BAmufflers tax season group buy 2020
Discussion in 'Deals & Group Buys' started by dirtydeeds, Jan 27, 2020.
Thread Status:
Not open for further replies.
  1. Feb 19, 2020 at 8:14 AM
    #211
    Stonehide
    Stonehide New Member
    2020 Cement DC Limited 4x4
    Stainless 10" ordered!
  2. Feb 19, 2020 at 3:46 PM
    #212
    Burdturger
    Burdturger New Member
    What are you guys using to cut into the stock muffler for the resonator? IIRC a hole saw was recommended. Is there a certain one rate to cut into metal?
    focal likes this.
  3. Feb 19, 2020 at 3:57 PM
    #213
    dyn0mitemat
    dyn0mitemat New Member
    Mat
    19 TRD OR
    Most hole saws will be treated for metal. If you do not have one already your local homeless depot/blowes (sp?) should have a few different brands, most any should be treated for metal and will work. Just cut slow and use cutting oil if you have to and they'll be fine .
    Another option is to use a plasma cutter if you have one available at a friend's or somethings. All that is required is to crawl under and mark the pipe, cut a hole, and bolt it on (no needing to pull the tailpipe)
    Jonas, Bob_Wiley, somadbamos and 2 others like this.
  4. Feb 19, 2020 at 5:16 PM
    #214
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    If you are going to be laying on your back to do this may I suggest that you line up the resonator in the correct position making sure it clears the spare tire, and make your marks with a sharpie. Now lower & remove the spare tire, this will make the installation of the resonator that much easier.
    tundra_20, somadbamos and Rica25 like this.
  5. Feb 19, 2020 at 5:58 PM
    #215
    dyn0mitemat
    Mat
    19 TRD OR
    For anyone inquiring about installation advice or tips, dirty deeds put up a good video awhile back on how to do a the install from start to finish.
    https://youtu.be/i79q3q3kaHs
    He even does it completely blindfolded at the end
  6. Feb 20, 2020 at 3:39 PM
    #216
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    Curious if anyone is also going with an exhaust tip and which? Found a few posts about the Go Rhino GRT234410B but not hot about cutting the tailpipe.
  7. Feb 20, 2020 at 3:47 PM
    #217
    rcjh0891
    rcjh0891 New Member
    Joel
    DFW
    2018 Tundra Platinum Crewmax 4x4 MGM
  8. Feb 20, 2020 at 3:48 PM
    #218
    IBJC
    IBJC New Member
    2020 tundra sr5 crewmax Cavalry Blue
  9. Feb 21, 2020 at 8:51 PM
    #219
    mttjdy
    mttjdy New Member
  10. Feb 21, 2020 at 9:10 PM
    #220
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    I think it’s half down
    mttjdy[QUOTED] and somadbamos like this.
  11. Feb 21, 2020 at 9:17 PM
    #221
    dyn0mitemat
    Mat
    19 TRD OR
    It is
    somadbamos likes this.
  12. Feb 21, 2020 at 9:19 PM
    #222
    buddy89
    buddy89 New Member
    SoCal/northern Az
    2015 Tundra dc sr5
    I know it’s $337 for an aluminized system. So probably $437 for stainless.
    focal and somadbamos like this.
  13. Feb 21, 2020 at 10:35 PM
    #223
    somadbamos
    somadbamos Dude, you're being totally undude.
    Jake
    Idiot Out Wandering Around
    '14 Crewmax w/ Attitude
    I went SS and yes that is what I put down.
    buddy89[QUOTED] likes this.
  14. Feb 21, 2020 at 10:43 PM
    #224
    dspilot
    dspilot Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    I paid the full price when I ordered, but at that point he knew that the total order count would be over 50, so he knew what the final price would be.
  15. Feb 22, 2020 at 10:05 AM
    #225
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    What's the order count at now?
    buddy89 likes this.
  16. Feb 22, 2020 at 10:09 AM
    #226
    Elduder
    Elduder New Member
    Supposedly over 50. Will be +1 more once I finally get a hold of Keith. Not his fault, me working 60+ hr weeks with no cell access.
    buddy89, somadbamos and Bob_Wiley like this.
  17. Feb 22, 2020 at 5:20 PM
    #227
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    So, I just noticed my “stock” exhaust isn’t stock...I never saw the weld points where the muffler meets the tailpipe until just now. I assume the DD 8” I ordered won’t actually work unless I buy a stock tailpipe from somewhere, which really sucks. My fault for not looking closer before ordering. Previous owner must have had the current muffler welded in.
    Here’s the front, which looks fine to me:
    And here’s the back (where I think I’ll have a problem):
    Anyone have any bright ideas on how to address this? Or know of anyone selling a stock tailpipe for cheap?
    @dirtydeeds could use your advice on this if you have any to offer, appreciate it.
    tundra_20 likes this.
  18. Feb 22, 2020 at 5:50 PM
    #228
    OV-1794
    OV-1794 New Member
    @Bob_Wiley
    You could always contact Keith and as long as he hasn't made yours have him dump it and install resonators. Or check local scrap yards
    buddy89 and Bob_Wiley like this.
  19. Feb 22, 2020 at 9:11 PM
    #229
    dyn0mitemat
    Mat
    19 TRD OR
    Instead of the flange, have him put an expanded piece of tubing that slips over whatever size your tailpipe is, and then use a clamp on it. Or weld it
  20. Feb 23, 2020 at 5:13 PM
    #230
    Thomjwilsok
    Thomjwilsok New Member
    Thom
    2013 toyota tundra crewmax
    The standard 8in system comes with a resonator correct? Or do I need to call and ask for that?
  21. Feb 23, 2020 at 5:16 PM
    #231
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Comes with unless you asked specifically not to include.
    buddy89 and focal like this.
  22. Feb 23, 2020 at 5:30 PM
    #232
    Thomjwilsok
    Thom
    Awesome, thanks.
  23. Feb 24, 2020 at 7:18 PM
    #233
    DR132
    DR132 New Member
    ALASKA
    2014 Tundra CM Platinum Blue Ribbon Metallic
    AWD Conversion, BAMuffler 8", Custom tuned with HPTuners, 2018+ LED Headlights, TRD front and rear sway bars
    +1 order in as of this afternoon :burnrubber:
    focal, somadbamos, buddy89 and 2 others like this.
  24. Feb 26, 2020 at 2:06 AM
    #234
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    I JUST bought that one! I recommend it!
    tundra_20 and focal[QUOTED] like this.
  25. Feb 26, 2020 at 2:08 AM
    #235
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    You can also use a regular drill bit. Just drill holes along the outside of your circle, light hammer tap will knock out the center.
  26. Feb 26, 2020 at 8:03 AM
    #236
    focal
    Nikolai
    VA / NC
    Good deal! I also ordered one and am actually on the way to pick it up from Home Depot now (it was the cheapest with ship free to store).
  27. Feb 26, 2020 at 8:21 AM
    #237
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Assuming this doesn't include the TRD Replacement system?
  28. Feb 26, 2020 at 8:27 AM
    #238
    daays
    daays New Member
    So what’s the total price on a SS system with over 50 orders?
  29. Feb 26, 2020 at 8:28 AM
    #239
    dspilot
    North Mississippi
    I paid $799 for the 8” SS.
  30. Feb 26, 2020 at 8:31 AM
    #240
    daays
    daays New Member
    Thanks! Might have to sit this one out, just bought Method Grids. My wife would have my head if wheels and an exhaust showed up. Some day though!
    19h341 likes this.
Thread Status:
