BedRug with Factory Bedliner
Discussion in '2.5 Gen Tundras (2014-2021)' started by thexman1, Jan 9, 2019.
  1. Jan 9, 2019 at 8:02 AM
    thexman1
    thexman1 [OP] New Member
    James
    Dayton, Ohio
    2016 Tundra (AKA: "The Mothership")
    I'm hoping y'all can help me. I have a 2016 crewmax and have a factory sprayed bedliner. I have been looking at a classic bedrug liner (https://bedrug.com/bedrug-classic-bedliners/2016/toyota/tundra) but am worried if the bedrug adhesive will stick to the spray liner material.
    Anyone have experience with this?
  2. Jan 9, 2019 at 8:04 AM
    Bedrug sells special velcro that adheres to spray on bed liners.
  3. Jan 9, 2019 at 8:45 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I’ve got a sprayed in bed liner with a bed rug installed over that. Been about 5 years now, it’s losing its stickiness in a couple spots but after 5 years in Colorado....I’ll take that.
    Black Wolf likes this.
  4. Jan 9, 2019 at 9:33 AM
    Jrharvey02
    ......and you can peel it back and re-stick with no problems, it’s like velcro. I wired up some leds, needing to pass the wire under the rug, and it went back into place and stayed there.
  5. Jan 9, 2019 at 10:09 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I just installed their tailgate rug. It asks to sand the liner where the tape is going, I didn’t want to wreck the surface and skipped that part. I did clean/dry it well, applied rubbing alcohol, their adhesive promoter and used a heat gun to warm the area up as it was cold the other day.
    I imagine the rug sticks longer if you have a tonneau cover so it rarely gets wet. Thinking of doing the bed too, feels great, could sleep on that surface.
    NewImprovedRon likes this.
  6. Jan 9, 2019 at 12:37 PM
    thexman1
    James
    Dayton, Ohio
    Thanks y'all. Very helpful. Sounds like I can do it and I worried about nothing. :)
  7. Jan 9, 2019 at 12:58 PM
    curt37
    curt37 New Member
    FRESNO, CA
    2018 Tundra Limited Crew Cab white
    SNUGTOP BED COVER
    I don't have a spray-on liner but have a Bed-rug, didn't use the Velcro on the bed and it stays put. The fit of the bed-rug is so good that you don't need the Velcro.
  8. Jan 11, 2019 at 8:10 AM
    Ronin
    Ronin Hoof Hearted
    Bill
    2019 CrewMax 5.7 Tanker
    Does the rug need to be trimmed if you have the deck rail system?
  9. Jan 11, 2019 at 9:12 AM
    curt37
    curt37 New Member
    FRESNO, CA
    SNUGTOP BED COVER
    I don’t have the back and sides Bedrug, but I think it just goes up to the bed rails.
    Ronin likes this.
  10. Jan 11, 2019 at 11:26 AM
    Ronin
    Ronin Hoof Hearted
    Bill
    Thanks. I decided just to go with the BedRug matt and tailgate rug since I already have a spray-in liner...
