Banging drivers side after 6112 install
Discussion in 'Suspension' started by Spitfire, Feb 8, 2020.
  1. Feb 8, 2020 at 2:41 PM
    Spitfire
    Spitfire [OP] New Member
    Long Island
    2018 Cement Limited Trd off road
    Passenger
    georgiey22 likes this.
  2. Feb 8, 2020 at 2:43 PM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    pass side has all nuts and no sign of cam towers leaks.
  3. Feb 8, 2020 at 2:48 PM
    rustytoys
    rustytoys New Member
    Post a pic of where the lower control arm attaches to the spindle on drivers side, not too close so we can see the area. There are different ways you can go when installing the coilovers, so I am not sure what areas they messed with.
  4. Feb 8, 2020 at 3:38 PM
    rustytoys
    You know, this other thread on here made me think - check the actual mounting bolts that hold the sway bar on the frame; I've never personally messed with those, but some guys apparently do - if they were left loose that would definitely make noise.
  5. Feb 8, 2020 at 7:24 PM
    Spitfire
    Long Island
    Will in the A.M
    Rica25 likes this.
  6. Feb 9, 2020 at 7:42 AM
    Spitfire
    Long Island
    Rica25 likes this.
  7. Feb 9, 2020 at 7:48 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The sway bar has 2 bolts to the frame rails. They are tricky to get tight. But why would they have loosened them? Very odd
    Rica25 likes this.
  8. Feb 9, 2020 at 8:52 AM
    rustytoys
    Spitfire, I was just trying to see how the ball joint is seated on the lower control arm in case they popped that - lower right of your photo, but its hard to see - you may want to just double check that nut - the one that looks almost inside the wheel in the pic. Really wish we could see something to point out, but everything looks completely fine - the only other area would be the sway bar to frame bolts - if they chose to remove those.
    Spitfire[QUOTED][OP] likes this.
  9. Feb 9, 2020 at 8:53 AM
    rustytoys
    Like in the other thread here - guys have trouble getting the sway bar end links bolted up to the control arm - so some people un-bolt the sway bar from the frame to help with this.
    https://www.tundras.com/threads/sway-bar-end-link-reinstall-help.61753/
    I would definitely say its a long shot, sure most leave it alone.
  10. Feb 9, 2020 at 9:04 AM
    1794TX
    Steven
    N.TX
    '20 1794
    So, I'm just gonna write something out loud here. For context, I have a sketchy faith in humanity; the lens I look through is fairly center, leaning pessimist.
    I joined this forum hoping for a little advice about a couple of things I was thinking of doing to my new 1794. Some little sliver of information that might help keep me from making any mistakes. I got here and started looking around and found it to be more valuable every day. Then I start recognizing a steady stream of posts like this one... Some guy needs a hand, and some other guy who doesn't know him goes all the way out to his truck with his phone, probably messes up his PJs, just to get a quick pic for reference. Not for a truck, because everyone here loves their truck; but for some guy that needs a hand.
    I'm not leaving.
  11. Feb 9, 2020 at 9:47 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is the sway bar link to arm bolt tight? My welded on nut broke off on the arm when i re installed mine.
  12. Feb 9, 2020 at 9:53 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    We all started somewhere with this passion of ours. I’m glad to help with anything for anybody.
    Tundra234, Boerseun and georgiey22 like this.
  13. Feb 9, 2020 at 10:39 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Hey dude, it all looks good from where I’m sitting. There’s a lot that could be loose but I’m guessing that’s all it is. I would take it back or to the dealer to check your torques. It should not “bang”. Period. It could be dangerous as something may be loose. I would just take it somewhere and pay for your peace of mind.
  14. Feb 9, 2020 at 10:54 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Did you get it aligned yet?
    Tundyfundy likes this.
  15. Feb 9, 2020 at 11:28 AM
    georgiey22
    georgiey22 SW Idaho
    When I first got into modding my Tundra, I also experienced the ‘be kind and pay it forward’ concept. Many Tundra owners here contribute. Although it’s a virtual platform, the kindness is real. Honestly, it makes owning and driving my Tundra even better than it already is.
    Hope to see you and others here for a long while. Enjoy your Sunday friends.
