New Member
    Wish I had saw this post a few months ago, That is a fair price. The northstar or whatever they are are stupid expensive, no kind of battery is worth $400 CAD, dont care how warm and fuzzy it makes you feel inside.
  4. Apr 6, 2022 at 9:45 AM
    #94
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I got the GM diode for under $2 at O’Reilly
    Calpoly93 and HulkSmurf14 like this.
  5. Apr 6, 2022 at 10:00 AM
    #95
    skip1980
    skip1980 New Member
    Columbia, Missouri
    Does anybody know if the diode with AGM is a Toyota thing or just Tundra. I had a AGM in my wifes 4runner for a few years and never had any issues.
  6. Apr 6, 2022 at 12:07 PM
    #96
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    The short answer is it's a Toyota thing.
    The less short but light on details answer is, it depends on how you use an AGM. AGM batteries will do fine with a stock Toyota voltage as long as they are only asked to float charge or keep topped up a generally full battery. Float charge is fine for most AGM batteries around 13.5- 13.8 volts - so if you drive your 4Runner around regularly, don't have other major accessories that drain the battery down, the battery will be fine.
    However, if you regularly discharge the battery like running a fridge or even an always on dash cam with a voltage sensor, AGMs work best with a cycle charge that is at a higher voltage - 14.4-14.8 depending on the manufacturer. Most (a generalization of recent years) Toyota alternators are controlled to max out at 13.8-14 volts which is ideal for a non-AGM.
    Over time, an AGM that is not charged at the correct voltage will have a reduced lifespan and has an increased potential of internal failure.
    BTBAKER, g6t9ed, OhEmmBee and 5 others like this.
  7. Apr 7, 2022 at 4:03 AM
    #97
    Moe2o4
    Moe2o4 New Member
    Corey
    Mine is averaging between 13.4-14v while running. So I'm assuming it should be more than that. I had the same battery in my Tacoma and i believe it was defiantly charging around 14-8-15v I believe.
  8. Apr 7, 2022 at 4:34 AM
    #98
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Mine does between 14.2-14.7
    HulkSmurf14 and Moe2o4[QUOTED] like this.
  9. Apr 7, 2022 at 4:50 AM
    #99
    SHUZAAM
    SHUZAAM www.anointed-automotive.com
    Aaron
    2005 Toyota Tundra SR5 AC 4x4
    it may seem cheap and not worth it, but I’ve seen and have had much luck personally with Everstart batteries from Wal-Mart.
    I know..I know. Seems stupid, even like I’m joking.
    I wish I was
  10. Apr 7, 2022 at 5:02 AM
    #100
    Moe2o4
    Moe2o4 New Member
    Corey
  11. Apr 17, 2022 at 3:58 PM
    #101
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Does this affect lithium battery as well? I've been debating going with antigravity lithium battery but I can't get an answer if our alternator would be ok to charge it.
  12. Apr 18, 2022 at 5:32 AM
    #102
    Moe2o4
    Moe2o4 New Member
    Corey
    So I got that fuse in last Saturday and put it in and been watching my voltage all last week and its ranging from 14-14.75. I've seen it go up to 14.75 is about the max its been. But its kind of been up and down all over the place. I'm assuming that's normal?
  13. Apr 18, 2022 at 6:00 AM
    #103
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah fluctuation is ok. If you're too concerned put a monitor to your battery posts and see what you're getting there.
    Moe2o4[QUOTED] likes this.
  14. Apr 18, 2022 at 6:10 AM
    #104
    Moe2o4
    Moe2o4 New Member
    Corey
    Ya I figured the fluctuation is ok. Not too concerned about it and I'm sure it's fine. Was just poking around and was considering picking up one of these to monitor it every once and a while.
    https://www.amazon.com/dp/B07WCW49Y...d_r=81394e33-f439-4fa6-ae63-7e26da80c225&th=1
  15. Apr 18, 2022 at 6:14 AM
    #105
    mountainpete
    No, lithium charge differently. On paper, an Antigravity should be fine with the stock charging as they have a management system built in but I have no personal experience.
    Lithium batteries are very rare on Tundras as starting batteries so it’s no surprise you can’t get a clear answer. Cost benefit just isn’t there as weight savings isn’t a consideration for a Tundra and most lithium starter batteries aren’t designed to discharge with accessories and be a starter. Plus the whole collisions and fire thing - it would need a box of some sort.
  16. Apr 18, 2022 at 6:25 AM
    #106
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    These have been in my wish list:
    MNJ Motor Car Battery Terminal Connectors with Voltmeter - 0/4/8 AWG Positive Negative Battery Post Clamp and Shims for Car Auto Caravan Marine Boat Motorhome (Pair) https://www.amazon.com/dp/B07VR367SP
  17. Apr 18, 2022 at 6:28 AM
    #107
    Moe2o4
    Moe2o4 New Member
    Corey
    Those are pretty awesome! I actually just put in a Rago Fabrication mount in the center of my dash last week and took their charger that came with it out and fitted it with a USB fast charger with a voltage meter in the center and it fast charges and its pretty slick!!!
  18. Apr 18, 2022 at 6:45 AM
    #108
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ooh looks good man. If you really wanna be sure tho I think meters at the posts are optimal.
  19. Apr 18, 2022 at 6:47 AM
    #109
    Moe2o4
    Moe2o4 New Member
    Corey
    Ya I totally agree with ya there, that one on the Rago mount matches my ultra gauge with the exact same numbers as well.
  20. Apr 18, 2022 at 6:50 AM
    #110
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Have you noticed that your phone charges faster?
  21. Apr 18, 2022 at 6:53 AM
    #111
    Moe2o4
    Moe2o4 New Member
    Corey
    It's pretty much the same, I used to use a fast charger that plugged into my cigarette lighter down below my climate controls. I may have lost a few mins on charge time but not that much. I never used a regular 2.1 usb to charge my phone.
  22. Apr 18, 2022 at 7:06 AM
    #112
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Man I've noticed a difference but only on long drives.
  23. Apr 18, 2022 at 7:15 AM
    #113
    Moe2o4
    Moe2o4 New Member
    Corey
    When my S22 is low lets say about 20% and I plug it in, it usually says about 1 hour and 18 minutes to full charge. And that's a 5000maH battery. I'll have to plug it into the factory 2.1V plug on the lower dash to see how much of a difference there is now.
  24. Apr 18, 2022 at 7:19 AM
    #114
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have an S20 Ultra and I love the quick charge capability. Android FTW
  25. Apr 18, 2022 at 7:43 AM
    #115
    Moe2o4
    Moe2o4 New Member
    Corey
    I just upgraded from my s20 ultra to a s22 ultra! Had it for 2 years and and it was time for a upgrade!
  26. Apr 18, 2022 at 7:48 AM
    #116
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I just upgraded from a Note 10+ lol
  27. Apr 18, 2022 at 7:49 AM
    #117
    Moe2o4
    Moe2o4 New Member
    Corey
    Damn LOL, what a dinosaur!!!!
  28. Apr 18, 2022 at 7:50 AM
    #118
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The specs on it were better than all of the mid level newer phones.
  29. Apr 18, 2022 at 7:51 AM
    #119
    Moe2o4
    Moe2o4 New Member
    Corey
    Totally agree, I had one and it did not disappoint!!!
  30. May 16, 2022 at 7:17 PM
    #120
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Mind if I ask how your electrical is after swapping the fuse to the GM Diode?
