Beeping while engine on, shut door and walk away
Discussion in '3rd Gen Tundras (2022+)' started by MJPlat, Feb 17, 2024.
  1. Feb 20, 2024 at 4:20 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Stuff the speaker in a pillow or stuffed animal that should muffle the sound...
  2. Feb 21, 2024 at 6:53 AM
    surfmc
    surfmc New Member
    2023 Tundra 1794 off-road
    Wouldn’t common sense say that would be something the driver would want to know at the time and not after they drive away without the key? I can’t see any rational reason for any vehicle to be able to be driven without the key.
  3. Feb 21, 2024 at 9:38 AM
    40man
    40man New Member
    It does let you know at the time via the beeping yet still running. Otherwise if your key fob dies while driving the car would turn off then, which common sense would say is a big problem...
    Tundrastruck91 and Mattedfred like this.
  4. Feb 21, 2024 at 10:01 AM
    surfmc
    surfmc New Member
    I’m just saying it seems odd that you can drive this thing without the key in it. So if I start the truck and walk back inside to get something, with my key in my pocket, it will beep to let me know I took the key, but then anyone can just jump in it and drive it away.
  5. Feb 22, 2024 at 8:22 AM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Just found that you can reduce the volume of the beeps in the settings menu under the door and lock settings. It's lower down on the page so you have to scroll down the screen to see it. You can reduce the volume all the way down, and there are no more beeps. Not on lock. Not on Unlock. Not when you shut the door and walk away. Or you can set them to very quiet beeps.
  6. Feb 22, 2024 at 10:26 AM
    Livin
    Livin New Member
    Kevin
    24 Black Pro
    Our rav 4 has the same beeping when I walk away as well , it is what it is
  7. Feb 22, 2024 at 11:05 AM
    DRP
    DRP Old Member
    Dave
    Thanks! Beeps no more...
    Edit: Need to retract my last statement. Still beeps when I walk away. No beeps on lock/unlock.
    Mattedfred and ChucklesToy like this.
  8. Feb 23, 2024 at 12:11 PM
    Keadog
    Keadog New Member
    It makes about as much sense as the remote start turning the engine off when you open the door WITH THE KEY (remote).
    Anyone who doesn't know they got out of their truck and closed the door (intentionally) with the engine running probably shouldn't be driving.
  9. May 18, 2024 at 1:24 PM
    Box
    Box New Member
    2023 Tundra Limited
    Thanks for this. I found this thread after spending an hour clicking through Techstream and trying different settings with no luck; frustrating this isn't a simple toggle on/off. Interestingly, the volume for this speaker should be controlled by the following setting: My Settings - Driver 1 - Warning Buzzer Volume. I adjusted this setting and it worked for the beeping coming out of this speaker for "normal" beeps like keyfob lock/unlock. However, the adjusted volume setting did not work at all for leaving the vehicle with keyfob while ignition is still on. It still produced the 7 annoying beeps at full volume. So, the only option is to unplug or physically muffle the speaker, so I just unplugged it following your picture below.
    Very frustrating as I car camp regularly with this truck (2023 Limited). While I am packing up in the morning, I start it up to warm up in winter or get the AC blasting in summer and I open/close the door quite a few times causing a cacophony of beeps that I am sure my fellow campers enjoy.
  10. Sep 24, 2024 at 5:16 PM
    60centenergy
    60centenergy New Member?
    Zack
    Greenville, SC
    2024 Lunar Rock SR5 Tundra TRD Sport
    I just came across this too! Thank you @Nschmittsd for finding this. I tried adjusting the volume from Carista and other places but that annoying constant beep when closing the door and keys not in the truck, was still there.
    I looked up under the driver fender liner
    I found the little box, unplugged it, tried to close the door while truck was on and keys in my pocket outside the truck and didn't hear anymore beeps! I just taped up the connector and plug end just to try and keep some water from getting in there.
    Nm6300'asl likes this.
  11. Mar 4, 2025 at 4:45 PM
    akira
    akira 25 Tundra Limited TRD OffRoad
    San Diego
    Just unplugged this and no more beeping when I get out of the running truck with keys in my pocket! I have the lock/unlock set to beep (not honk), so now when I lock or unlock the truck with the key fob, I only have the lights flashing. No audible beep.
    Thank you for this.
    60centenergy[QUOTED] likes this.
  12. Mar 4, 2025 at 6:06 PM
    60centenergy
    Zack
    Greenville, SC
    I’m glad it helped! Definitely one of the best “mods” I’ve done on the truck so far.
    akira[QUOTED] likes this.
  13. Mar 4, 2025 at 8:44 PM
    Petro
    Petro New Member
    2019 Tundra SR5 TRD OR Crewmax
    The previous owner of my truck installed a Compustar remote starting/alarm system since the truck didn't have the factory.
    I guess the plus is my vehicle doesn't shut off when I open the door.
    Didn't know Tundras did that.
  14. Mar 5, 2025 at 5:36 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I'm in and out of my running truck frequently around our ranch. I just leave the FOB in the center console tray most of the time. No beeping.
    Tundrastruck91 likes this.
