Bed Divider question w/ tri-fold Tonneau cover
Discussion in '2.5 Gen Tundras (2014-2021)' started by GaFFLe, Sep 1, 2020.
  1. Sep 1, 2020 at 3:51 PM
    GaFFLe
    GaFFLe [OP] New Member
    Atlanta, GA
    2020 Toyota Tundra Platinum
    Undercover bed sway cases
  2. Sep 1, 2020 at 5:52 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I had saw off a few inches on each side to fit. The tonneau cover drain channel pushes the rails out shortening the width.
  3. Sep 2, 2020 at 8:58 AM
    GaFFLe
    Atlanta, GA
    Are you using the Toyota divider or some other brand?
  4. Sep 2, 2020 at 9:18 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    I had a bak-flip tonneau cover that was flush fit and the Toyota cargo divider. The only thing I had to do was flip the brackets that mount on the deck rails. That is - the knobs you see on top that hold the cargo divider, those were now on the bottom. Same function.
    Side note: I hated that cargo divider. If you are going to leave it in one place, it isn't that bad. If you want to move it around, you have to loosen all four knobs, then beat it around with your hand as it roughly slides a couple inches one side at a time until you get it where you want it. Sometimes you can get lucky and get about a foot of movement if both of your arms are timed exactly right with the same pressure. :frusty:
  5. Sep 2, 2020 at 11:04 AM
    LKROOZR
    LKROOZR New Member
    Christian
    2017 Black Tundra Crewmax
    8" readylift on 37s
    I have the amp research bed extender with the bakflip mx4 tonneau cover.
  6. Sep 2, 2020 at 11:41 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I have the Toyota divider and Toyota tonneau cover. Like stated above. You need to flip the brackets so the knobs are facing down as well.
  7. Sep 3, 2020 at 6:20 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    How do you like the bed divider? worth the price?
  8. Sep 3, 2020 at 9:27 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    It’s worth it to me. I bring material to customer a lot. The times I only have a few 5gal buckets of chemicals and a few other items makes it easier. Also helps when going to Lowe’s to grab 5gal water and propane exchanges.
  9. Aug 30, 2021 at 8:23 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Resurrecting this thread. Looking at a bed cover and I plan to get the Toyota bed divider. Will this work with a retractable? Or do I have to use a trifold or roll up?
  10. Aug 30, 2021 at 8:37 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I believe it works with the retractable. With the trifold, the brackets push the rail out a little. You would just need to trim a little off both the divider ends to shorten it.
