Battery bought the farm today
Discussion in '2.5 Gen Tundras (2014-2021)' started by preacher35, Jun 29, 2020.
  1. Jun 29, 2020 at 2:10 AM
    preacher35
    preacher35 [OP] RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    So I drove my 2018 5.7 CM (18k miles and original OEM battery) to the grocery store today. Started fine at home but absolutely NOTHING (not even a solenoid "click") when I was leaving the store. Long story short, friend came and gave me a jump and I proceeded to drive it for a half an hour to see if it would take a charge. Got home, shut if off and tried to start. Same thing: nothing. So, my question is, will Toyota warranty it after 2 years? I've seen mixed stories of "free replacement" as well as "pro-rated". Can I pull it out of the truck and take it to the dealer in my wife's car and have it warrantied?
    Thanks in advance for any help!
  2. Jun 29, 2020 at 3:24 AM
    Thehype31
    Thehype31 New Member
    Upstate NY
    2023 super sonic red platinum hybrid
    I had mine die after 2 years/ 25k miles on my 2017.... jumped it, took the truck right to the dealer and it was a warranty swap.
    YardBird and NewImprovedRon like this.
  3. Jun 29, 2020 at 4:03 AM
    Stig
    Stig New Member
    Just call the dealer
    TWJLee and YardBird like this.
  4. Jun 29, 2020 at 4:10 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    They should give you a pro-rated credit towards a replacement.
  5. Jun 29, 2020 at 5:09 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    The OEM factory batteries don't seem to last very long these days.
  6. Jun 29, 2020 at 5:10 AM
    Rex Kramer
    Georgia
    You can top off the OEM batteries with distilled water, this practice will extend the life of the battery.
    Toyotoholic likes this.
  7. Jun 29, 2020 at 5:50 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    3 year bumper to bumper...
  8. Jun 29, 2020 at 7:35 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Just had the same thing happen in my 2018. Warranty covers it.
    YardBird and HulkSmurf14 like this.
  9. Jun 29, 2020 at 7:58 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Toyota should cover it. I took my dads RX350 to the dealer for a service and they detected the battery is starting to go, they replaced it under warranty (6 mos left on the factory warranty).
    YardBird likes this.
  10. Jun 29, 2020 at 8:19 AM
    ZPMAN
    Minnesota
    That's a short life for a battery, my 16 is still going strong but that may be due to cooler temperatures in Minnesota and possibly the few miles of dirt roads I must travel on. I belive the dirt roads keeps lead sulfate low due to the washboards on the dirt roads that are also good at loosening filings in your teeth. I have found in the past that can revive a dead battery (boat,motorcycle, lawnmower, ect)simply by placing on a cement floor and give it a little vibration being cautious not to damage or crack it then checking the water level (if possible) and recharging. Also making alot of short drives will kill a battery fast. Good luck
    https://www.crownbattery.com/news/sulfation-and-battery-maintenance
  11. Jun 29, 2020 at 8:44 AM
    17inferno
    17inferno New Member
    I had something similar after 2 years or so on my 17. Got a jump, got it home and put it on a deep cycle trickle charge for 24 hours. Been perfect ever since.
  12. Jun 29, 2020 at 11:28 AM
    preacher35
    Spoke to the local dealership and they said if the battery is really toast, they will do a free replacement. Now the question is, will my 0/1 gauge amp wire running directly to the battery, void the warranty? What do you guys think?
  13. Jun 29, 2020 at 11:38 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Shouldn’t. If they say it does, go to a different dealer. It’s free easy money for the dealer if your still under 3/36
  14. Jun 29, 2020 at 12:18 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    If you're worried, just disconnect it and tuck it under the fuse box. They will obviously see it so if there is a grey area, you wouldn't want them to be "blaming" the aftermarket wiring or draw on the electrical system. Amps that exceed the output of the alternator will then draw on the battery as a capacitor, too much of this will definitely lessen the battery's life. If you're on good terms with your dealership, I would not worry about it.
    Jstarr likes this.
  15. Jun 29, 2020 at 4:40 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The dealer will test the old battery and it will fail. They get a print out of the results and submit it for warranty with the battery. Easy money for the dealer and they wont give a butt hole if you have an amp connected. Lots of times we had a "special" battery that was guaranteed to fail just to replace batteries to make the customer happy. :rolleyes:
  16. Jun 29, 2020 at 6:05 PM
    Jstarr
    Jstarr New Member
    Jonathan Starr
    2000 silver 1st Gen Tundra, 2017 Tacoma TRD OR, 2020 4Runner TRD ORP, 1994 Jeep Wrangler
    If you have something connected to the battery that can elicit questions, I agree that it might be a good idea to disconnect it before taking it to the dealer.
    It sounds like a cell failed suddenly, which is likely a material defect or the result of running the battery way down or dry or into a short circuit with no fuse or breaker in the line.
    Toyotoholic[QUOTED] likes this.
  17. Jun 29, 2020 at 6:11 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    One bad cell isn't going to make the truck absolutely dead. Batteries that fail in the summer with the heat die instantly. Winter battery fails are a slow crank. The dealer isn't going to care what's connected to the battery as long as there isn't a parasitic draw. They run a GR8 test and if it fails new battery goes in. Techs dont have the time or bother to question customers about a dead battery and the dealer just wants the money.
    Black Wolf likes this.
  18. Jun 29, 2020 at 6:45 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Mine took a shit 3 weeks ago.
  19. Jun 29, 2020 at 6:53 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I took mine in 3 weeks before the 3/36 warranty was up and they replaced it free of charge.
  20. Jun 30, 2020 at 11:01 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I just changed mine in my 2016 with 115k miles last week.
