Bed hop, has anyone found a solution?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Superbrad, Nov 16, 2018.
  1. Dec 1, 2018 at 7:23 AM
    #121
    Rob371
    Rob371 New Member
    Rob
    Charlevoix, Michigan
    2007 Tundra Crewmax
    Steel bumpers front and rear,1.4" bilstien, KatSkinz Leather, rear airbags, halos.
    I talked to dealer back when I purchased the truck used. I think the tsb you refer to is the one that replaced rear cab mounts, basically to dampen the feel of bed bounce. Didn't make sense to me at the time. Sounded more like a hide the problem fix rather than a fix the problem fix. I don't notice it anymore with changes I've made to my truck. Not sure if it's a combination or one specific thing. 5200s at 1.4 inch in front and steel bumpers installed at same time. Air lift airbags added later. Suspension otherwise is stock. Tires are OE recommended size.
    As far as advertised mileage, all my buddies get similar mileage in their dodges, chevys, fords. The ford ecoboost does pretty good on gas. I drove a 2015 F150 crew cab for a month (yes a month, that's another story) while my truck was in body shop for deer damage. I think it had a 4.6 or something, a smaller v8 anyway. Was decent on fuel, higher teens most of the time with my short trip driving. It rode really stiff though. Rear end would hop if hitting bumps around corners or curves. If you read the ultra fine print on Tundra advertised mileage I'm pretty sure it says "down a hill with a stiff tailwind"
  2. Dec 1, 2018 at 8:00 AM
    #122
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    This thread is hilarious.
    We have a 1 mile or so concrete section of I5 between two Ridgefield WA exits.
    The section is very noticeable (like, annoys the shit out of my kids and wife) in the Tundra, not at all noticeable in the Lexus (car) or wife’s Pathfinder.
    BUT - my old 1 Ton long bed GM Duramax, was 5X shittier than the Tundra!! It was so Fing bad in the Duramax you couldn’t even talk to each other because your inards were being shaken up like a banana in a blender.
    Rica25, papasmurf and rodm1 like this.
  3. Dec 2, 2018 at 6:11 PM
    #123
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Roadmaster active suspension really buttoned down my rear end..... Reduced axle hop, increased load capacity. Have been using for years in various trucks.
  4. Dec 2, 2018 at 6:30 PM
    #124
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    How would suspension increase load capacity? After all, something like bags only keeps your ass end from sagging and from riding your bump stops under load, it doesn’t increase payload or towing.
  5. Dec 3, 2018 at 8:55 AM
    #125
    Bulldog9
    NOVA
    Check out the Roadmaster active suspension website. There are several videos that explain what the active helper springs do.
    First put them on my father's truck about 20 years ago. He had a Silverado and used it to tow a horse trailer as well as a boat trailer. Because neither of us liked the air spring or adding leaf springs or air shocks solutions, we found these and they made a dramatic improvement not only in reducing sag but also improve the tracking and handling stability and almost eliminated axle hop. The other thing I like is you have the ability to adjust the helper spring rate in tune it to your load ccarrying needs.
    First thing we did was add a set to his newest truck with the same improvements, and I added a set to my TRD Pro when I bought it last year.
    On the stock setting, the RAS Springs give about a half inch lift to the rear and if I recall correctly increase capacity by 1500 lb. not suggesting this increases the GVW of the vehicle, just the standard suspensions ability to carry a load with a much reduced or eliminated squat. The half inch of lift reduced the basic nose up stance of the TRD Pro. as you know the TRD Pro has a 2 inch lift in the front which over levels the truck making the front a little higher than the rear. The RAs system on the standard setting brought the rear up so that it actually is equal to if not a little higher than the front.
    But the biggest benefit of the RAS Springs is the stability it provides to the rear of the truck.
    https://activesuspension.com/suspension-kits/
    WrigglingWilly and ryanwgregg like this.
  6. Dec 3, 2018 at 9:12 AM
    #126
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    It's a truck and designed to carry a load in the bed. The light ass end is what causes the bed hop. You can add some wright to it which will help in snow, get some lighter springs and lower your weight capacity, or last buy a car.
    rodm1 and WrigglingWilly like this.
  7. Dec 3, 2018 at 9:23 AM
    #127
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  8. Dec 7, 2018 at 9:41 PM
    #128
    fairclothr1
    fairclothr1 Here and There Member
    Ryan
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    Got the bushings in worked out well. Haven't tried on a concrete road yet but should tomorrow
    Also, @Coachbuilder1 thanks for the extra fish in the package! :thumbsup:
  9. Dec 7, 2018 at 9:45 PM
    #129
    fairclothr1
    Ryan
  10. Dec 8, 2018 at 3:02 AM
    #130
    Steve6
    Steve6 New Member
    Tucson
    The spare tire trick has potential. In for interest in the outcome.
  11. Dec 8, 2018 at 5:15 AM
    #131
    Bulldog9
    NOVA
    Here's a fun and interesting video showing the comparison between a Ford Chevy and the tundra on bed bounce. I've noticed that all the videos were the pre 2014 body style. Did Toyota make any changes? That bed shake is gnarly. I wonder how a cap or bed camper would fare? Looks to me like it would be twisted apart.
    https://youtu.be/EWjTbiYo3x0
  12. Dec 8, 2018 at 9:16 AM
    #132
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    Pretty sure the only way to really eliminate this would be boxing the rear frame and or adding some sort of frame support. C channel frame is made to absorb and flex for comfort.
