Bed light wiring blues
Discussion in '2.5 Gen Tundras (2014-2021)' started by BigSwole, Feb 9, 2020.
  1. Feb 9, 2020 at 11:01 AM
    BigSwole
    BigSwole [OP] New Member
    Tony
    2014 Tundra limited
    Hi all, Im working on 2014 Crew Max I started my led tail light wiring this weekend and it is wearing me out due to me not being able to find cargo light wire in driver or driver side rear sil/scuff plate. I've seen post about pink, puke, purple or black thin wire but this is whooping my a$$. Any assistance would be welcomed and appreciated.
  2. Feb 9, 2020 at 11:11 AM
    biebs96
    PA
    Driver side front sill
  3. Feb 9, 2020 at 11:19 AM
    BigSwole
    Tony
    2014 Tundra limited
    Thanks biebs96, I'll go out and give it another shot. Can you tell me where you exited the cab to tie in to light wires?
  4. Feb 9, 2020 at 11:27 AM
    biebs96
    PA
    Under the carpet about six inches in from that wire loom is a rubber grommet that exits right above the frame rail and gives plenty of places to tie the wires up and out of the way
  5. Feb 9, 2020 at 1:22 PM
    BigSwole
    Tony
    2014 Tundra limited
    I've been at it for a couple of hours now and I cant get a positive reaction from my test light on any of these wire .
  6. Feb 9, 2020 at 1:55 PM
    BigSwole
    Tony
    2014 Tundra limited
    Snap on 12volt test light along with power probe .
  7. Feb 9, 2020 at 2:29 PM
    biebs96
    PA
    Make sure the dash switch is turned to on or door!!
    I can confirm the wire I sent you works as it’s been working on mine for months
    BigSwole[OP] likes this.
  8. Feb 9, 2020 at 2:35 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I would go to the multiple wire harnesses’ that are located behind the kick panel next to parking brake, just upstream from where you’re working now. Unhook each harness, one at a time, turning the cargo light on and off, until cargo light fails to turn on, that will narrow down which harness the cargo wire is in. Next, with the harness still unplugged, use your meter to figure out which wire is on/off (hot/cold) by putting the red tip inside each pin hole and grounding the other to bare metal (very important you have a good ground) while turning the cargo light switch on/off.
    Desert4673 and Toyotoholic like this.
  9. Feb 9, 2020 at 3:10 PM
    biebs96
    PA
    Pretty sure you had it here.
    I’d test it with the actually bed light.
    And make sure you have a solid ground as previously stated.
  10. Feb 9, 2020 at 5:21 PM
    BigSwole
    Tony
    2014 Tundra limited
    Like a ROOKIE the switch was in off. Please accept my apologies also thanks for all of your help during my bone head adventure. I have confirmed that the wire that you and Ron specified is in fact working just like it supposed to. Again thanks
  11. Feb 9, 2020 at 5:44 PM
    biebs96
    PA
    Awesome!!
    What bed lights did you end up using?
  12. Feb 9, 2020 at 6:01 PM
    BigSwole
    Tony
    2014 Tundra limited
    I got the Xprite LEDs. I'll post pics when I wrap it up. I also just installed the pop&lock tailgate and after I realized my goof on the cargo switch I noticed that I didn't run pop& lock wire down passenger frame rail as careful as I should( avoiding heat shields) So I re configured and secured.
    NewImprovedRon likes this.
  13. Feb 9, 2020 at 6:14 PM
    biebs96
    PA
    You’re going to love bed LEDs!
    I did bed lights...
    then running board lights...
    A9A1AB6C-D7FF-463C-B2F5-AAD0DDEA7D53.jpg 903FF243-DABE-4AC6-8272-57D2236DD99C.jpg
    then trailer hitch lights...
    then footwell lights...
    then under hood lights...
    and grill lights...
    Be careful, it’s contagious!
    I’m (Sorry for hijacking!)
  14. Feb 9, 2020 at 6:39 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I like that grille lighting!
    Nice original idea, great to see something different.
    biebs96[QUOTED] likes this.
  15. Feb 9, 2020 at 6:44 PM
    biebs96
    PA
    Thanks! It only lights up with the lock/unlock so its a brief but smile-worthy thing to see when walking out of work every night.
    Toyotoholic[QUOTED] likes this.
  16. Feb 9, 2020 at 7:52 PM
    TXTundra2722
    2015 Black Tundra
    What brand/ kind of lights did you use at these different locations... or is it in a build thread?
  17. Feb 9, 2020 at 8:00 PM
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    Did you add an additional relay and/ or in-line fuse for the bed lights?
  18. Feb 10, 2020 at 3:20 AM
    BigSwole
    Tony
    2014 Tundra limited
    No I haven't.
  19. Feb 10, 2020 at 7:36 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Same question but on a 2019 Platinum...which wire in that loom do I need to tap? (*Thanks for the rookie lesson - will DEF keep that in mind!)
  20. Feb 10, 2020 at 7:51 AM
    BigSwole
    Tony
    2014 Tundra limited
    I think our model years are different everything I've researched said 2014 -2018 so one of my fellow GURUS will chime in.
    bmann7[QUOTED] likes this.
  21. Feb 10, 2020 at 7:12 PM
    biebs96
    PA
  22. Feb 10, 2020 at 8:32 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I used the OEM bed lights on my 2014.
    Here are the instructions, including wiring instructions.
    It may differ on later year models.
    http://toyotaparts.sparkstoyota.com/install/00016-34089_2018_tundra.pdf
    I used Posi-taps instead of T-taps.
    But with the small OEM wiring, you need to make sure the Posi-taps get seated and make the connection before putting everything back together.
    bmann7 likes this.
  23. Feb 10, 2020 at 9:37 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
