Best Battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jalzate44, Jan 14, 2022.
  1. Jan 14, 2022 at 4:16 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  2. Jan 14, 2022 at 4:46 PM
    TTund16
    TTund16 New Member
    is the diode attached to or inside the alternator?
    Seems like Tundra stays right around 14V.
  3. Jan 14, 2022 at 5:34 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    I can’t remember which one I got, will have to sneak out in 20-30 min and verify….
    OEM battery went tits up after 5 months of NM hear. The replacement has seen 120+* all the way down to -40*
    It is the AGM. Been going strong for 5 years now. Zero issues.
    Luckydog likes this.
  4. Jan 14, 2022 at 7:25 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    It goes into the ALT-S fuse slot in the under hood fuse box in replacement of the fuse. The GM diode requires minor timing (think a pocket knife) to fit.
    TTund16[QUOTED] likes this.
  5. Jan 14, 2022 at 9:14 PM
    pandapro
    pandapro New Member
    Like this?
    General Motors DIODE 12135037-5 https://www.amazon.com/dp/B071913NJ4
    HulkSmurf14[QUOTED] likes this.
  6. Jan 15, 2022 at 5:54 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That's the one!
    When you buy and try to install it, you will need to clip a small part off to get it fully seated into the fuse location...like this:
    TTund16 and pandapro[QUOTED] like this.
  7. Jan 15, 2022 at 5:58 AM
    HulkSmurf14
    2014 Tundra Limited
    Now clip it, clip it real good...
  8. Jan 15, 2022 at 7:07 AM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    For standard lead acid batteries I've always found interstate to be the best and cost effective. My factory battery failed at 2 years, the inner post separated without warning IN the Costco Parking lot.
    Bought the Interstate.
    And all my other vehicles when I had the option to buy at my convenience, I have tried to go with an AGM. Not sure who makes it, but I've bought 3 at O'Reilly. One is 8 years old and going strong.
    Rodtheviking and HulkSmurf14 like this.
  9. Jan 15, 2022 at 7:12 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Walmart Everstart. 3 year free replacement warranty, $98.99. Prorated 5 years. I live in Houston where heat is relentless, I always get about 3.5 years out to them sometimes lucky and get 2 years 11 months and get a free replacement. start cycles take a toll on batteries. The same battery in my boat over 10 years old. I think we can all agree Walmart is everywhere and they don't require a membership. Even if you are out of town there is a Walmart.
  10. Jan 15, 2022 at 7:24 AM
    AZTundra
    Paul
    Phoenix, AZ
    Do you recall which direction the arrow faces? I'm going to swing by Chevrolet today and see if they have one in stock.
  11. Jan 15, 2022 at 7:34 AM
    HulkSmurf14
    2014 Tundra Limited
    Nice reminder Paul, it does matter which way it's inserted...
    Arrow points to the right...as in the direction most read...towards the right
    TTund16 and AZTundra[QUOTED] like this.
  12. Jan 15, 2022 at 7:46 AM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks!
  13. Jan 15, 2022 at 7:55 AM
    Gunship Guy
    Gunship Guy New Member
    Rick
    This is my wife’s original battery in her 2015 Lexus RC350. Still working beautifully. Lucky? Sure. Also notice the Power Pulse desulfator. This is from Pulse Tech and they have been supplying the military for years. As a fleet spec writer we were recommended a similar product from this company that uses a small solar panel. Not a good fit for this car. However since it does use the battery power to perform its function the vehicle needs to be a daily or frequent driver. It will run down the battery after a week of inactivity as discovered on my 2017 Sierra, with original battery. Not dead mind you, but watching the voltmeter I could see that it was heavy charging for quite awhile on my next trip. Cold enough winters and hot enough summers in Omaha to give it a good test. Works very well.
    coldcanuk, RitcheyRch and HulkSmurf14 like this.
  14. Jan 15, 2022 at 8:17 AM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Are there any risks to the trucks electrical system by replacing that fuse with the diode? If you were to switch back to a non AGM battery, can the diode stay in the fuse block or does the fuse need to go back in?
