Best Battery Terminals for my Tundra?
Discussion in '2nd Gen Tundras (2007-2013)' started by mlong219, Apr 26, 2017.
  1. Apr 26, 2017 at 1:16 AM
    mlong219
    mlong219 [OP] New Member
    Hi All,
    I just purchased the NorthStar 27F Battery for my 2010 Tundra 4x4 Platinum CrewMax. After a few days with the new battery, today my battery was dead, and wouldn't start.
    Once I got the truck jumped, and drove home, I checked the connection, and noticed the + battery terminal, looks like it corroded, and about to break based on the following pic?
    Any suggestions, on which terminal connectors I should use with the NorthStar?
    Will this replacement work, or are there better ones?
    http://tinyurl.com/loejeu5
    Thanks,
  2. Apr 26, 2017 at 1:53 AM
    caboose
    caboose -1
    somewhere in the USA
    tundra dc trd
    ride rites w/ air compressor, trd pro grille, decked bed storage, nfab rkr rails w/steps, remote start.
    omgboost, Hoff and TundraDan723 like this.
  3. Apr 26, 2017 at 2:47 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Get the ones in your link they are factory style and will work very nice. Coat them in some dielectric grease or get battery cabLe protectant spray to prevent corrosion
  4. Apr 26, 2017 at 2:48 AM
    Tundraplatinum
    2016 Platinum CM
    These are awesome, especially if you have some add ons tied into battery. But a little spendy$$$$
  5. Apr 26, 2017 at 5:53 AM
    Mike Tread lightly.
    south carolina
    I bought some for my tundra thanks to @csuviper for the source... . Imo it's the best I have seen yet for battery connections and multiple connections at once. .. they are heavy but very very well built and designed.
    If you have the money go for it.
    It's on my build page also on a lead acid battery.
  6. Apr 26, 2017 at 7:37 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    They are very nice terminals. Made of aluminum so chance of galvanic corrosion over a long time but the company said they have never heard of an issue with them. Aluminum is a pretty good conductor. Better than lead.
    NewImprovedRon likes this.
  7. Apr 28, 2017 at 6:31 AM
    mlong219
    Well I decided to go with the original terminal from Toyota. Truck starts better now. I may look into the high end ones that CSUVIPER suggested later.
    Also, is there a way to clean the wire ends, that connect to the terminal? They looked really dirty. Brake cleaner maybe?
  8. Apr 28, 2017 at 6:50 AM
    mlong219
    Also, can anyone tell me what the original negative battery cable looks like on the Tundra 5.7 4x4 engine?
    This is what I currently have, and I believe its a aftermarket cable, but I want it replaced as well.
    I went to O'Reilly Auto Parts, and they suggested the following replacement, but it looks odd to me.
    http://tinyurl.com/lrzexzt
    I went ahead and selected the following, but not sure if it would work?
    http://tinyurl.com/kztwu6o
    Thanks!
  9. Apr 28, 2017 at 7:09 AM
    csuviper
    Broomfield, CO
    Clean with this. It will neutralize the acid.
    Inquiringone and RitcheyRch like this.
  10. Apr 28, 2017 at 7:17 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I'd advise using a wire brush, and then a good coat of this. http://tinyurl.com/lkhx8k9 It'll seal the connector and prevent corrosion in the future. Any halfway decent auto parts store will have it.
  11. Aug 8, 2019 at 7:02 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Looking for some advice on how you connected the factory positive (+) from your tundra harness to this new battery terminal? Mine has this “L” bracket attached to the end, which would likely attach to the new terminal, but the tabs near the end look like they will be in the way. I put an arrow at the “tab” I feel will be in the way...advice?
  12. Aug 8, 2019 at 7:04 AM
    csuviper
    Broomfield, CO
    The tab can bend up if needed
    Jrharvey02[QUOTED] likes this.
  13. Aug 8, 2019 at 7:14 AM
    Randy Morton
    Randy
  14. Aug 8, 2019 at 7:46 AM
    Jrharvey02
  15. Aug 8, 2019 at 7:58 AM
    Randy Morton
    Randy
    Yes, they should fit any battery.
  16. Mar 19, 2020 at 3:13 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Are these still the go to connector? I’m about to replace my battery and want something like this.
  17. Mar 19, 2020 at 5:28 PM
    Randy Morton
    Randy
    They're still working great for me.
  18. Mar 19, 2020 at 6:24 PM
    Cfincke
    San Antonio
    I have had them for 2 years now, have not seen a better option
    BlueBottle[QUOTED] likes this.
  19. Mar 19, 2020 at 6:28 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Just placed my order!
    Randy Morton likes this.
  20. Mar 19, 2020 at 7:13 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Kicker terminals are rad.
  21. Apr 5, 2020 at 11:34 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Anyone find a solution to cover the positive terminal lead? I don’t feel comfortable with it exposed like this.
  22. Apr 6, 2020 at 5:30 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I just ordered the sdhq ones :thumbsup:
    Platinum714 likes this.
  23. Apr 6, 2020 at 5:35 AM
    Cfincke
    San Antonio
    I have had mine installed for 2 years now without issue. I was hesitant at first too.
  24. Apr 6, 2020 at 7:58 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    SDHQ has terminal covers? Photo/link please
    I know it should be fine for the most part, but if anything accidentally touches that and any ground, that will be bad news.
  25. Apr 6, 2020 at 8:27 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I think he was referring to recently ordering the SDHQ battery terminals
    Flyinryank and Bakelite like this.
  26. Apr 6, 2020 at 10:10 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    why is the positive terminal spun around like that and not sitting over the battery?
  27. Apr 6, 2020 at 12:38 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    because the harness lead can't make it any further. Some moved it horizontal but I don't like how close it is to the battery tie down like that.
  28. Apr 6, 2020 at 5:56 PM
    619Tundra
  29. Apr 6, 2020 at 6:00 PM
    619Tundra
  30. Apr 6, 2020 at 6:34 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    When I bought my car last year and battery died, the bracket rusted off and broke. Ended up buying new Toyota terminals. Spent about $30-40. Could have gotten myself a pair of these for that money :frusty:
    619Tundra likes this.
