Bed hop, has anyone found a solution?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Superbrad, Nov 16, 2018.
  1. Nov 19, 2018 at 2:13 PM
    fairclothr1
    fairclothr1 Here and There Member
    Ryan
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    Castle Rock is THE WORST!!! My buddy has a mid-00s Titan and he says the same thing. His is an extended cab, so would likely be a similar wheelbase as we have in our DC Tundras. I had heard maybe Coachbuilder shackles and upgraded Bilsteins would help, but, your experience would say otherwise... I am heading to IA the end of December and I know they have some stretches or I76 and I80 that are now concrete. Really wanting to take my Tundra, not our 4Runner. I have 110k less miles on my truck...
    Grumpy Uncle likes this.
  2. Nov 19, 2018 at 2:22 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Glad I wasn’t imagining the bed bounce with certain types of pavement. Mine did seem to get a little better overall with the addition of the poly bushings on the Toytec shackles, but it’s still aggravating in places. I about lost my mind on highway 24 from Limon to the Springs a few months back it was so bad. I wonder if certain types of pavement don’t gyrate the leaves and make the main springs bounce off of the overloads more aggressively.
    Also, welcome from Burlington and check out the Colorado BS thread!
  3. Nov 19, 2018 at 2:32 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thank you for the mention Rica25
    Superbrad Im a Tundra Owner too and know exactly what you're talking about, We have the same great concrete highways over there in Utah and feel your pain :) lol
    Many have asked about bed bounce and why their tundras feel so restricted or loose in the rear. This is our Specialty.... Over the years we've been able to dial in our Shackle Design as well as the Bushing Profile and compound in the rear leaf spring eyelets. Allowing the rear suspension to cycle extremely smooth yet very controlled. Our Coachbuilder shackles will not only provide Amazing ride quality but added strength, Eliminate side to side flex, You'll get the amount of lift you're wanting ( +1"s .625" ) ( +2"s 1.25" ) ( +3"s 1.75" ) all while transferring the power down to the ground.
    https://shop-coachbuilder.myshopify...uilder-1-shackles-provides-625-of-actual-lift
    https://shop-coachbuilder.myshopify...ilder-2-shackles-provides-1-25-of-actual-lift
    https://shop-coachbuilder.myshopify...ilder-3-shackles-provides-1-75-of-actual-lift
    Big J, 15whtrd and Rica25[QUOTED] like this.
  4. Nov 19, 2018 at 2:35 PM
    fairclothr1
    Ryan
    As one that isn't currently interested in any lift, do you guys have any that don't lift the rear and leave it at the stock height? Thanks!
    snarkscarbine and wyone like this.
  5. Nov 19, 2018 at 2:41 PM
    Professional Hand Model
    Hand Protectors
    Rica25 likes this.
  6. Nov 19, 2018 at 2:51 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Unfortunately no.. Our Smallest or shortest shackle is our +1"s. they are just short enough we're able to fit a solid cross brace in without sacrificing functionality.
    If you have a floor jack you can see what they would look like installed.
    Park on a flat level surface and pull a measurement from the center of the wheel openings down to the ground.. if your truck is stock it should measure 39"-39.25"
    using your floor jack raise the rear by jacking up on the trucks tow hitch .625". this will provide a mirror image for you.
    Rica25 and fairclothr1[QUOTED] like this.
  7. Nov 20, 2018 at 7:27 AM
    Superbrad
    Superbrad [OP] New Member
    Brad
    2018 Tundra SR 5.7 4x4 long-bed White
    Interesting idea, seems a bit far fetched but maybe worth a shot. I’d love to hear from any Colorado members who have switched to higher end rear shocks.
  8. Nov 20, 2018 at 8:01 AM
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Two things that I have done that helped a little bit are the trd rear sway bar and line-x the bed. Both helped slightly but didn’t make it go away completely.
    There’s also quite a few bed stiffeners out there that I feel would help, just haven’t tried one yet.
  9. Nov 20, 2018 at 8:05 AM
    Rica25
    Ricardo
    Tulare
    Coachbuilder is having a big sale on shackles he started the THREAD YESTERDAY*** Coachbuilder Shackles Group Buy ***
  10. Nov 20, 2018 at 8:08 AM
    Rica25
    Ricardo
    Tulare
  11. Nov 20, 2018 at 11:51 AM
    Superbrad
    Brad
    Please keep us posted!
    Rica25 likes this.
  12. Nov 20, 2018 at 12:02 PM
    Grumpy Uncle
    Pat
    CO
    Like some have said weight, once I had my topper install most of it went away. There are parts of I-25 that I still get a little bit, nowhere what it used to be.
  13. Nov 20, 2018 at 2:25 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    From everything I have read it is most likely the factory bushings. Coach builder shackles should eliminate the binding that occurs with factory ones. I plan to upgrade to his shackles even if I do a full on lift kit. Nothing ordered yet... saving up to do the whole thing all at once. (Shackles, shocks, rims, tires, etc.)
