BAmuffler 8 vs 10 with resonator
Discussion in 'Performance and Tuning' started by Robster80, Nov 8, 2021.
  1. Nov 8, 2021 at 3:51 PM
    Robster80
    Robster80 [OP] New Member
    Has anyone had or heard both 8 and 10 with resonator on? Put resonator on my 8 and its much better but still theres a a bit more deep noise in cabin than i prefer. Mainly on roads with slight inclines or part throttle crusin thro town (1100-1200 rpm). Curious how quieter the longer muffler (10-14) would be in these scenarios as im definitelt contemplating swapping to somwthing different sizewise
    dirtydeeds likes this.
  2. Nov 8, 2021 at 3:55 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Give dirty deeds a call, Keith is great at explaining the differences.
  3. Nov 8, 2021 at 11:09 PM
    CMikeB
    CMikeB New Member
    I just traded Keith my 10" system for his 14",both with resonator. After having the 10" for several years, my hearing loss was making conversations difficult while pulling hills, especially towing. Add that to the fact that I'm getting old and grouchy, the 10" was getting intrusive.While the 14" system will NEVER be mistaken for "stock", either at idle, cruising or most certainly at higher RPM's, it's more subdued with no raspy "bark" at cold-start. Trading my 5-6 year old system back to Keith for a $ 220.00 total (for shipping) was a no brainer, especially when Keith and Shawna are so great to deal with!
  4. Nov 9, 2021 at 4:26 AM
    Robster80
    Does it still sound great when u romp on it? I figured i would probably need a 12” or 14”
  5. Nov 9, 2021 at 4:37 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I'd love to hear a sound clip of that 14". Feel free to post one. :D
  6. Nov 9, 2021 at 4:54 AM
    CMikeB
    CMikeB New Member
    Absolutely! Like I said, no matter where the RPM's are, my 14" system won't be mistaken for stock, you'd have to be a heck of a lot more deaf than I am to not hear that. I lost the 'love' for the raspy bark at cold start.The interference in conversations, because of my nerve damaged hearing is another reason it had to be 'toned down.'
    dirtydeeds and Blue Thunder like this.
  7. Nov 9, 2021 at 5:02 AM
    CMikeB
    CMikeB New Member
    I'll post a video later today.:thumbsup:
    dirtydeeds and 17TundraDCEd like this.
  8. Nov 9, 2021 at 6:00 AM
    Robster80
    Yeah id love to hear a clip if u dont mind. Actually the resonator tamed the loud cold start alot. Its just that deep hum at times thats a bit too much for me
  9. Nov 9, 2021 at 6:54 AM
    CMikeB
    CMikeB New Member
    Doesn't look like I'm able to send video, "The uploaded file does not have the allowed extension." What am I doing wrong?
  10. Nov 9, 2021 at 7:04 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    I think you have to post it on YouTube and then copy the YouTube link into your reply here.
    My wife had to do the YouTube part for me because I didn’t have an account.
  11. Nov 9, 2021 at 7:37 AM
    3jet3
    3jet3 New Member
    FL
    2021 Tundra TRD
    ----Suspension---- 6112 Bilstein Front 5160 Bilstein Back 3 CB .5" Shims(2 driver side, 1 passenger) CB 3+ Shackles Differential Drop kit Carrier Drop kit ----Wheels---- Tires - Falken WildPeak A/T- 295 70 18 Wheels - Raceline Gauge 18" ----Accessories---- GoRhino RB20 Running Boards
    I just ordered the 8". Hopefully its not too loud. Website side 8" was mild, and 10" was quite?
  12. Nov 9, 2021 at 7:39 AM
    MadMaxCanon
    from the way keith explained it, they arent all that different from each other, more same than different, you really only notice the differences when you get on it.
    dirtydeeds and 3jet3[QUOTED] like this.
