Bed hop, has anyone found a solution?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Superbrad, Nov 16, 2018.
  1. Nov 22, 2018 at 5:41 AM
    #91
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The bed on my '07 RCSB bounced pretty bad when I purchased it last year, I expected some bounce because of the short wheel base and empty bed.
    Among other things, I dropped the rear with an SOS flip-kit, added a rear sway bar and Air-lift bags. The bed no longer bounces, and the ride is smooth & predictable.
    Rica25 likes this.
  2. Nov 22, 2018 at 11:47 AM
    #92
    cdmagor
    cdmagor @tundra4by4
    Clayton
    Denver Colorado
    2017 Tundra
    Toytec 3/1 Eibach Lift Coachbuilder +2 Shackels 285/75/18 Nitto Tires Method Racing Wheels
    Rent a ball joint press, all the shops have them and return all your money when you bring it back. It will be much more helpful than those cheap pullers. Might have to use a socket if the press doesn’t have the right size.
    Rica25[QUOTED] likes this.
  3. Nov 22, 2018 at 11:57 AM
    #93
    cdmagor
    cdmagor @tundra4by4
    Clayton
    Denver Colorado
    2017 Tundra
    Hey man, I’m in Denver as well and know exactly what you’re talking about. Especially cement highways. I experienced this with my stock setup, my lift with 1” rear blocks and my lift with toytec shackles.
    I finally found the solution. @Coachbuilder1 shackles. I put the +2’s on mine since I have a lift but if you don’t have a lift the +1 would help tremendously. I hated going over 65mph before I got these and now no matter the speed or terrain it’s such a nice riding truck.
    @Coachbuilder1 put a video together for how to install them https://youtu.be/zmJ6Xjjtpe8.
    Coachbuilder bushings help as well, which come with the shackles. Use a ball joint press to get the factory ones out.
    I know toytec is slightly cheaper but I promise you will be happier going with Coachbuilder. It will be the best $285 you spend. The toytec shackles are the same ones they use for the older Tacoma’s... I just don’t think they’re made for a big truck like a Tundra and honestly no better than stock.
    Please reach out to me with any questions. I know how annoying bed bounce can be. It was such a relief when I drove my truck after putting the Coachbuilder shackles on.
    Here’s the link https://www.shopcoachbuilder.com/products/coachbuilder-1-shackles-provides-625-of-actual-lift
  4. Nov 22, 2018 at 2:12 PM
    #94
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    25 in castle rock does suck but 285 thru Indian hills is the worst. Curious what everyone that is experiencing this has for shocks. I have a grade model, so the black shocks. A friend is going to give me an extra set of bilsteins that he has, I'll let you.know if it improves. I'm in the same boat of I cant do lift shackles as it's a working and towing truck.
    Btw, a loaded car trailer does not make it any better:eek:
    Superbrad[OP] and Rica25 like this.
  5. Nov 22, 2018 at 11:12 PM
    #95
    cdmagor
    cdmagor @tundra4by4
    Clayton
    Denver Colorado
    2017 Tundra
    In my opinion shocks only do so much for the rear suspension, especially preventing bed bounce. Leaf springs are the biggest factor.
    The +1 Coachbuilder shackles would greatly improve your ride quality. They will only lift your rear end a hair over a 1/2 inch. If you tow a lot, even a better reason to add bigger shackles. I towed today for the first time since I added mine and it made a huge difference.
  6. Nov 23, 2018 at 8:21 AM
    #96
    nuclearlemon
    wyoming
    2012 dc
    has anyone used poly bushings with stock shackles and springs? the bushings i've seen all say they only fit with lift springs (different eye size maybe???), but i've only begun my research there.
    Rica25 likes this.
  7. Nov 23, 2018 at 9:45 AM
    #97
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    I've installed the coach builder bushings with stock shackles and it certainly reduced the rear end hop and shuddering post bump. Like others I don't want any lift which is why I avoided the shackles. For the time and money it was a worthwhile upgrade for me.
    Hope this helps.
    Rica25 and nuclearlemon[QUOTED] like this.
  8. Nov 23, 2018 at 9:55 AM
    #98
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    The shackles come with a carrier bearing drop kit which lowers that. I believe this is what you are talking about. @Coachbuilder1
    Rica25 likes this.