    Coachbuilder1 and Rica25 like this.
  14. Nov 20, 2018 at 2:32 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Let me know if you have any questions and will gladly help. We just posted up a group buy if the timing is right for you.
    Big J[QUOTED] likes this.
  15. Nov 20, 2018 at 2:42 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Adding thickness, cross bracing or boxing the frame should help I'd think
    Rica25 likes this.
  16. Nov 20, 2018 at 4:36 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Idk, even adding my 5th wheel hitch and suspension mods has not changed mine. It is weird and temps-load make a slight difference, but it is still there. Has to be the tri tech frame. That is my biggest complaint tho, and I will deal with the areas it happens for rock solid dependability.
  17. Nov 20, 2018 at 5:30 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    I blame the road. Got CB +3’s with Fox DSC in the rear. Excellent on pretty much everything except a few sections of freeway here in SoCal. I405N past the 101 is super shiti! California has some of the worst roads..
    Big J and Rica25 like this.
  18. Nov 20, 2018 at 5:38 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    And yet one of the most expensive places... lol
    Tax dollars hard at work o_O
    Tracy Perry, zcarpenter92 and Rica25 like this.
  19. Nov 20, 2018 at 5:39 PM
    #49
    Rica25
    Ricardo
    Tulare
    Agree bro .....live in central California myself
  20. Nov 20, 2018 at 5:54 PM
    #50
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I have fox 2.0 resi's in the rear and considering the CB shackles. How much improvement with the CB shackles?
  21. Nov 20, 2018 at 6:01 PM
    #51
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    Have you guys notice any difference between wheel/tire setup? Couple places in San Diego that have the bounce and I definitely noticed a difference of when I was running stock 18s steelies with Michelins and now running 20s with Dunlops.. Stock 18s barely noticed anything... Or maybe it's all in my mind
  22. Nov 20, 2018 at 6:01 PM
    #52
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Agreed (w/Sterling above). This is not unique to any region. For me it was almost exclusively the seamed stretches of interstate where I noticed it. Proof of that is when you're bouncing along whatever interstate and then you come to an overpass and it completely goes away for a brief stretch because the road surface changes. Sadly, you do get used to it. My kids even enjoyed it for brief stretches. I also noticed it was most pronounced between 70-75 mph. Different speeds made it stop, sometimes.
    I will say this, OP, you list "long-bed". Is that single or double cab? Curious because before my '18 CM I had a '14 DC long bed (yes, 8ft) and it was ten times more noticeable on that truck than on the 5.5 ft bed CM. Dealers and even forums didn't have a lot of answers, mostly because there are sooooo few Toyota trucks with a wheelbase that long so not a lot of folks are making noise about it. Feelin' your pain.
    Rica25 likes this.
  23. Nov 20, 2018 at 6:02 PM
    #53
    sdde4n
    sdde4n New Member
    15 north through Miramar was as bad as any I've experienced. I was stock TRD wheels and tires at that time.
  24. Nov 20, 2018 at 6:07 PM
    #54
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I live in CASTLE ROCK and drive that stretch daily!! I have honsestly considered unloading my truck it’s so bad.
    I’ve tried numerous things and nothing eliminates it. I have upgraded 6112/5160 suspension and it may have reduced it a little. Honestly, speed is the biggest difference maker for me. Once I get above 80 it seems to get out of its frequency range.
    I believe it’s the frame design. Let me know if you come up with anything and I’ll do the same.
    Rica25 likes this.
  25. Nov 20, 2018 at 6:07 PM
    #55
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Definitely improved with the poly bushings. If you are considering going in on the GB for CB it’s worth it.
    Rica25 likes this.
  26. Nov 20, 2018 at 6:08 PM
    #56
    Rica25
    Ricardo
    Tulare
    Just paid for mine and can't wait to get them installed and test it out
    BTBAKER likes this.
  27. Nov 20, 2018 at 6:08 PM
    #57
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I may give Toytec a call. They are local and may have an upgrade that will reduce the bounce.
    Rica25 likes this.
  28. Nov 20, 2018 at 6:56 PM
    #58
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Will these shackles reduce/eliminate bed bounce?
    Rica25 likes this.
  29. Nov 20, 2018 at 7:00 PM
    #59
    Rica25
    Ricardo
    Tulare
    I will be giving it a try ......I've read a few people that say due to polyurethane bushing that will swivel with shackle they seem to help some
    BTBAKER[QUOTED] likes this.
  30. Nov 20, 2018 at 7:03 PM
    #60
    Welcome from Aurora. It's not just the shackles that fixes bounce. It's replacing the OEM bullshit bushings and replacing with poly bushings. Check out ToyTec shackles and poly bushings. Nuke proof and adjustable from 1" to 1.5".
    Hoologan, Rica25 and BTBAKER like this.