  16. Feb 9, 2020 at 11:31 AM
    georgiey22
    georgiey22 SW Idaho
    @Spitfire I live in California but was in Farmingdale, NY last week. If I get out there again soon, I’d be happy to look at it, although it won’t be for awhile. I’d recommend you get it to the shop that did the work, if you aren’t handy with the wrenches.
  17. Feb 9, 2020 at 3:33 PM
    Spitfire
    Long Island
    Thanks for the offer! Im going to stop by tomorrow at lunch and see what they say.
    Side note I REALLY like how the shocks ride
    georgiey22[QUOTED] likes this.
  18. Feb 10, 2020 at 9:04 AM
    Spitfire
    Long Island
    All aligned .. at shop guy was trying to say it could be tire rubbing.. is that possible? On stock tires and offset
  19. Feb 10, 2020 at 9:07 AM
    #49
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    You should be able to see tire rubber scuffs I would think. Have a gopro you can strap under there? I did that to my Tacoma to watch my steering rack
  20. Feb 10, 2020 at 9:21 AM
    #50
    georgiey22
    georgiey22 SW Idaho
    Sure, but rather than guess if that’s the issue, ask him to confirm with certainly. Replace the rub.
  21. Feb 10, 2020 at 12:35 PM
    #51
    Spitfire
    Long Island
    so he said that he didn't hear anything on the drive (another tech guy this time) i said it has to be something.. he said he retorqed everything and there wasn't any noise. kinda shook my head bc thats what i was asking them to do in the first place.
    have to take for a drive and do some tight turns when i get home. didn't have a chance bc i was rushed at lunch
  22. Feb 10, 2020 at 12:56 PM
    #52
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    1) Darren at Boss knows his shit. That guy probably sells more 6112s than anyone else on the internet. 2) Are you sure all of the alignment bolts are TIGHT TIGHT? I had one loose after install and was getting a pretty big banging noise.
    I have a set of 6112s on my truck from Boss - Ill go get a picture of the top, but I don't believe that is your issue.
  23. Feb 10, 2020 at 6:45 PM
    #53
    Spitfire
    Long Island
    I didnt think for a second it was anything related to boss. I drove around and tested the shocks out. No noise at all now.. musty have not tightened everything the first go around. Hopefully everything is good from this point on.. 5160s are next
    Thanks for all the input everyone.. greatly appreciated!
    rustytoys and georgiey22 like this.
  24. Feb 12, 2020 at 7:36 AM
    #54
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Agree 100% about Darren @BOSS4x4s
  25. Feb 12, 2020 at 7:37 AM
    #55
    r1-superstar
    DB
    UTAH
    I think you are right in the sense that they missed something. Glad it is worked out now.
  26. Feb 12, 2020 at 7:52 AM
    #56
    Elduder
    Elduder New Member
    If you actually look closely enough you will see all the top nuts are there.
    As far as clunks while turning I'd check the torque on the LCA cam bolts, if left loose you can get clunks/bangs while turning and while cycling them. Other thing to check is the skid plate.
  27. Feb 12, 2020 at 8:07 AM
    #57
    The top spring mount may be installed incorrectly. The slots are supposed to be in the groves for the stud. Also, the mount is directional. Some people do not know that.
    You can see the direction of the mount in this image:
  28. Feb 12, 2020 at 8:28 AM
    #58
    georgiey22
    georgiey22 SW Idaho
    That’s great news...I’m running 6112 and 5160 but installed all at once.
    Would you mind writing a detailed review of the ride, handling, nose dive, comfort, rebound, etc after you make the switch?
    The reason I ask, I love them and they’ve been flawless in 10K miles. I have 6112 and 5100 on my 2016 4Runner and am really happy with that setup also. 5160s are double the price as the 5100s and curious if the daily driving performance is the same or better. No doubt the 5160 is better off road to cool the shock oil and minimize shock fade.
    Thanks!
  29. Feb 12, 2020 at 8:47 AM
    #59
    Spitfire
    Long Island
    i will once i get the money for the shocks. might be a while. going to disney next week and the wife is onto me :eek:
  30. Feb 12, 2020 at 9:53 AM
    #60
    r1-superstar
    DB
    UTAH
    6112/5100 here. Great set up. 5160 same shock as 5100 but with res for off-roading/cooling.
