Battery blinking
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra21NS, Mar 23, 2022.
  1. Mar 23, 2022 at 4:45 PM
    Tundra21NS
    Tundra21NS [OP] New Member
    2021 Black Tundra limited Nightshade Edition
    Anyone know why my battery is blinking on dash board. Truck only one year old. Voltage is at 14.
  2. Mar 23, 2022 at 4:54 PM
    Could be a bad alternator, should be under warranty. I would go back to the dealership.
    GODZILLA likes this.
  3. Mar 23, 2022 at 4:56 PM
    18" TRD Off Road Wheels
    Owner manual should have an explanation for all the dash lights. The battery symbol just means some kind of voltage problem, I think. Jim could be right about the alternator. Either way, with it being that new I would just take it to the dealer to get whatever it is replaced/repaired.
  4. Mar 23, 2022 at 4:56 PM
    Tundra21NS
    Yeah seems odd for a brand new truck.
  5. Mar 23, 2022 at 4:58 PM
    Stock batteries are known to be sh*t from Toyota. Also from Subaru. Alternators are funny. Some will last forever, and others of the exact same make/model/part will only go for a short while before cratering.
    TTund16 likes this.
  6. Mar 24, 2022 at 4:56 AM
    Tundra21NS
    Just as I figured it would do. Drive about 45 mins to the dealer. The battery blinker stopped flashing.
    They tested battery and alternator. Both came back good. Maybe I just need to drive my truck more.
  7. Mar 24, 2022 at 9:32 AM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    I wouldn't be surprised if your battery was going bad. My battery was replaced at 6 months old. It was leaking and beginning to have issues with starting.
  8. Mar 24, 2022 at 4:12 PM
    Rocko9999
    Rocko9999 New Member
    It's battery or alternator. 14v while running means alternator is prob working. What is voltage of battery when truck is off? Use multimeter.
    2mchfun likes this.
  9. Mar 24, 2022 at 4:15 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Might be benifitial to get the battery load tested. If it fails, be sure to take the print out with you when you go back to the dealer.
  10. Mar 24, 2022 at 4:44 PM
    Tundra21NS
    I just hope it doesn't come back. Everything seems normal again.
  11. Mar 24, 2022 at 4:54 PM
    2mchfun
    These newer vehicles are not sold with quality batteries or meant to sit for long periods of time. Grab an Interstate battery from Costco or an O'Reilley's Platinum, you will be golden for a good 3-4 years or so depending on your location provided you drive it every 5-6 days for about 30 minutes or more. If the dealer replaces it, you just get a repeat of the same junk.
