Bed Stiffeners - What do they do? Do I need them?
Discussion in 'General Tundra Discussion' started by TOTAL CHAOS, Jul 10, 2018.
  1. Mar 11, 2019 at 9:14 AM
    #91
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Send one this way. I’ll send you pics after the install :rofl:
    TheBeast and Watt maker like this.
  2. Mar 11, 2019 at 9:16 AM
    #92
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    Give us a call to get an order going and then we'll send them your way :spending:
    TheBeast likes this.
  3. Mar 11, 2019 at 9:37 AM
    #93
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    :( Will be ordering one soon lol. :thumbsup: Free shipping and tax free right? Cali resident :p
  4. Mar 11, 2019 at 9:44 AM
    #94
    TOTAL CHAOS
    Corona, CA
    We have to charge you shipping as well as sales tax.
    Ring us at 951-737-9682 and we'll give you an out-the-door price
  5. Mar 11, 2019 at 10:07 AM
    #95
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Will do!!!
  6. Mar 23, 2019 at 4:38 PM
    #96
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Here you go...
    Awesome product, well packaged, no damage, easy to install. Loving them!
    Before...
    After...
    Thanks @TOTAL CHAOS and ORW!!!
  7. Mar 23, 2019 at 4:44 PM
    #97
    TheBeast The Beach
    solid !
    Toyotoholic likes this.
  8. Mar 25, 2019 at 10:52 AM
    #98
    TOTAL CHAOS
    Corona, CA
    Nice job!
    Very clean install with the rubber bed mat. Nicely done :cool:
    Toyotoholic[QUOTED] likes this.
  9. Mar 25, 2019 at 12:27 PM
    #99
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Thanks!
  10. May 13, 2019 at 8:40 AM
    #100
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I chopped about 2.25 inches off my factory bedliner in these pics btw. Solid!
  11. May 13, 2019 at 1:57 PM
    #101
    TOTAL CHAOS
    Corona, CA
    Nice job :thumbsup:
    Lookin' good :cool:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Flyinryank[QUOTED] likes this.
  12. Jul 1, 2019 at 3:52 PM
    #102
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    @TOTAL CHAOS Just an FYI... I started installing a set on my 2018 CM SR5 and Toyota may have "modified" the bed bc the holes are not lining up properly. When I drilled the lower "side" hole, it didn't line up with the access area inside the light cover opening (about 1/2in too low). I ended up drilling a new hole through both the bed AND the stiffener. Would have doen it just 1/2in higher, but since there I had just drilled the bed near there I dind't think it would be as structurally sound, so I went with the access hole about 2 1/4in higher.
    And then with the top hole, again, it does not line up right. Checked this one before I drilled and it would have come out in an area where you cannot get to the back side to install the washer/nut. Ended up drilling a new hole in the bed stiffener/bed about 1/2in lower than the hole provided.
    Going to install the passenger side tonight and I'll take some pics for reference. I would think that it might be good for you to provide a few sets of holes going forward so that customers can pick the set that best lines up with their vehicle year.
    porkitt likes this.
  13. Jul 1, 2019 at 4:46 PM
    #103
  14. Jul 1, 2019 at 6:03 PM
    #104
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    PM SDHQ ;)
  15. Jul 1, 2019 at 6:29 PM
    #105
    Done.;)
  16. Jul 2, 2019 at 9:08 AM
    #106
    DividedSky
    Jeff
    @TOTAL CHAOS ...
    Here are some pics showing how the stock holes (red) and new holes (green) line up on the inside of the brake light opening. Both sets of stock holes end up in a location where they are not accessible from the back side (blocked by sheet-metal), so be sure to tell clients to eyeball them from the back before they drill (or provide a few sets of holes to account for variances between vehicles). Learned this the hard way with the lower hole on the drivers side where I drilled the stock location and couldn't get the washer/nut on despite all my best efforts.
    ToyoD and Rex Kramer like this.
  17. Jul 2, 2019 at 9:26 AM
    #107
    GiantsFanDan
    The stock TC locations worked fine for me and I used a stubby wrench inside the body area.
    Flyinryank likes this.
  18. Jul 2, 2019 at 9:29 AM
    #108
    DividedSky
    Jeff
    I tried the stubby as well, but there was no way in hell it was going to work. The top holes were literally right behind sheet metal, and the bottom holes were far enough down that while I might be able to get the nut/washer on by hand, no tool would have fit in that small space. Stubby wrench or regular....
    pbcolt likes this.
  19. Jul 3, 2019 at 10:20 AM
    #109
    TOTAL CHAOS
    Corona, CA
    Thank You for providing photos and giving us some details as to what modifications you had to do. I'll be discussing this with the team but it might be a minute before I follow up.
    We are closed right now for our shop vacation (6/28-7/14)
    I'll be monitoring the forums while we're closed
  20. Jul 3, 2019 at 11:00 AM
    #110
    DividedSky
    Jeff
    No problem.... I STILL think you have a great product, and these small changes that Toyota may make from year to year are probably impossible to keep up with. Btw, I'm just over here in OC, so if you want to take a look in person that could be arranged. I'd also be willing to be a "test mule" for you guys with future projects.
    :thumbsup:
  21. Aug 13, 2019 at 12:28 PM
    #111
    TOTAL CHAOS
    Corona, CA
    Order your bed stiffeners today! Click this link or check out the image below
    Watt maker likes this.
  22. Aug 13, 2019 at 11:31 PM
    #112
    empenaflor
    empenaflor New Member
    2014 TUNDRA 4X4 LTD - Black
  23. Aug 14, 2019 at 10:01 AM
    #113
    TOTAL CHAOS
    Corona, CA
    You shouldn’t experience any major issues. Some very minor shaving of the Decked system has been required on some trucks but not all
    DECKEDUSA likes this.
  24. Aug 20, 2019 at 9:32 AM
    #114
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Any changes made to work with 2018+ trucks as mentioned by @DividedSky ? I’m holding off until I get confirmation.
  25. Aug 20, 2019 at 10:41 AM
    #115
    DividedSky
    Jeff
    Honestly, the "fix" was so easy I wouldn't even sweat it. If you need to drill some additional holes, just go ahead and do it. Maybe just eyeball it up before you drill to make sure things will align.
  26. Aug 20, 2019 at 11:03 AM
    #116
    sdde4n
    sdde4n New Member
    Kinda hoping for $180 I wouldn’t have to drill holes.
    BravoDeltaRomeo likes this.
  27. Aug 20, 2019 at 12:27 PM
    #117
    TOTAL CHAOS
    Corona, CA
    We haven't made any changes
    The hardware can be accessed with a short box or open end wrench. It can be a little bit tight on some years and models.
    Sorry about any inconveniences caused by this
  28. Sep 5, 2019 at 12:11 PM
    #118
    TOTAL CHAOS
    Corona, CA
    Don't forget, you can always purchase these at an Authorized Dealer instead, here are a couple of options:
    [​IMG][​IMG][​IMG]
  29. Sep 5, 2019 at 1:30 PM
    #119
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    Does anyone make the upper bed supports? The ones up by the cab?
  30. Sep 19, 2019 at 11:37 AM
    #120
    TOTAL CHAOS
    Corona, CA
    Not that we're aware of
    deedubb[QUOTED] likes this.
