Bed Stiffeners - What do they do? Do I need them?
Discussion in 'General Tundra Discussion' started by TOTAL CHAOS, Jul 10, 2018.
  1. Mar 5, 2019 at 12:19 PM
    #61
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    We have a few customers running this setup
    Paul B likes this.
  2. Mar 5, 2019 at 12:19 PM
    #62
    TOTAL CHAOS
    Corona, CA
    Comment below if you have any questions about TOTAL CHAOS Bed Stiffeners
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  3. Mar 5, 2019 at 1:08 PM
    #63
    Yotatundraaah
    Yotatundraaah My tundra stays hungrry
    Southern CA
    2016 Silver Sky Tundraaaah
    Kings suspension Built Right ufc 295/70-18 Toyo AT2 18" XD bully wheels Baja designs foglights Baja designs ditch lights Rago fabrication ditch brackets Tiger auto rock slider Extang solid fold 2.0 cover Read more....
    So if you have the factory bed liner you just put it underneath it?
  4. Mar 5, 2019 at 2:15 PM
    #64
    TOTAL CHAOS
    Corona, CA
  5. Mar 5, 2019 at 2:35 PM
    #65
    Yotatundraaah
    Southern CA
  6. Mar 7, 2019 at 10:51 AM
    #66
    TOTAL CHAOS
    Corona, CA
    No problem :thumbsup:
    Glad I can help
  7. Mar 7, 2019 at 10:53 AM
    #67
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I have the factory bed liner. They sprayed over the bolts and the torx 55 doesn’t catch enough to loosen the bolt. Any solution for that? Anyone came across that yet?
  8. Mar 7, 2019 at 10:55 AM
    #68
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Can you try cutting around the bolt, will it peel off?
  9. Mar 7, 2019 at 10:56 AM
    #69
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Scrape off the bed liner from the bolt?
    15whtrd likes this.
  10. Mar 7, 2019 at 10:57 AM
    #70
    TOTAL CHAOS
    Corona, CA
    As @Hbjeff and @mountainpete mentioned, have you tried using a razor blade or exacto knife to cut around the bolt and peel the liner off?
    This should work but please let us know if it doesnt
  11. Mar 7, 2019 at 10:59 AM
    #71
    pschiller86
    Paul
    Temecula, CA
    I will try that this weekend. Thanks guys!
  12. Mar 7, 2019 at 11:01 AM
    #72
    15whtrd
    15whtrd Mr. Blonde
    Yeah you’ll just have to scrape it out. I forget the size but it should be a fairly snug fit with the torx.
  13. Mar 7, 2019 at 11:21 AM
    #73
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    I had the same issue and I used a mallet to hammer the torx in. Eventually the spray bedliner was removed.
  14. Mar 7, 2019 at 12:15 PM
    #74
    Professional Hand Model
    Hand Protectors
    Heat up the tip of the torx and insert it a few times.
    Watt maker and TheBeast like this.
  15. Mar 7, 2019 at 12:51 PM
    #75
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That’s what she said
  16. Mar 10, 2019 at 1:27 PM
    #76
    pschiller86
    Paul
    Temecula, CA
    Tried heating up the torx bit, tried using a mallet. But still no luck.. anyone wanna buy my brand new set of bed stiffeners?
  17. Mar 10, 2019 at 1:30 PM
    #77
    15whtrd
    15whtrd Mr. Blonde
    Get a nail and scrape that shit out!
  18. Mar 10, 2019 at 1:44 PM
    #78
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Call the shop that did the spray and see what they use to clean it off?
    If you end up selling the stiffeners i will buy them
  19. Mar 10, 2019 at 1:57 PM
    #79
    pschiller86
    Paul
    Temecula, CA
    979BC0A0-201F-4D12-A3C2-05D435AAE746.jpg Check out that torx nut. Any recommendations? Torx T30 doesn’t catch at all ...
  20. Mar 10, 2019 at 2:00 PM
    #80
    pschiller86
    Paul
    Temecula, CA
    I don’t have a 35. Dangit. Might have to go to Home Depot. I have a 30 then 40.
  21. Mar 10, 2019 at 2:02 PM
    #81
    15whtrd
    15whtrd Mr. Blonde
    Hopefully you didn’t blow it out. If you do get it out you should probably replace it by the looks of it.
    Watt maker likes this.
  22. Mar 10, 2019 at 2:02 PM
    #82
    15whtrd
    15whtrd Mr. Blonde
    I bought some cheap ones from Harbor freight and didn’t have all the sizes I needed. I ended up going to Sears and getting my self a nice kit.
  23. Mar 10, 2019 at 2:08 PM
    #83
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How close is an allen key to being pounded in?
    15whtrd likes this.
  24. Mar 10, 2019 at 2:18 PM
    #84
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Razor blade around edge, then remove bolt. Razor circle around torx hole then pick out with pick of some sort.
    https://youtu.be/e0An9Cj2aQI
  25. Mar 10, 2019 at 7:44 PM
    #85
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
  26. Mar 10, 2019 at 8:04 PM
    #86
    TOTAL CHAOS
    Corona, CA
    We can't offer any forum discounts with our pricing policy. An Authorized Dealer might be running a special :thumbsup:
    vq35721[QUOTED] and T-Rex266 like this.
  27. Mar 10, 2019 at 8:22 PM
    #87
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  28. Mar 10, 2019 at 8:28 PM
    #88
    TOTAL CHAOS
    Corona, CA
    T40 is what should fit. Hopefully you can find something that works
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  29. Mar 10, 2019 at 8:49 PM
    #89
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Just ordered with ORW!
    vq35721 likes this.
  30. Mar 11, 2019 at 9:06 AM
    #90
    TOTAL CHAOS
    Corona, CA
    Great! Let's see some pics after you install :D
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Toyotoholic[QUOTED] and vq35721 like this.