  9. Nov 23, 2018 at 10:46 AM
    #99
    Rob371
    Rob371 New Member
    Rob
    Charlevoix, Michigan
    2007 Tundra Crewmax
    Steel bumpers front and rear,1.4" bilstien, KatSkinz Leather, rear airbags, halos.
    My 2007 Crewmax does it as well. Only on certain roads though. I haven't really noticed it in a while. I've put the bilstein 5200s up front at 1.4" setting, added steel bumpers front and rear all at the same time two years ago. I don't remember noticing it after that. I have added air bags this past summer. Not sure if one or all things combined effected it. The Toyota fix was replace rear cab mounts with a superseded part but I never did it. I thought Toyota had corrected this on later models but it sounds like they didn't.
    Rica25 likes this.
  10. Nov 26, 2018 at 11:59 AM
    #100
    fairclothr1
    fairclothr1 Here and There Member
    Ryan
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    @Coachbuilder1 Am I able to just buy bushings and swap the stock bushings? If so, is that one of the sets at ~$50?
  11. Nov 27, 2018 at 8:24 AM
    #101
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Yes, All though our poly bushing kit is specifically designed to work with our shackles we've had many just upgrade the rear eyelet bushings. this provides a smoother pivot but does not address the other faults in the suspension. We worked hand in hand with the engineers at Energy Suspensions in order to not only come up with the correct compound but the over all profile.
    https://shop-coachbuilder.myshopify...urethane-bushing-kit-rear-leaf-spring-eyelets
  12. Nov 27, 2018 at 8:26 AM
    #102
    fairclothr1
    Ryan
    Thanks! Just looking at what I could possibly talk the wife into letting me purchase this close to the holidays. $50 is easier to sell than nearly $300. :thumbsup:
    Coachbuilder1[QUOTED] likes this.
  13. Nov 27, 2018 at 8:45 AM
    #103
    power80
    power80 New Member
    2018 Tundra Crewmax Limited 4x4
    I've never had an issue. However, my rig came with the TRD rear stabilizer bar. I added the Coachbuilder shackles, but not because of bed hop. Perhaps the stabilizer bar will help?
    Rica25 likes this.
  14. Nov 27, 2018 at 11:54 AM
    #104
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I have a 2007 CM TRD that experiences bed hop pretty bad. I also have a 2014 DC with a canopy and sway bar and it still has bed hop, but not nearly as bad.
    Rica25 likes this.
  15. Nov 27, 2018 at 2:32 PM
    #105
    nuclearlemon
    wyoming
    2012 dc
    nope. i added one. didn't seem to make a difference
  16. Nov 28, 2018 at 6:53 AM
    #106
    fairclothr1
    Ryan
    Just ordered the bushings. Hoping it will at least make a small difference. Can look at the shackles down the road a bit. I know I have to press the old ones out, but, do you have a video or tutorial on how to properly put your bushings in? They look like they are 2 pieces per eyelet, and maybe have a collar? Cheers!
  17. Nov 28, 2018 at 7:10 AM
    #107
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Put 600 pounds in the Bed. I have the 8.1 bed on a 2018 SR. I avoid the 25 through Denver. The slabs of concrete are poured at just the right width and the slabs are just heaved enough that the Tundra starts to bounce. Weight is the only thing that helps without mods. With only a 1600# weight cap in the bed, I did not foresee an issue like this. Rest assured, that piece of road feels bad in my 2011 Regular cab Tacoma, as well. Northbound more than south.
    BTBAKER and Superbrad[OP] like this.
  18. Nov 28, 2018 at 7:36 AM
    #108
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    CM’s generally don’t have near the issue with bed bounce that DC’s do, wouldn’t surprise me if the sway bar was helping you.
  19. Nov 28, 2018 at 7:41 AM
    #109
    WrigglingWilly
    LineX
    With mine, the bounce is all four corners, not just the back wheels. The WHOLE truck bounces down the I25!
    BTBAKER and Rica25 like this.
