Benefit/Harm to Running W/O Front Sway Bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by ThisGuy03, Jan 26, 2022.
  1. Jan 28, 2022 at 3:22 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  2. Jan 28, 2022 at 4:15 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I have been driving for 44 years and never came close to hitting anything bigger than squirrels, birds, armadillos, and opossums.
    Both of these were the same morning.
    Not letting me embed YouTube shorts
    https://youtube.com/shorts/atlpYDqe648?feature=share
    https://youtube.com/shorts/48nuNUksk-Q?feature=share
    joseph_womack likes this.
  3. Jan 28, 2022 at 4:58 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    Your second video is "video unavailable." I've hit a few small animals too, including a dog that wanted to chase my truck. He rushed out and slid on the dirt right under my front tire. Luckily, he got up and took off, seemingly no worse for the wear.
    Someone took out an armadillo in front of my house. Didn't even know armadillos lived in this area. Came home to find a big vulture (also not known in this area) trying hard to drag the armadillo off. The whole thing reminded me of Arizona or New Mexico, not northern Alabama.
  4. Jan 28, 2022 at 6:49 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Yeah, fixed it. radio was playing music. Copyright block. Elk walked out of the dark in front of me doing 75. Missed him by moving over.
  5. Feb 1, 2022 at 6:39 AM
    ThisGuy03
    ThisGuy03 [OP] New Member
    Las Vegas, NV
    ‘17 CM LTD TRD 4x4 MGM
    King 2.5s..TC UCA..35x12.50-18 M/T..AMP Steps
    Kings 2.5s and TC UCA. July 2021 install. Doesn’t do it at higher speeds.
    joseph_womack[QUOTED] likes this.
  6. Feb 1, 2022 at 6:54 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Depending on how frequent the noise the OP is experiencing this, this is a logical explanation especially going from Reverse to Forward, the pads tend to shift in the caliper within the caliper abutment clip.
    @ThisGuy03 - is it more pronounced when reversing with a hard braking motion then proceeding forward with hard braking motion?
  7. Feb 1, 2022 at 10:34 AM
    ThisGuy03
    Las Vegas, NV
    I know about the floating pads. I do have that noise as well as the ABS actuators engaging. I know what those sound like.
  8. Feb 1, 2022 at 1:30 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    did you put those UCA on when lifting it? or did you have them on before the lift and kept them on after?
  9. Feb 1, 2022 at 1:44 PM
    ThisGuy03
    Las Vegas, NV
    It was all done at the same time. Coils, UCAs, gusseted Spindles. That was July 2021, and this issue has just come up in the last 3 months or so.
  10. Feb 1, 2022 at 1:47 PM
    joseph_womack
    Joe
    Louisiana
    hmmmm, can you check your cam bolts (bolts on the LCA that adjust camber, have white covers with little marks on it) and make sure they're tight, you can get a clunk if they aren't, but you've got me scratching my head at this point, maybe check LCA bushings and ball joints.
  11. Feb 1, 2022 at 1:54 PM
    ThisGuy03
    Las Vegas, NV
    I thought LCA bushings and cam bolts as well. I just had it at the dealer for diff service and T case service. They inspected the LCA and bushings and bolts and said all was well. I also thought LBJs, but I don’t have any movement/popping when turning the steering wheel like I’ve seen in videos. I’ve been scratching my head as well. I don’t want to start throwing money at parts that may not remedy the issue. I also don’t want to have a catastrophic failure with my family on board.
  12. Feb 1, 2022 at 1:56 PM
    joseph_womack
    Joe
    Louisiana
    why don't you throw the sway bar back on for a month or two and see if the noise stops entirely, if it does, then maybe the problem sits in one of the shocks or something (since they can't articulate independent of each other (with the sway bar on))
    if the noise stays then you know its not a specifically related to the sway bar issue, then you could start having other things checked
    might not be the solution you want, but its a way to trouble shoot and attempt to narrow down the problem
  13. Feb 2, 2022 at 12:16 AM
    handyman
    handyman New Member
    So far, so good. The proof is in the pudding.
