Battery Monitor
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2point5seconds, Jan 27, 2022.
  1. Apr 7, 2022 at 9:45 AM
    #91
    Wallygator
    What are you referring to?
  2. Apr 7, 2022 at 10:00 AM
    #92
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Your ammeter/USB port replacement
    Wallygator[QUOTED] likes this.
  3. Apr 7, 2022 at 10:57 AM
    #93
    Wallygator
    Oh, sorry have a lot going on right now at work, so it's a 3.0 charger so it supposedly charges faster than some. I hardly ever use the USB port or C plug part of it cuz I have two USB ports in the Rago Fab dash mount. I charge my phone there.
  4. Apr 12, 2022 at 9:26 AM
    #94
    2point5seconds
    2point5seconds [OP] Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    No. You have to cut the factory wire and wire the new one. It's not bad. I did it on the front dash and rear console for people riding in the back to charge their phones. So you will need to take the dash apart.
    One thing you need to know is this charger/volt meter is larger than factory one. So you need to drill a bigger hole. I would start from the inside.
  5. Apr 12, 2022 at 10:01 AM
    #95
    raspy87
    raspy87 New Member
    Andrew
    RI
    ‘19 DC SR5 Cement
    I’ve actually already installed it! I released the factory wire terminals from the plastic 90* housing on the original 12v outlet and reinstalled them on the new outlet with electrical tape around it. 61FFE789-BD40-4DCC-B143-31428956A877.jpg
    Thanks for the response!
  6. Jun 14, 2022 at 8:03 AM
    #96
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I think you just got a lemon....same set up and process for two years with no issue.
    Wallygator likes this.
  7. Jun 14, 2022 at 8:06 AM
    #97
    dkrou
    dkrou New Member
    dan
    2019 tundra
  8. Jun 14, 2022 at 8:10 AM
    #98
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It all worked out.
    I've got better things to do than to top off an AGM battery once a month with a charger..:thumbsup:
  9. Jun 14, 2022 at 11:03 AM
    #99
    Wallygator
    Just topped off my X2 overnight while I slept soundly in bed and wow it was hard!
    This battery is over three years old now and no issues except for what I mentioned above. :)
  10. Jun 15, 2022 at 5:57 AM
    #100
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I decided on my AGM because I have a ton of Baja Design lights and most recently added a Blackvue dash cam that runs a minimum of 6 hours in park mode. I don't think other batteries could handle it....the other bit of good news is when you get the trailer pkg on newer tundras it comes with 180amp alternator which helps a bunch when the thing is running.
    AGSport and Wallygator like this.