  20. Nov 28, 2018 at 8:39 AM
    #110
    fairclothr1
    Ryan
    Your wheelbase is even longer than my DC with the standard 6.5' bed. I thought it was more in the range of the DC wheelbase. My buddies Titan is a similar wheelbase and he has bed bounce too.
  21. Nov 28, 2018 at 8:45 AM
    #111
    WrigglingWilly
    LineX
    If I am on Blacktop, not poured concrete, the Tundra rides like a Cadillac. At all speeds. Even other poured concrete highways, like the I70, or the 25 south of Denver, no issues at all. It is that one stretch of the 25, and a couple select sections on the c-470. I say the road is defective, not the truck! It was so bad by the Ikea by Greenwood Village, they just put down blacktop instead of fixing the new concrete. On a 12 lane freeway! Asphalt! The contractor in charge of that project must have goofed big time for a fix that temporary to be needed.
  22. Nov 28, 2018 at 10:48 AM
    #112
    Coachbuilder1
    David
    Salt Lake City UT
    Thank you for your order..
    A day or 2 before installing spray each side of the rear leaf spring eyelets with Zep or PB blaster anything to get them wet. Then using a ball joint press tool ( Can be borrowed from Advance Auto parts or Autozone ) you'l be able to push the OE bushings out. Be sure to remove your spare tire before removing your factory shackles and lower the rear axle down away from the frame rails. Our Poly bushing kit will install very easily and will see a full write along with tips highlighted in our install guide. This will be in with your parts. Please follow up if you need an hand with anything else.
    I found this general video using the Ball joint press tool and should help,
    https://www.youtube.com/watch?v=GkcKOBUx2KU
  23. Nov 28, 2018 at 12:01 PM
    #113
    nuclearlemon
    wyoming
    2012 dc
    mine should be here friday...crossing my fingers it helps at least some ;)
    Rica25 and Coachbuilder1 like this.
  24. Nov 28, 2018 at 12:42 PM
    #114
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    this thread is funny..
    ive spent 10k on 16" 3.0 triple bypass shocks, Deaver SUA custom leafs, a bed cage, air bumps and more... and guess what I still have .. you guessed it bed bounce...
    there are mitigation strategies for it to reduce feel and effects, but harmonics in freeways, wheelbase, frame design and suspension geometry all play into it as factors, yes leafs, shocks and other parts may reduce the feel of it, but it will happen regardless maybe to a lesser extent or less noticeable effect. There is a TSB for 07-10 Double cabs, but im not sure how well the "fix" actually helps
    Its just the nature of the tundra. Just like the damn gas milage convo. Its a 5.7 liter 1/2 ton gas truck that weights 6500lbs... its not going to get prius milage and if you believe the epa sticker #'s i also have some ocean front beach property in Arizona to sell you...
    Erichudgins, Rica25, joonbug and 5 others like this.
  25. Nov 28, 2018 at 1:07 PM
    #115
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
  26. Nov 28, 2018 at 1:10 PM
    #116
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
  27. Nov 28, 2018 at 1:23 PM
    #117
    15whtrd
    15whtrd Mr. Blonde
    Must be the difference in weight over the rear tires. Because I was pretty sure they are the same wheel base.
    zcarpenter92[QUOTED] likes this.
  28. Nov 28, 2018 at 1:29 PM
    #118
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I noticed it happening on mine after I lifted it with a add a leaf. But only on certain stretches of concrete highways.
    Rica25 likes this.
  29. Nov 28, 2018 at 1:48 PM
    #119
    zcarpenter92
    Zach
    NE Colorado
    In sig
    That wouldn’t surprise me one bit on weight over tires, the DC’s would have their weight more over the front.
    15whtrd[QUOTED] likes this.
  30. Nov 29, 2018 at 1:12 PM
    #120
    SV373
    SV373 New Member
    Chuck
    2017 4WD CM Tundra
    My 2017 CM TRD is plagued with bed bounce on concrete highways as well. It was annoying with the original 275/65-18 tires. I just upgraded to a 285/65-18 e rated tire and it is absolutely terrible now. Seeking the best solution to at least reduce it to a tolerable level.
    Suspension is stock TRD with no rear sway bar. I am considering spring bushing and rear shock upgrade myself.
    WrigglingWilly likes this.
