Bed Bounce Fix?
Discussion in 'General Tundra Discussion' started by Rica25, Feb 24, 2018.
  1. May 21, 2022 at 7:13 AM
    #151
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I run I25 through Castle Rock daily and I agree with you. There’s speeds north of 80 that seem to quiet it down as well.
    DeesCrewMax likes this.
  2. May 21, 2022 at 7:52 AM
    #152
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    I swapped out my 5160 (rear shocks) for 2.0 fox r/r tuned by accutune. So far it seems to have reduced the bounce even with no weight in the bed (other than my topper). Ill check back when i have more road time. Im also waiting on 2.5 fronts with 500lb coils.
    Stats for completeness:
    18 crewmax sr5 (5.5 bed)
    E load bfg ko2 (285 75 17)
    6112 @ 1.9 + 1/4” shim on both sides
    1.25” shackles with poly bushings (bossoffroad?)
    Snugtop rebel
    Upcoming:
    Front shocks / coils
    New tires. Considering toyo at3 (maybe c load? Havent decided)
    BTBAKER likes this.
  3. May 21, 2022 at 1:05 PM
    #153
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    That stretch is the worst I've encountered. But since the weather has warmed up, it's almost unnoticeable.
    BTBAKER[QUOTED] likes this.
  4. May 21, 2022 at 5:32 PM
    #154
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    When I bolted on my P&P Engineering sliders they eliminated a good part of my bounce/kick.
    Skew12 and Terndrerrr like this.
  5. May 21, 2022 at 6:04 PM
    #155
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Adding substantial weight under the cab or to the bed will dampen it quite a bit.
    Skew12 likes this.
  6. May 23, 2022 at 9:50 AM
    #156
    COTundie
    Trey
    Pretty things
    Does anyone make electronically adjustable rear shocks for our Tundras?
    Wonder if we may be able to tune the bounce out with different shock valving to match the road conditions.?
  7. May 23, 2022 at 10:42 AM
    #157
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Anything that limits flame flex right behind the cab will help. Sliders makes total sense. You’re forcing the cycling action to stay in the springs more
    Skew12 likes this.
  8. Apr 12, 2023 at 4:42 PM
    #158
    RockyMountainTundra2012
    RockyMountainTundra2012 New Member
    Allen
    2012 Tundra CrewMax
    I got my 2012 Tundra CrewMax last August and it suffers from bed bounce, even with a LEER topper, Thule crossbars and large RhinoRack X Basket, and about 100 lbs of gear in the bed.
    I spent time really looking into this and seeing what others tried. Googling part numbers I discovered my shocks and struts are from Autozone.
    I ordered and installed Rancho RS9000XLs in the rear, and essentially the same for the front with Rancho quick lift struts. My truck has spacers front and rear and 35/12.50/20s on the factory BBS wheel package.
    I’ve only installed the rear shocks so far. Set to 1, nice cushy ride that eliminated 90% of the bounce on Colorado concrete freeways.
    I think greasable or pivoting/softer rear shackles would likely take care of the rest.
    I have never seen someone share the Rancho solution, so I thought I would bring this back from the dead.
    Skew12 and rruff like this.
  9. Apr 12, 2023 at 5:11 PM
    #159
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    That's weird because the black shocks have very little damping. Turn your Ranchos up the max and see what happens.
  10. Apr 12, 2023 at 5:13 PM
    #160
    Allen
    2012 Tundra CrewMax
    I did out of curiosity
    It was bed bounce times 100. It was physically uncomfortable, not just the annoyance it used to be. I can’t stress enough how bad it was
    And when you say black shocks, you mean the Autozone shocks? Because that is what was on my truck when I bought it
    rruff likes this.
  11. Apr 12, 2023 at 6:11 PM
    #161
    rruff
    rruff New Member
    My truck was insane on I25 south... this was right after I bought it, and heading home to NM! It was way beyond uncomfortable. It was like constant whiplash. I've notice it in ABQ but not nearly as bad... both with the black shocks and the IM FCPs. I think the longbed makes it worse.
  12. Apr 12, 2023 at 7:04 PM
    #162
    Allen
    2012 Tundra CrewMax
    I ride 285, 470, and 6th Ave mainly. Then I25 and I70. 285 has been the worst…
