Bed step?
Discussion in 'General Tundra Discussion' started by redryder, May 4, 2019.
  1. May 4, 2019 at 7:54 AM
    redryder
    redryder [OP] New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    I'm looking to get a bed step and the two that I found are the AMP or the BESTOP. What's the differences between the two? Also ice seen some pictures of the steps facing the side of the truck when open and some facing the back. Is that just a user preference that can be changed or is it a certain model step?
  2. May 5, 2019 at 4:25 PM
    11SilverPlatinum
    11SilverPlatinum New Member
    Dave
    2011 Platinum Tundra
    Plastidip emblems, Pace Edward bed cover w/lumber rack, remote start, TRD intake and exhaust, TRD front and rear sway bars, color match grill surround, LED headlight upgrade.
    I love my bed step. It is the AMP step. It kind of goes out at an angle from the rear bumper. It works great to step up on the tailgate. There is only one way to install it. Definitely recommend. :thumbsup:
  3. May 5, 2019 at 5:17 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Toyota’s is a re-branded Amp Research, smaller than Bestop, angled corner so blends with the bumper and looks more OEM when tucked.
    Bestop is larger and the surface is grit like sandpaper. More to step on, sure footing.
    Both use the same kick down mechanism.
    I went for the greater surface area, less slippery when wet. The Bestop comes with spacers to have it sitting slightly lower if you like. And it can be adjusted laterally so it’s hidden more under the bumper from the side.
    This is how I’ve set mine, no spacer used.
    imho, AR looks better, Bestop is more practical and costs less. It will boil down to your preference.
  4. May 5, 2019 at 5:46 PM
    redryder
    Ryder
    Louisiana
    Ok sweet! What is a good place to get the bestop from?
  5. May 5, 2019 at 5:50 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    I too have the bestop bed step. Install was pretty hard for me. There were some bolts That were tricky to get to and a pain to loosen. I bought an open box from ebay for $130
  6. May 5, 2019 at 6:06 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I'm in Canada, bought it on sale from PartsEngine. In the US, use camelcamelcamel and setup an alert. It was $165 last November but Amazon price drops are anyone's guess. Google around if you rather have it sooner than later.
    As noted above, it is a bitch to install the way the bracket you need to remove is bolted under the top bumper cap. Props to @TundraPro2019 for his tips here:
    https://www.tundras.com/threads/bestop-trek-step-or-amp-research-bedstep.27237/#post-954376
    Works well with tailgate down or up, after using it a few times you'll wonder how you lived without it.
    TundraPro2019 likes this.
  7. May 6, 2019 at 1:27 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    0424190818[2999].jpg 1231131642a.jpg Found my best price on Amazon for my Bestop but it was a few years ago. Looked at the Amp Research step but for me, Bestep offered more for less $.
    JoshuaA and Black Wolf like this.
  8. May 11, 2019 at 8:59 AM
    redryder
    Ryder
    Louisiana
    Picked up an open box bestop from Amazon for $160 shipped. Just waiting for it to stop raining and dry up so I can install it.
    Black Wolf and bmcdds like this.
  9. May 11, 2019 at 9:21 PM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    I have the OEM one as well and it’s really useful. I find my self using it a lot more than I thought I would. Installation wasn’t too bad, just take your time and it will be fine. Also make sure to put some tape above the bumper before you start, another member gave me this tip and it saved my truck from scratches. DE25E7BA-9A3E-46C2-911A-1D2B7917AE75.jpg
    JoshuaA, georgiey22 and KnuckleHD like this.
  10. May 11, 2019 at 10:36 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I have the Toyota AMP step and I use it constantly. It’s ok. It feels solid as a rock when you install it,and the components are pretty beefy, but it does flex some under weight. That said I would purchase it again.
    Black Wolf likes this.
  11. May 11, 2019 at 10:51 PM
    I briefly had a '13 CM and I bought a used one off CL, I regret not taking it off when I traded for my '14, was a Bestop brand
  12. May 12, 2019 at 5:40 PM
    redryder
    Ryder
    Louisiana
    So I just got through attempt number one of installing this thing and it kicked my ass. I had the hardest time getting enough of the bumber cap up so I could stick a wrench in to get to that bolt. So after about two hours fighting and cussing I gave up until next weekend. It just was not my day I guess.
