BayRunner's '17 Platinum MGM build
Discussion in '2.5 Gen Builds (2014-2021)' started by BayRunner, Nov 13, 2017.
  1. Apr 17, 2018 at 6:23 PM
    BayRunner
    BayRunner [OP] I’m here, except when I’m not
    2017 Tundra Platinum
    Mod Update: Installed the S&B Cold Air Intake
  2. Apr 22, 2018 at 10:05 AM
    dmeneses1983
    dmeneses1983 New Member
    Dennis
    2016 Silver Tundra
    where'd you get the stubby?
  3. Apr 23, 2018 at 8:07 AM
    BayRunner
  4. Apr 24, 2018 at 1:51 PM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    Do they still have this show every other weekend. Is the the old mall over by BassPro shops. I might have to start checking this out, never knew about it.
  5. Apr 24, 2018 at 2:54 PM
    BayRunner
    Yes they do. I have not attended since Winter kicked up, but plan to get back into it shortly. Was just discussing with my nephew who has a nice Mini and hangs with the Mini group at the show. We were just planning a "detailing" weekend to get the rides ready I think I got the better end of the deal. I help him detail his Mini, and he helps me detail the Tundra :D
    Their web site, including the schedule is: http://carsandcoffeerichmond.com/
    Also, it's held in the parking lot at: Regency Square Mall: 8 - 10am, 1420 N Parham Rd
    don3032[QUOTED] likes this.
  6. May 1, 2018 at 12:54 PM
    BayRunner
    Mod update: Installed a RCI Aluminum powder coated engine skid plate.
  7. May 30, 2018 at 7:29 AM
    BayRunner
    Mod Update: Installed LED backlit Toyota logo grille badge made by @Sting Ray
  8. May 30, 2018 at 8:44 AM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Man I really love this pic!
  9. May 30, 2018 at 10:28 PM
    BayRunner
    You and me both Ray. You did a great job on the backlit badges.
    Sting Ray[QUOTED] likes this.
  10. Sep 10, 2018 at 10:25 AM
    VAQuicksand
    VAQuicksand New Member
    @BayRunner Hi- I have a very similar light build as yours, but for the fog. However, seems when I'm in drive and have my blinkers on, the a/c back light panels seems to blink as well. Very odd because everything else is functioning on the tail light (break, blinkers, tail light, reverse), headlights (DRL, low/high beams) and fog.
    Have you experienced anything like this? Any suggestion be appreciated
    Headlights: 2018 Tundra LED w/black housing
    Fog: Morimoto LED fog
    Taillights: Spyder LED Smoke Black
  11. Sep 10, 2018 at 12:45 PM
    BayRunner
    That is very strange indeed and I have not experienced this at all. Everything on my setup works as it should.
    1. My first question would be whose headlight harness did you use and also 1st or second generation harness. 1st generation uses the Moto LED controller and 2nd gen does not.
    2. Secondly, did you re=pin the turn signal wire on your truck for the new headlight. Note: This may not apply if you were provided an adapter cable for your turn signal plug that goes between the turn signal and headlight harness. Again, this depends on the harness you used.
    3. If you can rule out the harness and/or turn signal wire (re-pinning), I'd start ruling out other causes. I'd start with the fogs since they are not OEM. Check your wiring "+" / "-" connections and other contacts. Try unplugging the fogs and power connectors and see if this changes anything.
    Just my .02.
  12. Sep 11, 2018 at 12:53 PM
    VAQuicksand
    @BayRunner --Good suggestions.
    1. I use an adapter by https://www.instagram.com/dmv_slightwork/ which we used the MotoControl Bi-Xenon: H4/9003
    2. n/a
    3. This is a good one. I'll have to try this-
    I'll have to double check those suggestions after hurricane florence passes this week. I'll let you know how it goes. Thank you!
  13. Sep 17, 2018 at 12:55 PM
    vawildtundra
    vawildtundra New Member
    Rick
    2008 Gold Tundra
    6” suspension lift, 2” body lift. 18” Rockstars wrapped in 35” Nitto Trail Grapplers
    Where did you get the decals done? Looking to do the same thing.
  14. Sep 17, 2018 at 1:01 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    man i bet that looks bad AF at night! :thumbsup:
  15. Sep 17, 2018 at 2:05 PM
    BayRunner
    I had a local Vinyl shop do it. He custom created the hood insert and the side stripes. Was very pleased with the results.
  16. Sep 17, 2018 at 2:08 PM
    BayRunner
    Looks extremely good at night and gives it a very high end look and feel. It is definitely worth the purchase for @Sting Ray doea a good job
    Sting Ray likes this.
  17. Sep 22, 2018 at 9:13 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Thanks! I appreciate it. Glad I could play a small part in making your truck even more bad ass!
  18. Sep 22, 2018 at 10:43 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Truck is looking good!
  19. Feb 12, 2022 at 11:09 PM
    #49
    18" TRD Off Road Wheels
    You really need to update your build thread, @BayRunner. o_O:boink: :rofl::rofl::rofl:
  20. May 4, 2022 at 7:02 PM
    #50
    Man, I followed the link in your sig from your Sedona thread so I could see your build.... You have way more cool s#!t on your truck than this. Need to update that first post. :boink:
    I was specifically looking to see what kind of bumper you have.
  21. May 4, 2022 at 7:11 PM
    #51
    BayRunner
    Yea, it’s been on my todo list to update my build thread, but prepping for Sedona had me busy for a while.
    I’m running the nFab bumper on the front and the ICI Alumilite bumper on the rear. The spare tire carrier is a hitch carrier and not part of the bumper. It’s a DirtCom TrailSwing HD. I really like it and it performed well out on the Sedona trails.
    GODZILLA[QUOTED] likes this.