    TTund16 likes this.
  15. Jan 15, 2022 at 8:23 AM
    mountainpete
    Technically there is some risk as you are replacing a fuse with a GM diode as it eliminates the fuse.
    If you buy the HKS version it’s a diode and fuse. Best way to go but much more expensive. It’s a risk based decision - I went GM.
    https://www.hkbelect.com/product/438-mk2-micro-blade-5a-electronic-fuse-version-2019/
    And if you go back to non AGM just switch back to the fuse. All the diode does it increase the charging voltage.
    camron1039, HulkSmurf14 and TTund16 like this.
  16. Jan 15, 2022 at 8:33 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    From the dust I assume it's been a long time since you checked the electrolyte levels?
    NewImprovedRon likes this.
  17. Jan 15, 2022 at 4:37 PM
    AZTundra
    Paul
    Phoenix, AZ
    Picked up my GM diode this afternoon.
  18. Jan 15, 2022 at 5:34 PM
    Jalzate44
    Jalzate44 [OP] New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    Thanks everyone. Going with the Costco one!
    RitcheyRch likes this.
  19. Jan 15, 2022 at 5:38 PM
    #49
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Would you mind elaborating on this, or pointing me to a thread that discusses it? I have the Batteries Plus X2 power I believe it is, and I never modified anything. Do I need to for proper charging? Thanks!
  20. Jan 15, 2022 at 6:30 PM
    #50
    mountainpete
    There are quite a few threads on the subject. This is an example of one of the threads: https://www.tundras.com/threads/agm-battery-charging.97564/ but you will find more if you search “ALT-S” on the site.
    Simply put, an AGM runs optimally and lasts longer if receives a relatively high charge voltage. Example for an ODX 27F:
    Stock, a 2.5 gen Tundra doesn’t put out a voltage in the ideal range for cycle charges. It rarely goes above 14v. It will keep a topped up battery full perfectly fine, but if you drain it with a winch, fridge, etc, an AGM needs more voltage to properly charge and maintain its life.
    If you modify what is put in the ALT-S fuse you can increase your alternator voltage by about 0.5v (depending on how you do it). The voltage increase will bring it up to the ideal area for an AGM. The mod is common across Tundras and Tacomas.
    The cheapest way to do this is with a GM alternator diode. Less than $10 and generally reliable. There are other options that are adjustable voltage that are more expensive but also have better fusing in place if something in your wiring goes wrong. The HKS version is also specially made for this application vs the GM diode being more of a “hack”.
    Hope that helps.
    boostedtrdpro[QUOTED] likes this.
  21. Jan 15, 2022 at 6:32 PM
    #51
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    O’Reilly sells the GM diode for $4. I had to order it but they got it next day.
  22. Jan 15, 2022 at 6:34 PM
    #52
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Personally I'm a huge fan of Northstar
  23. Jan 15, 2022 at 6:36 PM
    #53
    mountainpete
    And no longer made :(
    Odyssey ODX is now the identical replacement.
  24. Jan 15, 2022 at 6:46 PM
    #54
    boostedtrdpro
    Jeremy
  25. Jan 15, 2022 at 6:49 PM
    #55
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Guess I should buy one more for the future
  26. Jan 15, 2022 at 6:51 PM
    #56
    mountainpete
    I just had mine warranty replaced direct from Enersys and they are now only building the Odyssey brand. Side by side and spec to spec they are identical except for color.
  27. Jan 15, 2022 at 6:52 PM
    #57
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    mountainpete[QUOTED] likes this.
  28. Jan 15, 2022 at 6:53 PM
    #58
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Wonder why they gave it up.....
  29. Jan 15, 2022 at 6:54 PM
    #59
    mountainpete
    Enersys bought Northstar pre-pandemic and last year decided to merge it all under Odyssey. At least that’s the explanation I received from Enersys.
  30. Jan 15, 2022 at 6:56 PM
    #60
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    From my experience, products pre-merger are usually better than post-merger (ie. Alienware & Dell). Worried about this Odyssey copy cat's quality.