    NewImprovedRon likes this.
  13. May 12, 2019 at 5:43 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Cut the bracket. Save yourself the hassle.
    AZTundra likes this.
  14. May 12, 2019 at 6:04 PM
    redryder
    Ryder
    Louisiana
    But don't I still need to get the bolt out?
  15. May 12, 2019 at 7:28 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
  16. May 12, 2019 at 8:16 PM
    shhernandez74
    Samuel
    Here are some pictures I took. I know they are random but I will break down the process.
    I began by removing the bracket. Loosen al the bolts and you’ll be able to “twist” it out. You kinda have to shimmy it in different directions to get it to come out.
    Next I pushed up on those black tabs, I managed to push them out with a long screw driver. Finally to get the bolt underneath the middle section, I just pried the edge up a little and got underneath with a ratcheting wrench.
    If I had to do it all over again I would probably just cut the bracket. I’m just really OCD and knowing that i hadn’t used the correct bracket would drive me nuts.
    31DFF4F6-A3D7-483B-B67E-FDE0E1F6D20F.jpgF15E362B-563D-4A30-9733-76C0BD09DD5E.jpgF0E1D021-06D0-4F07-A8C6-753F025EB9FE.jpg
  17. May 12, 2019 at 8:53 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Jeff_1974 and TXRailRoadBandit73 like this.
  18. May 12, 2019 at 9:01 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    So only usable with the tailgate up?
    I want one that works on the passenger side. Have some replacement parts in my body that makes it tough to climb up from the driver side.
  19. May 12, 2019 at 9:02 PM
    realtorblake
    Yes..
  20. May 12, 2019 at 11:15 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Those shitty plastic clips under the bottom of the plastic topper for the bumper are garbage. They don’t ever sit properly once they are removed. If it’s too cold or the truck has been sitting outside they will snap. My step itself cracked. Cut the bracket.
  21. May 13, 2019 at 5:22 AM
    redryder
    Ryder
    Louisiana
  22. May 13, 2019 at 5:45 AM
    CMB
    CMB New Member
    Cecil County MD.
    You'll be good to go. Before I bought my Bestop Step, I made sure it wasn't a knock-off of the one from Amp Research, they both operate the same. The only difference is the size of the step-surface/shape and price.
  23. May 13, 2019 at 7:08 AM
    AZTundra
    Paul
    Phoenix, AZ
    I second the opinion to cut out the metal bracket. I've got the AMP Research model and fought the metal bracket for quite some time (couldn't get the right angle to pull it out). Ended up using the sawzall to cut it into smaller pieces to remove it. I try to follow the directions exactly and this was one of those scenarios where I had to go to my own method for removal. Aside from swapping the metal bracket with the AMP one install was pretty easy and straight forward.
  24. May 19, 2019 at 5:45 AM
    redryder
    Ryder
    Louisiana
    Cut the bracket. The installation was a breeze after that.
    YardBird, Rica25, JoshuaA and 2 others like this.
  25. May 19, 2019 at 6:18 AM
    CMB
    CMB New Member
    Cecil County MD.
    Second Gen's may not have a bracket in the way. There wasn't one on my 2010. :thumbsup:
  26. May 19, 2019 at 9:32 AM
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Same!
    Rica25 likes this.
  27. May 19, 2019 at 10:54 AM
    CMB
    CMB New Member
    Cecil County MD.
    I love my bed- step. It's the Bestop Step. It kind of goes out at an angle from the rear bumper. It works great to step up on the tailgate. There's only one way t install it. Definitely recommend.:devil:
  28. May 21, 2019 at 7:14 AM
    shhernandez74
    Samuel
    Yup, i did not know how much i needed it until I installed mine!
  29. May 21, 2019 at 12:11 PM
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    I bought my bestop from Amazon in “opened box” condition for $75 shipped. Box was barely damaged and everything else was like new.
  30. May 22, 2019 at 10:30 AM
    redryder
    Ryder
    Louisiana
    Damn, and I thought I was getting a decent deal for 160 shipped.
