Battery Issue?
Discussion in '3rd Gen Tundras (2022+)' started by prosledder, Sep 24, 2022.
  1. Jun 27, 2023 at 7:28 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    Marine grade breaker, marine grade fuse block, relays, proper grounds, etc.
    Tested and confirmed - zero parasitic leak/draw.
    What am I testing "amp draw" for?
    4x aftermarket horns...which are used once (for 3 seconds) a decade?
    1x LED light bar, same as above.
    A few LED/low amp interior devices which are seldomly used as well.
    My wife ran 1000+W RMS stereo in her 2005 4Runner, and I had to replace the OEM, Japan-made, battery..........after 12 years!
    It ain't me bud, it's the sh** OEM Tundra battery, as described in post(s) above.
  2. Jun 27, 2023 at 9:57 PM
    Tom976
    Tom976 New Member
    Tom
    Testing for amp draw when in use and powered off (parasitic leak) is what I was referring to.
    Looks like a clean wiring job. Thats on top of the air filter housing?
    Hope you have better luck with this battery.
  3. Jun 28, 2023 at 9:31 AM
    99ways2die
    NJ
    No; top of the pass-side fuse box.
    Thanks.
    -99