    Rica25 likes this.
  13. Dec 8, 2018 at 4:26 PM
    #133
    Bulldog9
    NOVA
    Found out that they did do a major upgrade to the frame in 2010, but is intentionally flexible for ride quality and comfort. Flex looks ugly, but is designed this way.
    Rica25 likes this.
  14. Dec 8, 2018 at 6:09 PM
    #134
    Rica25
    Ricardo
    Tulare
    I dont think that's true my Truck is an 08 my uncle has 2011 or 2012 and they ride the same when they were stock but now mine rides better since he doesn't really do any upgrades
  15. Dec 9, 2018 at 5:41 AM
    #135
    Bulldog9
    NOVA
    I'll have to find the article, they talked about some extra supports at the rear of the bed and frame, seems that it was the 07 year that was the worst.
    Rica25[QUOTED] likes this.
  16. Dec 9, 2018 at 5:49 AM
    #136
    Rica25
    Ricardo
    Tulare
    The only changes they made were the bed bushings I'll find a pic
  17. Dec 9, 2018 at 5:51 AM
    #137
    Rica25
    Ricardo
    Tulare
  18. Dec 9, 2018 at 5:51 AM
    #138
    Rica25
    Ricardo
    Tulare
    I did this fix back in 2012 to mine helped but didn't go away
  19. Dec 10, 2018 at 7:53 AM
    #139
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    AND.......
    Rica25 likes this.
  20. Dec 10, 2018 at 8:17 AM
    #140
    fairclothr1
    Ryan
    Sorry, got busy yesterday. Went on a stretch of road that has bounced fairly well at 65-70mph yesterday, and, maybe a little better, but definitely not gone. After a quick check for police, took it up to 80 and was nearly gone, but, didn't need to chat with a LEO, so, was very short testing that. I drive to IA on Christmas and will see how it will do on I-76 and I-80. I also added another sandbag, so now have 4x70lbs bags. It's all I can do for a grand total of $70 (sandbags were ~$20, plus the bushings).
  21. Dec 11, 2018 at 7:41 AM
    #141
    WrigglingWilly
    LineX
    I was just having a thought. If we only had a way to add 300#s of weight that could be mounted into the hitch reciever, the bed would remain fully useable! My Tundra rides best with a trailer, so that was my inspiration for this idea.
  22. Dec 11, 2018 at 11:07 AM
    #142
    Uncle_Charlie
    Uncle_Charlie New Member
    2018 Tundra- Work truck package
    Maybe an auxiliary gas tank. Would solve two problems with one mod. You can't see it, but my tongue is firmly planted in me cheek.
  23. Dec 11, 2018 at 11:26 AM
    #143
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    agreed...ive just accepted it at this point lol. Worst part is, after I read this damn thread....Now I REALLY notice it:crazy:
  24. Dec 11, 2018 at 11:43 AM
    #144
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    turn up the music and go fast LOL
  25. Dec 11, 2018 at 11:45 AM
    #145
    Erichudgins
    Eric
    Murfreesboro, TN
    Wait.... that's how I fix everything:anonymous:
    Rica25 and papasmurf[QUOTED] like this.
  26. Dec 11, 2018 at 11:48 AM
    #146
    15whtrd
    15whtrd Mr. Blonde
    Lead bars take up less space then sandbags. Just start stuffing them in any location you can LOL
    Rica25 likes this.
  27. Dec 11, 2018 at 1:56 PM
    #147
    L3TT3RS
    L3TT3RS New Member
    Taylor
    19 Tundra
    Fox/Total Chaos/Coachbuilder
    The c channel frame is designed to flex to provide a better ride. The only real solution to eliminating the tundra butt is to reinforce the frame to help prevent torsional rotation. Is it annoying? Yes. Is it detrimental to the vehicle with daily driving and mild offroading? No. If you are doing. Heavy offroading, you may consider getting some cross bracing for the frame and or making it completely boxed. With cross bracing.
    Rica25 likes this.
  28. Dec 11, 2018 at 2:40 PM
    #148
    15whtrd
    15whtrd Mr. Blonde
    Even then I think it will still bounce. I think it’s more about the wheel base. My friend has a 2005 SRT 10 ram. The frame is fully boxed and it does it on sections of the freeway as well. Boxing the frame would help with ass wobble but not bed bounce. Imo
  29. Dec 11, 2018 at 2:51 PM
    #149
    L3TT3RS
    L3TT3RS New Member
    Taylor
    19 Tundra
    I must be missing something then I was thinking bed bounce and ass wobble were the same thing.
  30. Dec 11, 2018 at 2:54 PM
    #150
    15whtrd
    15whtrd Mr. Blonde
    No this is more of a front to back bucking. Almost the feeling of an unbalanced trailer that feels like it’s tugging at you and bouncing your truck. The assed wobble is just flex. Some have flexed it enough to create problems though. A couple guys tore some of the sheet metal under the bed along the cross bracing. But they use the shit out of their rigs and many have RTT’s with bed racks.
