Banging and clanking when accelerating from a stop
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by JDEtundra, Mar 14, 2023.
  1. Mar 15, 2023 at 10:48 AM
    JDEtundra
    JDEtundra [OP] New Member
    So thats one thing I notice last night was back and turning to right while backing and moving forward, it felt as though steering wheel was skipping or bumping but very slight, didn't notice it again though. was kind of odd. no suspension upgrades or lifts. Brakes and rotors were done about 25k ago and l looked at rotors last night, seem fine no bad wear or grooves.
  2. Mar 15, 2023 at 10:50 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I would check your steering rack connections and see if you see any leaks. Check out the fluid too.
  3. Mar 15, 2023 at 10:52 AM
    JDEtundra
    power steering has fluid and no noticeable leaks. I will crawl under and look at steering rack connections. but would this cause the engine to bog down feeling during noise the after 20mph everything is good?
  4. Mar 15, 2023 at 11:22 AM
    MadMaxCanon
    Probably not unless the power steering pump is like semi seized or something weird like that. Did you ever get a steering rack recall notice? I forget what years it affected.
  5. Mar 15, 2023 at 11:27 AM
    JDEtundra
    no I haven't. I did try to look at recalls but only one I found was for the rear bumper.
  6. Mar 15, 2023 at 11:40 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Do a drain and fill of your rear diff. Check for metal.
  7. Mar 15, 2023 at 11:46 AM
    JDEtundra
    can I ask why the rear diff? Only ask cause noise is in front and engine hesitation.
  8. Mar 15, 2023 at 11:55 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Driveline noise is tricky and can sound like it's coming from somewhere it isn't. I've chipped a tooth on a ring gear and lost power like you described...it felt like engine hesitation. It's worth a quick little release of the plug then looking at the fluid for metal.
    JDEtundra[QUOTED][OP] likes this.
  9. Mar 15, 2023 at 12:44 PM
    Sounds like what it would do if you had 4WD engaged. Which would be suspicious for CV’s or front diff.
  10. Mar 23, 2023 at 6:35 AM
    JDEtundra
    So what I have found so far is the passenger rear speed sensor was showing active. so pulled it out and found diff oil all over sensor. so I am assuming maybe this could be the issue. causing ABS to fault out. Maybe I am wrong but going to try this first. So do I change bearing out as well when I switch out inner seal on axle or do I clean everything inside and just put it back together.
