Battery light is on...alternator or battery?
Discussion in '1st Gen Tundras (2000-2006)' started by 1stgentundradriver, Mar 18, 2021.
  1. Mar 20, 2021 at 2:54 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Just use petroleum jelly...good to go and cheap. no moisture no corrosion.
  2. Mar 20, 2021 at 3:03 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    :rofl:You got me.
    There...I fixed it before my "fallibility" was widely discovered. Only the most devoted fans of my bullshit and free advice now know the truth.:rofl:
  3. Mar 20, 2021 at 3:03 PM
    Professional Hand Model
    Hand Protectors
    Yeah Jelly is an arrow in the quiver, but I found a tube of the NoAlox on a street corner and decided to give it a whirl. It can be used almost anywhere with plastics, rubber, all metals electric connections. An all around top notch product. Actually promotes conductivity while protecting versus just a lay over layer which on some connections isn’t ideal and may block conductivity.
    Grab a bottle and try it. Can be used on the house stuff, as well.
  4. Mar 20, 2021 at 3:06 PM
    Roborob70
    Robert
    Will check it out. Thanks
  5. Mar 20, 2021 at 3:06 PM
    Hand Protectors
    I checked your Permatex Spray which seems about as ok as a Jelly Overlay. They claim it promotes conductivity, but I fail to see how based on their Spec Sheet Breakdown. I don’t see a conductor in the formula.
    https://www.permatex.com/wp-content/uploads/tech_docs/sds/01_USA-English/80370.pdf
  6. Mar 20, 2021 at 3:09 PM
    Hand Protectors
    Its about $8 for a small bottle (last I checked) which is all you need as a little goes a long way.
  7. Mar 20, 2021 at 3:10 PM
    Roborob70
    Robert
    Got a 55 gallon drum on the way. I've been using the wrong shit....
  8. Mar 20, 2021 at 3:23 PM
    JohnLakeman
    I never studied the ingredients to see if it should work, only paid the money and tried it to see if it worked. It worked for me, but if you apply too much it can be a big freaking mess. The Prestone will dry slightly; grease never dries.
    When they say "it promotes conductivity", I believe that's marketing speak written by a BA in advertising. It's just more copy to fill up label space. I believe it's another way of saying it promotes conductivity by eliminating corrosion, not by improving conduction across the gap. You know, similar to that transmission warmer/cooler thing on 2019+ Tundras. :D
  9. Mar 20, 2021 at 11:52 PM
    1stgentundradriver
    1stgentundradriver [OP] Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Sorry for the late reply! It was definitely electric bake light. It was towed to the shop today and they fixed it in the same day and I drove it home. If anyone in the Silverdale Wa. Area needs work done on a vehicle, the guys at the Goodyear shop on silverdale way rock.
    Anyway, the problem was solely the alternator. No blown fuses, all wiring is good, alternator itself had an internal short and caused it to fail. Can’t quite remember why he said it started smoking but what he said made sense. Truck now has a reman (could not find any stock replacement alternators) 130 amp alternator. Runs and starts like a champ.
  10. Mar 21, 2021 at 9:11 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Yea seems to me they always go out at around 200k.
  11. Mar 21, 2021 at 9:58 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Well having 180,000 miles it seems a tad early but whatever! I’m glad it’s fixed and running smooth as before.
  12. Mar 21, 2021 at 2:05 PM
    Hand Protectors
    Nothing wrong with an early replace if in there. In your case it needed it. I wonder what caused the short inside. You have lots of salts on road?
  13. Mar 21, 2021 at 2:08 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    No salts at all. Pretty sure the truck has never seen salt. Purchased from the original owner who was local.
  14. Mar 21, 2021 at 4:43 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Don't tell my 1997 T100's alternator that is original at 264,000 miles (I did just recently put in a 2nd set of new brushes).
  15. Mar 21, 2021 at 9:04 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    She won’t know a single thing...I promise.
