BDS 7
Discussion in 'Suspension' started by mixwells, Jun 8, 2017.
  1. Jun 8, 2017 at 8:57 PM
    mixwells
    mixwells [OP] New Member
    Anyone running the BDS 7" with fox coilovers and 35" tires? If some let's hear some reviews, thanks in advance!
  2. Jun 9, 2017 at 5:21 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
  3. Jun 9, 2017 at 5:29 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    rockmup, SATC1, JAMES and 1 other person like this.
  4. Jun 9, 2017 at 5:39 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    I disagree....but to each their own
    GNTundra likes this.
  5. Jun 9, 2017 at 6:13 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I originally ordered had the 7" BDS kit with fox coil overs. I decided to sell the 7" BDS lift with and keep my fox coilovers. Only because I have other friends that had excessive tire wear with the 7" BDS lift. If your running 35" tires and not a crazy offset I don't see you having any issues though. BDS makes a great lift and they have lifetime warranties on all their stuff as well. If you go with the 7" BDS lift I would suggest you look into coachbuilder or Ekstrom Designs. He sells various components to help improve ride quality and performance. If you add shackles to your rear leaf springs it will help your ride quality a considerable amount. There are other parts suppliers for shackles as well. Changing your front steering ends can also help. Just depends how far you want to go with your lift. I hope this helps you with your decision.
    Jsena likes this.
  6. Jun 9, 2017 at 7:20 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    i actually just took my BDS kit off, and Im looking to sell it with Coachbuilder steering ends. if you are interested let me know, im letting it go for a fraction of new. i sold the coilovers and UCA's already but the entire bracket lift and spindles and CB tierods will be up for sale. I loved the kit, only reason i changed is Im going Long travel now so different direction with the truck
    bill70387, csuviper and Jsena like this.
  7. Jun 9, 2017 at 10:36 AM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    I got the BDS 7" with the Fox coilovers and 35's. I guess I should have asked the guys with smaller lifts the correct tire size I needed prior to installing.IMG_1099.jpgIMG_0934.jpgIMG_0969.jpg
    ARES, Bluering808, GNTundra and 2 others like this.
  8. Jun 9, 2017 at 10:38 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I might be
    Eclipsed & Floating likes this.
  9. Jun 9, 2017 at 10:38 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Pm me
  10. Jun 9, 2017 at 10:40 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    @Puud youbsee my message last night about your truck ?
  11. Jun 9, 2017 at 10:41 AM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    Na I didnt sorry
    Jsena[QUOTED] likes this.
  12. Jun 9, 2017 at 10:42 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    It's on your build page
  13. Jun 9, 2017 at 11:20 AM
    mixwells
    Well, what's your review, has the kit any problems? And the tires compared to stock, mpg, power loss, gear problems..... any input will help, thanks!
  14. Jun 9, 2017 at 11:39 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    I like it the way it is. 37's You gotta change gears for sure, you're gonna rub, your Speedo for sure is gonna be off and not sure by you but by me you start toying with the legality of bumper height
    GNTundra, joonbug and Puud[QUOTED] like this.
  15. Jun 9, 2017 at 11:44 AM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    I like it a lot. No real problems at all to speak of. Right after I got done with the lift I had a little shimmy at around 50 mph ended up being the tire balance. I had always had good luck balancing with beads in the past but we sucked them out and threw on weights and now she rides great. Ride comfort is awesome handling the bumps and everything. Turning radius did take a little bit of a hit compared to stock but so have all my trucks in the past. Mpgs according to trucks display were 15.9 before lift and Im at 13.1 today. I havnt hand calculated the mpgs cause I dont really care that much. No real noticeable power loss going to the bigger tires she still seems to have plenty of get up and go when I need it. Also I havnt had any problems with the shift points even the higher ones. I think with 37's is when you start pushing the capabilities of the stock gears. Make sure you go back in, and re torque everything after a few hundred miles I had a couple things work loose on the sway bar ends and control arm but thats pretty normal with any new lift. No abnormal tire wear thus far but Ive only had it for a couple thousand miles. I have spoke with others that had issues with the VSC after the lift but were all solved by doing a zero point calibration. My ass end did sag a little with just the lift. I installed some toytec shackles at 1 1/4 and popped it back up. Prior to pulling the trigger I would get @R0CKETMAN s blessing he seems to be the wheel and tire aficionado around these parts.
    GNTundra and MotoTundra like this.
  16. Jun 9, 2017 at 11:46 AM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    Also I had the most minimal rub in reverse that has already gone away on its own. 35x12.50r18 +1 18x9
    Junior 88 likes this.
  17. Jun 13, 2017 at 4:26 PM
    mixwells
    Thanks Puud, anyone else have some input on the BDS?
  18. Jun 13, 2017 at 6:51 PM
    R0CKETMAN
    NGAMTNS
    Nah bro this is all you need. Try Costco for bulk price.
  19. Jun 13, 2017 at 8:02 PM
    mixwells
    Well just ordered the kit, now I'm stuck between 35s or 37s, so confussed:notsure:
  20. Jun 13, 2017 at 8:09 PM
    hollandhunter
    hollandhunter New Member
    2017 SR5 CM 4x4
    I think 35s look fine. An is plenty of rubber on the ground. Fixing to pull the trigger myself.on a new lift. I will go with 35s on 18s more then likely. Also because it will be my daily driver.
  21. Jun 13, 2017 at 8:16 PM
    1UPPER
    TEXAS
    Flux capacitor!
    35" are easier to work either, better performance on stock 4.30 gears and less money. 37" will definitely require more trimming some times a lot more pending the offset of your wheels.
  22. Jun 13, 2017 at 8:31 PM
    mixwells
    True, plan on running 20" wheels, I just hope the 35s don't look too small with the 7" BDS lift!
  23. Jun 13, 2017 at 8:38 PM
    35" tires on a 7" lift will look too small, IMO.
    papasmurf, Asw278, R0CKETMAN and 3 others like this.
  24. Jun 13, 2017 at 8:39 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
  25. Jun 13, 2017 at 8:41 PM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    Took you 4 days to come up with that. Good job man.
  26. Jun 13, 2017 at 8:43 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Dude! I've been waiting for that reply. I was wondering which direction you'd come from. You're more kosher than I
    GNTundra and Puud[QUOTED] like this.
  27. Jun 13, 2017 at 8:47 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Im glad im at the age that im done lifting my trucks.....more money in the bank...and no going :goingcrazy: :goingcrazy: :goingcrazy: :goingcrazy: :goingcrazy: :goingcrazy: over what kit, tires, wheels, etc......
  28. Jun 13, 2017 at 8:50 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    But when i was younger, i sure had my share of some nice looking lifted trucks !!!
    Puud likes this.
  29. Jun 13, 2017 at 8:51 PM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    Haha I dont get too worked up over shit on forums. I usually see people who act like that, as looking like thisIMG_1125.jpg
    GNTundra, joonbug, JC303 and 2 others like this.
  30. Jun 13, 2017 at 9:00 PM
    Eclipsed & Floating
    Voluptuous Whitey
    :rofl::rofl::rofl:
    Agreed..that's why I was waiting. It's called "gauging" your character......you passed :thumbsup:
