Bank 1 sensor 2 02 not getting much voltage.
Discussion in '1st Gen Tundras (2000-2006)' started by JeffTundraSR5Guy, Jan 11, 2023.
  1. Apr 9, 2024 at 6:50 PM
    creidenouer
    creidenouer New Member
    How did this turn out?! I'm getting the same N/A readings.:mad:
  2. Apr 9, 2024 at 7:13 PM
    First thing to do is, check for obvious wire issues, cut/spliced wires, or any issues with the connector on the affected bank (like, if you live in a road-salt area, check for obvious corrosion).
    If nothing, two options....
    A) Sanity check/money saver, which may or may not be possible.
    Denso is he OEM manuf'er, look up the correct "exact fit" parts at www.densoautoparts.com (note: Sometimes O2 sensors are called a/f or air/fuel sensors) and note the part numbers - be careful, because 2WD ("RWD") and 4WD sometimes use different sensors - read the part notes.
    If you find the Denso part lookup tool shows your downstream sensors (left and right) share the same part number, you may do a sanity check by swapping the after-cat sensor between the two banks to see if the code changes. If so, you know it's a wiring problem, not a sensor problem. But it's not uncommon for sensors to go bad.
    B)
    Replace the upstream and downstream on the affected bank/side.
    ONLY use Denso brand parts for that specific part, they're the OEM manuf'er, again, look up the correct "exact fit" part numbers at www.densoautoparts.com (note: Sometimes O2 sensors are called a/f or air/fuel sensors)
    DO NOT purchase your parts from scAmazon or fleaBay, too many knockoff parts are sold there (Rock Auto is safe, Summit Racing is also safe).
    I am curious what @Martini8875 found. I forgot about this post totally.
  3. Apr 10, 2024 at 6:16 AM
    creidenouer
    Thanks for such a thorough response and help shifty! @Martini8875 Yes, still curious.
  4. Jun 6, 2025 at 7:58 PM
    Solismobilemechanic
    Solismobilemechanic New Member
    Gustavo
    2002 toyota tundra
    Im having the same issue. Mine reads 0v and does move up a bit on voltage when I rev up to 3krpms
