Bed Stiffeners - What do they do? Do I need them?
Discussion in 'General Tundra Discussion' started by TOTAL CHAOS, Jul 10, 2018.
  1. Jun 29, 2020 at 9:35 AM
    #181
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    The nut on the bed is tacked/spot welded on so as long as they don't get REALLY aggressive with it and somehow break the tack and spin the nut it should work.
    mountainpete[QUOTED] likes this.
  2. Jun 29, 2020 at 10:24 AM
    #182
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Thanks - I will let you know how it goes.
  3. Jul 1, 2020 at 2:18 PM
    #183
    mountainpete
    Dealer came through and fixed the bolt. Had to cut off the old and weld on a new nut.
  4. Nov 11, 2020 at 5:33 PM
    #184
    donny.brooke
    donny.brooke New Member
    2024 TRD Offroad dbl cab Lunar Rock
    Can you get these in Canada?
  5. Nov 11, 2020 at 5:36 PM
    #185
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  6. Nov 11, 2020 at 7:29 PM
    #186
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Wonder if these would help with this weird popping noise I have in the rear when making turns. Sounds like a warping noise like the bed is flexing somewhere.
  7. Nov 11, 2020 at 7:41 PM
    #187
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    All 6 bed bolts tight?
  8. Nov 12, 2020 at 5:57 AM
    #188
    donny.brooke
  9. Nov 12, 2020 at 6:04 AM
    #189
    BravoDeltaRomeo
    Bruce
    MB Canada
    Not that I know of for this brand. There would be others if you Google it, but I don't think I'd trust them.
    These are $180usd, plus shipping I imagine, let's say $20 to a US address (they're steel and heavy), so about $200+ one tax 7% guessing, total is $214usd or $280 CAD and potential for more taxes if you bring them over the border on a day trip
    So $300 cad is a small bit more than the conversion, but taxes and duty are all included and you don't have to leave your house or travel to the USA during a pandemic (if you can even cross he border) to get them.
    If I was.bjuing, it's worth the extra $20 to have them at my door in Canada.
  10. Nov 12, 2020 at 7:00 AM
    #190
    Tundra_361
    Victor
    2019 Black 1794 4x4
    All the Tundras around here come with a sprayed bed liner. So I assume those bolts are not gonna back out or loosen.
  11. Nov 12, 2020 at 7:27 AM
    #191
    mountainpete
    I ordered mine via Krave in Calgary. Took a bit of time but was cheaper than purchasing direct and I was able to support a local shop. Another option is Overland Outfitters - good small shop in BC that brings in product from a bunch of vendors out the states including Cali Raised and offers them at fair prices. Either way, you're making import and customs their problem (which is a good thing).
    BravoDeltaRomeo and Wrongside like this.
  12. Nov 12, 2020 at 7:44 AM
    #192
    14burrito
    2014 SR5 CM 4x4 5.7
    Unless they were loose to start with...
  13. Nov 12, 2020 at 8:20 AM
    #193
    donny.brooke
    Emailed Total Chaos and got some dealer info. Overland in Surrey B.C.
    BravoDeltaRomeo likes this.
  14. Nov 12, 2020 at 8:30 AM
    #194
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Just put in an order :D
  15. Nov 12, 2020 at 1:31 PM
    #195
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Could have been. The sound has been more frequent over time. Might put my rear sway bar back on and see if this helps limit the body roll.
  16. Mar 20, 2021 at 7:39 PM
    #196
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Can somebody measure there bed from the mounting bolt too the side? I’ve got a weird clunking noise that showed up after the addition of the camper top. I suspect bed flex but nobody makes a set for the 1st gens. Was curious if I could make a set work off the shelf or if I’ll have to build a set
  17. Apr 6, 2021 at 12:22 PM
    #197
    IndianaGeologist
    IndianaGeologist New Member
    Would you recommend installing the stiffeners before getting the bed line-x?
  18. Apr 6, 2021 at 12:38 PM
    #198
    mountainpete
    I would recommend after.
  19. Apr 6, 2021 at 1:17 PM
    #199
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Like @Cummins3500 I too want to know if these will work on a first Gen. I don’t off-road other than logging roads, but I do wonder if my bed flexes. Can’t hurt to have some extra rigidity in the build of the truck. More tie downs are always welcome.
  20. Apr 14, 2021 at 7:15 AM
    #200
    taytor
    taytor New Member
    2019 Crewmax SR5
    @Bailey Can you let me know if you had any issues running these stiffeners with your Four Wheel Camper Raven?
