Best 3.0 Lift kit between Fox vs. Icon vs. ToyTec vs. King vs. Other's
Discussion in 'Suspension' started by zachzap361, Mar 24, 2020.
  1. Mar 25, 2020 at 8:07 AM
    zachzap361
    zachzap361 [OP] MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    @monaco730 the link I sent earlier was before you cleared up the air on the difference of with and without resi.
    I love @sdhq_offroad they got great stuff and great prices too. Will probably go through them.
    @GiantsFanDan I do appreciate the help. I think like @Alexstundra said I'll cry when I do it but I'll never look back from the decision.
    GiantsFanDan likes this.
  2. Mar 25, 2020 at 8:16 AM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    U can also try wheelers off road. They beat everyone’s prices for My fox and gave me free shipping with a forum discount
    Sunnier likes this.
  3. Mar 25, 2020 at 8:21 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    There are tons of variables that come into play when picking the correct setup for your needs/ wants.
    One thing that you need to also keep in mind here is that most of the kits you are looking into (KING, ICON, FOX) will need to be removed from the vehicle (manufacturers recommendation of every 40-60K) and sent in for a rebuild/ service (if you are not able to do it yourself) to insure the proper life, performance and durability possible.
    All the options you are looking into are amazing options but MAY be overkill for you actual needs. Every option you listed has their amazing pros VS cons overall.
    Our standard BOSS 2.0 kit will offer great on road/ offroad performance, full ride height adjustable coilovers in the front, double zinc coated bodies, specific valving within the shock to optimize ride quality and performance overall. Our BOSS kit is specifically designed as a "Daily driver/ weekend warrior" kit, and IF a shock starts to leak it will be a simple replace of a shock itself, no need to have the vehicle down longer than needed, especially if its your daily driver vehicle.
    ICON - Digressive valving within the shocks themselves to offer a better higher speed style driving experience with optimal performance offroad. - Rebuildable
    KING - Progressive valving within the shocks themselves to offer you a better slower speed style driving experience. - Rebuildable
    BOSS - Progressive "specific" valving within the shock to optimize ride quality on and offroad. - Not rebuildable, replaceable shocks. Regardless we can get you taken care of no problem at all, here at Toytec we offer all the major brands from KING, ICON, Etc in stock here ready to rock and roll.
    Feel free to give us a call anytime at 303-255-4959 and we can get you taken care of.
  4. Mar 25, 2020 at 8:21 AM
    StrmTroop29
    StrmTroop29 New Member
    Anthony
    Let me know what kit you are looking for sir! Our boss kit is back in stock with our rear shocks as well. I'm Anthony over at Toyteclifts!
    zachzap361[OP] likes this.
  5. Mar 25, 2020 at 8:24 AM
    Vizsla
    Vizsla pretend2send
    I’ve run a version of all of the Fox Tundra shocks. Didn't matter 0-2” or 0-3” with the 2.5 shocks, they had 3.5”+ lift out of the box. The lowest I could set them was 2 3/8” lift. 2.0 had 2 1/4” lift out of the box, didn’t adjust.
  6. Mar 25, 2020 at 8:39 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have Fox 2.5s up front and 2.0s in rear. I'm sitting on close to 8" lift. The ride is not stock feeling at all but I like a firm ride in a 4x4 rig. My 2WD Sequoia sits on Bilstein 5100s on all 4 corners and it feels as smooth as it did on stock shocks. On the lowest setting it was lifted 0.75" so if you were to put it on the highest setting you'd probably get close to 3" if lift (someone else probably has it set up that way so they can chime in if that's true). Point is for what you're wanting to do, Bilsteins can get the job done and not break your wallet or kill your ride quality.
    Note: the shop who put my 2.5s in mentioned they could go higher with them if wanted - I replaced my 6" readylift spacer so that gives you an idea on the versatility of them
    monaco730 likes this.
  7. Mar 25, 2020 at 8:51 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I've got the toytec/radflo collabs
    Had I done it over again, would have gone ADS or King (90% sure ADS)
    Flyinryank likes this.
  8. Mar 25, 2020 at 8:52 AM
    zachzap361
    Zach
    San Antonio
    @HBdirtbag Why is that? Bad experience? Mess up over time?
