Battery dead after four days
Discussion in '1st Gen Tundras (2000-2006)' started by oldnavy2x2, Dec 27, 2021.
  1. Dec 27, 2021 at 9:44 AM
    oldnavy2x2
    oldnavy2x2 [OP] New Member
    virgil
    2002 tundra 2x2
    none
    2002 tundra V8 battery drain. What is a normal milliamp drain and what's not .. mine is dead in 4 days. Has new battery.
  2. Dec 27, 2021 at 9:54 AM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    IiRC someone on here said something like 50 mA. Biggest culprit is usually aftermarket alarms/starters.
    FrenchToasty likes this.
  3. Dec 27, 2021 at 3:18 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Compustar Remote Start and Alarm was killing the battery in my old 2002 Access Cab in two (2) days. Had it all removed and no more issues.
  4. Dec 28, 2021 at 7:15 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Have the new battery load tested, even brand new they can be bad, have a dead cell, etc.
  5. Dec 28, 2021 at 7:18 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Or the door switches.
    Riverdale21 and Jack McCarthy like this.
  6. Dec 28, 2021 at 7:25 AM
    Richid
    Richid New Member
    Previous owner of mine had reported the same thing. I couldn't find the battery drain.
    One post on here recommended turning off the headlight switch as the relay sometimes drains the battery. Not sure if it's true, but haven't had a problem since. Could be a poor connection or corrosion, but it stopped so I don't see a need to dig into a 20-year-old truck to find out exactly why.
    My next step was to replace the battery cables as it looks like they are prone to internal corrosion after so many years of use.
    Good Luck!
  7. Dec 28, 2021 at 9:30 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Relatively easy to find the battery drain. Many threads on here discussing this.
  8. Dec 28, 2021 at 9:56 AM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    My old Gmc truck inside lights would stay on for 1 min , after you left the truck. The time delay was built in to the head light switch. It went bad, so my inside light would stayed on all the time, draining my battery. After replacing the $85 switch, no more problems. That was 25 years ago.
  9. Dec 28, 2021 at 3:57 PM
    gascap
    gascap New Member
    2002 Tundra
    Do you have an alarm system or remote start connected?
  10. Dec 28, 2021 at 6:27 PM
    shifty` My piss and moans are the fuel
    Do you know how to test for parasitic draw? It's really easy. This entire video will help you diagnose and teach you new stuff, but around the halfway point (18m30s, roughly) they start talking about how to diagnose parasitic draw using a multimeter:
    https://www.youtube.com/watch?v=YC--MLNIbik#t=18m28s
