Battery Size for 5.7L
Discussion in '2nd Gen Tundras (2007-2013)' started by ARayT, Jun 19, 2020.
  1. Dec 31, 2020 at 2:53 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I’ve had 2 truestart batteries and they were 5 yrs old and 6 years old.They were in a Camry and Tacoma and traded them both in. Never had a problem with them.
    Skidmarks likes this.
  2. Jun 30, 2021 at 9:08 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Just went to two Duralast platinum AGM 24F batteries. The second one is for running a fridge. Same CCA as the stock 27F.
  3. Nov 13, 2021 at 10:46 AM
    Skidmarks
    Skidmarks New Member
    There is a big difference between a Tacoma and a Tundra. The 5.7 will take a toll on any battery. I honestly dont think Toyotas batteries are bad. I am on my second one and I have a 2016 Tundra. So about 3 years is normal for this beast.
  4. Nov 14, 2021 at 5:00 AM
    CMikeB
    CMikeB New Member
    The Nothstar I BOUGHT for my 2010 Tundra has been in the truck going on 5 years. I have no idea if and when it'll ever fail.0424190427[2965].jpg
  5. Nov 14, 2021 at 5:10 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    I've had excellent result with True Start batteries. The batteries in BOTH my Tacoma and Tundra are 27F's.
    The factory battery in my '15 Tacoma lasted until this past spring (6 years). The battery was still going strong and tested well, but, 84 month True Start batteries (2 year free replacement) were on sale here, so, I replaced both the Tacoma and '07 Tundra batteries at the same time with True Start 27F's. This was the 3rd True Start battery for my Tundra after 14 years. (If my Tundra sits for more than a week, I keep a battery minder on it)
    WILLINH[QUOTED] likes this.
  6. Sep 10, 2022 at 7:42 PM
    kingrosk
    kingrosk New Member
    New York City
    2012 tundra crew max
    rims, blackoak led light bar, upgraded led turn signals, rear sway bar, rbp running boards, and fake roll bar because it looks good.
    Back in March 2020 I needed a new battery. I got the diehard platinum. By June it wasn't holding its charge. So they replaced it and here it is August and it keeps dying. I'm think because of my alarm and my short ride back and forth to work has something to do with it not fully charging. Do I order the
    Odyssey Battery ODX-AGM34R Extreme Series AGM Battery
    880 CCA
    I had an odyssey prior to the diehard and never had a problem. Let's see.
  7. Nov 2, 2022 at 11:09 AM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    Which model is this? Thanks!
  8. Nov 2, 2022 at 1:24 PM
    CMikeB
    CMikeB New Member
    NSB AGM2 930 195
  9. Nov 3, 2022 at 2:57 PM
    Fishinstud
    Fishinstud New Member
    San Antonio, Texas
    2016 TSS Off Road 4x4
    Oh poop! Driver's handle Lock'er Down Console Safe BAMUFFLER standard 6” stainless steel exhaust
    Battery Search Results
    LONG LASTING PERFORMANCE
    2016 Toyota Tundra V8 5.7L Standard
    Due to HAZMAT compliance requirements, shipping is currently unavailable for automotive batteries.
    YOUR BATTERY INFORMATION
    Item Number 1131901
    Group Size 27F
    CCA 710
    CA 890
    Voltage 12
    RC 165
    Termination Code TOP
    Wet/Dry W
    EXCLUSIVE FOR COSTCO
    Group Size: 27F
    $104.99*
    *Refundable core charge of $15.00 not included
    36 Month Limited Warranty
    baraynavab likes this.
  10. Nov 4, 2022 at 7:54 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    Just replacing the battery may not be enough. A lot of batteries die due to the low voltage charge that is programed into the alternator.
    There is another thread on here about Voltage Boosters you might want to look at.
    The Mike Singer Voltage Booster Stage 1 or Stage 2 depending on how much you want to boost your voltage from your alternator.
    You can also swap out a chip in the engine bay fuse box or try the HKB Voltage Booster.
    Seems the factory setting on the alternator is approx 13.6. Discussion says that AGM batteries need higher charge. With the mods you get 14.4 or higher depending on the route you take.
    After reading the threads I went with an AGM Battery and the Singer VB Stage 1.
  11. Nov 24, 2022 at 4:31 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I was at BJ'S last week and they carry Interstate batteries, they were stamped made in Mexico which suprised me.
  12. Oct 22, 2023 at 3:08 AM
    CMikeB
    CMikeB New Member
    Just had to "top it off" after 9 years. I'll shop for an X2 if it's the Northstar replacement.