  13. Nov 9, 2021 at 7:41 AM
    3jet3
    3jet3 New Member
    FL
    2021 Tundra TRD
    Okay good to know! I will post videos as soon as I install.
  14. Nov 9, 2021 at 7:46 AM
    18" TRD Off Road Wheels
    You guys should specify if you are on the dual systems that replace the TRD exhaust or the singles as well. The single pipe 10" is what is usually recommended for towing and such because it isn't as intrusive when under load, but the 10" on the duals is still loud, IIRC. To get the duals quieter you have to get into 12"+ but that would be really quiet on a single.
  15. Nov 9, 2021 at 8:30 AM
    Robster80
    I wouldnt call it loud whatsoever. It sounds incredible. My only dislike is some of the resonance u get in cab while at certain rpms or inclines
  16. Nov 10, 2021 at 6:42 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Did you drill the hole for the resonator? It makes the drone go away. There’s a little sound still, but not drone. Also, did you cut the tailpipe by chance?
  17. Nov 10, 2021 at 8:09 AM
    CMikeB
    CMikeB New Member
    I have it on You Tube but my limited mental capacity doesn't allow me any further action, chime in with instructions if you get time.
  18. Nov 10, 2021 at 8:24 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    have two tabs open: one will be your YouTube and the other will be tundras.com where you’re trying to post the reply or post the link. Open up the video in YouTube and at the very top where you have the URL which is just the address for your YouTube video you can right click on that and then click on copyThen click on the tundras tab go to the reply area right click again and hit paste that should put the link there and then you can just post reply
  19. Nov 10, 2021 at 10:33 AM
    CMikeB
    CMikeB New Member
    17TundraDCEd likes this.
  20. Nov 10, 2021 at 12:19 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Happy I could help. Still sounds pretty healthy in the video you posted.
  21. Nov 10, 2021 at 12:20 PM
    Robster80
    Yeah i drilled the resonator hole. Was careful and precise in the whole install. But sorta wondering if i did something wrong now lol
    dirtydeeds[QUOTED] likes this.
  22. Nov 10, 2021 at 12:23 PM
    9DivDoc
    9DivDoc New Member
    Wisconsin
    2021 TRD PRO CM MGM 2021 SKM CM Limited
    Good to know & thanks...another old & grouchy so 14" sounds like the way to go...for me anyway...muchos gracias
  23. Nov 10, 2021 at 12:24 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    If the exhaust turns real quiet at around 65 mph and up in 6th gear while maintaining speed with little to no load - then you did it right. Below that speed, you'll still hear some exhaust tone - which isn't necessarily drone.
  24. Nov 10, 2021 at 12:26 PM
    Robster80
    Oh yea pretty quiet at that speed. I can hear the exhaust but not too obtrusive. It just gets noisier than i like when theres any incline in the road and at some lower rpms in city driving
  25. Nov 10, 2021 at 12:33 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Sounds like you installed the resonator correctly and it’s doing its job. You may prefer longer canisters to lower the overall sound.
  26. Nov 10, 2021 at 1:46 PM
    Robster80
    yeah maybe that 12”. Gonna give Keith a call
  27. Nov 17, 2021 at 9:57 AM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Keith I'm curious how much sound will i lose or possible performance installing the resonator? I currently have the 10 inch, and after a road trip over the mountain pass this last weekend I'm debating installing my resonator just don't want to lose performance but would like less drone. Thanks
  28. Nov 17, 2021 at 11:04 AM
    dirtydeeds
    Keith
    USA
    You won’t lose any performance at all. Just the drone. That’s it. Install it!!!
    Keith 760-877-4234
  29. Nov 17, 2021 at 12:41 PM
    ErikTRDTUNDRA
    Erik
    Will i lose any sound while i have my foot in it?
  30. Nov 17, 2021 at 1:21 PM
    dirtydeeds
    Keith
    USA
    None from outside the truck. But inside will be tamed a bit on the throttle. But more importantly, cruising is way quieter.