  9. Mar 25, 2020 at 8:54 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    I just think the others provide better quality and the trucks i've ridden in with King and ADS were much smoother and better off road. I'm currently rebuilding mine and goign from the 700lb spring toytec put on them, to a 600 lb spring. That may help....even radflo didn't understand why they went with a 700lb spring as it's heavier then anyone else puts on these kits and should only be used when you've got a lot of gear up front.
    Now that said, everyone has different needs/wants. I always shoot for the best i can buy and generally go overkill on suspension. I'll offroad a few times a year, everything from fast sand dunes, to slow as shit rock crawling, but spend 98% of the time on the hwy.
  10. Jun 12, 2020 at 10:24 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    My low mileage Tundra came with the Toytec ultimate 3" on it i love it alot. My recommendation tho if you do go with it , for the rear go add a leaf or shackle (not block) . An make sure to get the SPC upper adjustable control arm.
  11. Jun 13, 2020 at 6:29 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    The question should start with what’s your budget.
    chugs and T-Rex266 like this.
  12. Jun 13, 2020 at 1:05 PM
    PNWpeakseekers
    PNWpeakseekers New Member
    Ben
    2019 Tundra double cab
    Just installed the ToyTec 2.5 Aluma. After trying to keep up with a lifted Rubicon in Utah the lift was needed. Only road use so far but drives smooth, no complaints. I have the Toyota Bilstein front and rear shocks and original upper arms and rear shackles if anyone knows some people looking for an extra set. Came from a 2019 double cab with 10,000 miles
  13. Aug 15, 2020 at 1:24 PM
    Thomascapital
    Thomascapital New Member
    I bought a 2016 trail edition forerunner back in February 2017. Love it. Full package KDSS etc. Install icon to lift system with the additional control arm. Set it to 3 inches. It is the best system.
  14. Aug 15, 2020 at 2:47 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Any of them cranked to 3.5 inches of lift will ride like garbage....
    chugs likes this.
  15. Sep 9, 2021 at 6:38 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    I just ordered the wrong fox shocks, 883-02-021, and was going to cancel the order, because I wanted 2.5-2.75" of lift to make up for my ranch hand summit I just ordered. So I might be okay with the ones I got and can get another 1/2 to 3/4? I just want to end at 2" of lift.
  16. Sep 10, 2021 at 8:56 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Max height for those shocks are 2". We typically recommend actual lift height to be slightly under that for the best ride quality. At 2" or more, you run the risk of driving around with the shocks topped out and not providing the best ride.
  17. Sep 10, 2021 at 10:19 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Thank you for the info, I will purchase taller ones. Thanks!
  18. Sep 10, 2021 at 10:25 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    If I were to call, would ya'll be able to walk me through the order for my specific requirements? Honestly I need someone to hold my hand so I stop ordering the wrong thing!
  19. Sep 10, 2021 at 12:17 PM
    #49
    AccuTune Offroad
    El Cajon, CA
    PM sent! Happy to help
  20. Dec 18, 2021 at 4:46 PM
    #50
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Would there be any issues with running the Kings 3.0 with RR in the front and 2.5 with RR in the rear?
  21. Dec 20, 2021 at 7:19 AM
    #51
    AccuTune Offroad
    El Cajon, CA
    If properly tuned it can be fine, however that 3.0 DIA Coilover up front is not needed. Matching 2.5 DIA front and rear will work great for most applications.
    YotaBro[QUOTED] likes this.
  22. Dec 20, 2021 at 9:11 AM
    #52
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    Probably all great advice but I have the ICON 2.5 VS RR CDCV up front and the 2.0’s in the back, and love the ride on pavement. Started with the clicker up front on 5, ended up with it at 6 for a good blend of on-road manners for me and the family. It’s not Cadillac-plush, it’s more like firm and planted confidence-inspiring handling without being harsh or jouncy at all.
    I bought ICON specifically after researching digressive vs progressive. I primarily wanted great highway-speed handling on pavement and great performance on poorly-maintained roads, and I got it in spades. The off-road reputation speaks for itself, although I very rarely need it.
    TundraPJ likes this.