    I'm about to the pull the trigger on ordering from 4WC and wanted your opinion if the stiffeners will interfer with the bottom of the camper.
  21. Apr 15, 2021 at 12:42 AM
    #201
    pnw tall trees
    pnw tall trees New Member
    Pacific Northwest
    07 Limited Crewmax
    I was in line for doing a roof-top tent system over the bed and saw the concern about constant pressure causing the side rails to spread, so I decided to prepare with the Total Chaos bed stiffeners. They’re a serious hunk of steel and happily straightforward to install. I have a spray-in liner so I had to cut around the big bolt and peel off the bed liner in order to get the torx in there. It was easy to do but you’ll want to fill that spot with a properly-sized washer so the horizontal portion of the bed stiffener under the big bolt is supported and level. I ended up postponing the roof-top tent purchase but in the meantime I have piece of mind and some very useful and numerous lash points in the rear of the bed. The various lash points are helpful for securing stuff especially if you have to drive with the tailgate down. Pricey but two thumbs up for Total Chaos.
    TOTAL CHAOS[OP] likes this.
  22. Apr 15, 2021 at 4:09 AM
    #202
    IndianaGeologist
    I'm about to get the bed liner, can you mount the bed stiffeners on top of the liner?
  23. Apr 15, 2021 at 6:13 AM
    #203
    Skew12
    Skew12 New Member
    2010 Black Rock Warrior
    Do these help with bed bounce on the road?
  24. Apr 15, 2021 at 3:07 PM
    #204
    pnw tall trees
    Pacific Northwest
    07 Limited Crewmax
    Yes, my bed had a thick spray liner before I installed the Total Chaos bed stiffeners. Actually, I think it is best practice to line the bed before you put any mods on, but others may have a different view. I didn't have a choice. It was no problem, just had to cut carefully around the big torx bolt and peel off the bed liner. The other tip is to get a stainless steel washer the same diameter as the big torx bolt head, and put that down first before the bed stiffener to give yourself a level surface. Hope that makes sense.
  25. Apr 15, 2021 at 4:56 PM
    #205
    mountainpete
    Not a cure all but it does help a bit.
    Skew12[QUOTED] likes this.
  26. Apr 15, 2021 at 7:15 PM
    #206
    Skew12
    Skew12 New Member
    Thanks. I’ll give me a shot.
  27. Apr 16, 2021 at 2:58 PM
    #207
    marsbar
    marsbar New Member
    Bob
    CO
    2018 DC Long Bed SR5 O.R.
    Leer cab high topper, Toytec Aluma 2.0 kit, + 1.5 shackles + deaver 3 leaf add, SPC UCAs, SPC LCA bolt kit, 295 70 18 Revo 3 tires.
    easy quick question:
    Are the vertical side members bolting into a single layer of thin sheet metal, or is there something more substantial in the those bolt locations?
    Also, any issues loading 4x8 sheet material (plywood, Sheetrock) with these?
    Thanks
    IndianaGeologist likes this.
  28. Apr 16, 2021 at 10:04 PM
    #208
    pnw tall trees
    Pacific Northwest
    07 Limited Crewmax
    I don’t recall exactly the wall thickness of the bed where the vertical bolts go into (without removing the taillight assemblies) other than I am certain I was satisfied with the operation. The whole thing seemed completely stout to my mind, and remains so to this day.
    The distance between the bottom-most lash hole points is 55 1/4” (it’s way outside of the width of the wheel-wells) so it does not interfere with 4x8 panels laying down in the bed. Hope that helps.
    marsbar likes this.
  29. Apr 17, 2021 at 12:30 PM
    #209
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    You won't be able to run the bed stiffeners with a slide in Four Wheel Camper
  30. Apr 17, 2021 at 1:45 PM
    #210
    Snikskytter9
    Snikskytter9 New Member
    Rich
    New Hampshire
    2017 Tundra SR5 TRD off road
    2” level Nitto Ridge Grapplers Switch Pros 9100 Alpine wireless CarPlay Pillar post lights / amber / white Grille mounted light bar TRD Pro grille Dipped/blacked out badges 20% front window tint RCI 12” rack DECKED bed system LED bed lighting OEM Tow mirrors Crappy awful magnum research side steps.
    Hey mates!
    Will these work with a Deck’d drawer system installed without modifications? I’m sorry if this has been answered somewhere in this post. Thanks!
