Bed rail tie downs
Discussion in '1st Gen Tundras (2000-2006)' started by jacklduffy, Jun 22, 2018.
  1. Jun 22, 2018 at 5:14 PM
    jacklduffy
    jacklduffy [OP] New Member
    Jack
    05 Tundra Limited Crewcab Phantom Gray 4x4
    K&N air filter, Flowmaster
    So far the only thing I don’t like about my 05 double cab is the lack of tie down options for the bed rails.
    Anyone have any good suggestions?
  2. Jun 23, 2018 at 8:43 AM
    Professional Hand Model
    Hand Protectors
    I’ve been using a system to two fixed non stretching cords/ropes running from front to back that are hooked to the factory loops mounted on the front and back of truck bed. Those cords have a bit of slack (not much) and allow the use of the rubber bunges to hook a across onto each cord/rope depending on your cargo size. Its scalable and modular without much weigh/cost and/or drilling into your bed.
    NomadicFrog likes this.
  3. Jun 23, 2018 at 9:44 AM
    NomadicFrog
    NomadicFrog New Member
    Mark
    Tempe, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    Gaffer tape over door lock/unlock beeper.
    I have temporarily arrived at the same solution. I also tried to do the cool Unistrut mod, but discovered that the first gens don't have the mounting holes necessary. Here's my "progress" on that, so far. The next time I get around to removing the camper shell I'll drill some holes in the top of the bed side and try again to mount my DIY unistrut rails.
  4. Jun 23, 2018 at 10:43 AM
    Hand Protectors
    That adhesive you asked me about, which I have not forgotten, is the Liquid Nails ‘Fuze It’. You’d be fine drilling new holes for the uni-strut with that adhesive as a sealant. That uni mod looks cool and has its purpose, but I have found the modular bunge system is best.
  5. Jun 23, 2018 at 12:19 PM
    jacklduffy
    Jack
    I’ll have to look into some of these options, you can’t get anything for the stake pockets because of those stupid caps!!
