Ball joint broke on the highway....help....
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, Jun 22, 2025.
  1. Jun 23, 2025 at 9:21 PM
    #61
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Always thank the Lord for all circumstances. Bad things happen so we can have a challenge to rise to and to allow us to learn new things.
    I met my wife because I got fired from a job I loved so much I'd have worked for free.
    I got her to fall in love with me 11,000 miles away because I learned lessons from her immediate predecessor who lost interest when I didn't know how to handle internet relationships. On the plus side my wife is low maintenance and works like a Terminator programmed to mow grass.
    You can do this. People here will help.
    My help: get the right power tools for this job. :)
  2. Jun 23, 2025 at 9:30 PM
    #62
    Aerindel
    Aerindel [OP] New Member
    Montana
    So I see you are a firefighter.
    I am also a firfeighter. Captain in fact at this point after 20 years.
    Guess what the very best powertool ever invented (IMO) for removing ball joints is?......that I happen to have access too.....did the job in two seconds.
  3. Jun 23, 2025 at 9:57 PM
    #63
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    One of you tech savy guys print that sticker (OEM or Die) and I'd buy.
    Aerindel[OP] likes this.
  4. Jun 23, 2025 at 10:23 PM
    #64
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Captain? WOW! (Hasty salute!). :p I was a firefighter, volunteer for two years with two different departments. What calls I went on I greatly enjoyed and felt I had some impact. I think it's a great way for someone to serve their community and learn life-saving skills at the same time. With my first department I saw some of the most selfless bravery one could imagine. Those guys were some hard chargers. The chief was exactly the kind of leader every man of action would want to have. (Wow, flood of memories just now).
    What powertool? Car cutter upper from the department crash truck?
    Aerindel[QUOTED][OP] likes this.
  5. Jun 23, 2025 at 10:56 PM
    #65
    Aerindel
    Montana
    Jaws from the crash truck, can apply tons of force, with high precision in a small space.
    If they didn't cost $10,000 dollars I'm sure every mechanic would have them.
  6. Jun 23, 2025 at 11:28 PM
    #66
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Once I put 2 and 2 together (the heat today has thrown my mind off a bit) I realized that is likely what you used.
    Perks of the job! :)
  7. Jun 24, 2025 at 1:26 AM
    #67
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Thats Crazy!!!
    I've never seen anyone break a ball joint even in my many years of offroading!!
  8. Jun 24, 2025 at 2:10 AM
    #68
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I saw the aftermath of such a failure. Sometime last fall, after joining this site and learning about the issue, a guy parked at the lumber area of Lowe's. I walked past, noticed it was a 1st gen. Tundra, missing the driver's outer and inner fenders!
    I spoke with the owner. He said "it just collapsed while sitting at a gas station, tearing the fender off."
    The man didn't know about OEM as a replacement, probably got whatever the garage threw on and he definitely wasn't interested in knowing the timing belt needed changed. SMH. He went on to say "I graduate nursing school this semester and I'll just buy a new truck."
    Clearly a solid plan, sure to keep his debt to a minimum. LOL
    shifty` and Tundra Texan[QUOTED] like this.
  9. Jun 24, 2025 at 4:11 AM
    #69
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
  10. Jun 24, 2025 at 4:11 AM
    #70
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Once I thought about it most of my off roading was done in a Tacoma which is a hell of a lot lighter than the Tundra.
    I'd bet that has a lot to do with it.
  11. Jun 24, 2025 at 4:12 AM
    #71
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    You pulled out the jaws of life to work on the truck? That's awesome! Please tell me you got pictures of that.
  12. Jun 24, 2025 at 4:50 AM
    #72
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Ah...You'd think they could beef up the joint by going with a different material.
    As a Machinist(retired)there's all kinds of stronger materials out there,while it may cost more initially at least you wouldnt run the risk of getting into a wreck and possibly killing yourself or worse someone else.
  13. Jun 24, 2025 at 5:13 AM
    #73
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    I don't have a picture of it, but I'm sure someone does. It's not a matter of material used, but design of the joint. Ours are in constant tension with the weight of the truck trying to rip the joint apart. They flipped the design for the 2nd gen eliminating the issue. They do make a uniball kit that partially eliminates the design, but it's pricey.
    shifty` and Bought2Pull like this.
  14. Jun 24, 2025 at 5:30 AM
    #74
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Either way you're gonna have to either change the design or go with a stronger material.
  15. Jun 24, 2025 at 10:38 AM
    #75
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I think that’s Mevotech Supreme which they are not supreme - more like shit.
  16. Jun 24, 2025 at 10:56 AM
    #76
    Mr Badwrench
    Mr Badwrench New Member
    That's how it seems to go. Everything breaks at the same time whether you have one or 3 vehicles.
  17. Jun 24, 2025 at 12:22 PM
    #77
    MS == MEVOTECH SUPREME. ('supreme' line)
    "Supreme" should clearly be in quotes. But as @The Black Mamba so intelligently reported earlier, the blue boots were also a giveaway it was Mevotech.
    The Black Mamba likes this.
  18. Jun 24, 2025 at 12:27 PM
    #78
    Jack McCarthy
    Jack McCarthy Happy hour; beer goggles, not a fake profile.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Supreme Crap
    G_unit3000 likes this.
  19. Jun 24, 2025 at 2:29 PM
    #79
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    It's a typo. They were supposed to be called Mevotech Subprime.
  20. Jun 24, 2025 at 2:50 PM
    #80
    Aerindel
    Montana
    Woke up today at 9 with a headache. Asked my wife to get my a Tylenol and a Redbull....(caffine and tylenol usually work on headaches)....figured I would read on my ipad for a bit until they kicked in.
    Woke up six hours later. Wife gone to work, dog and cat sleeping ontop of me....guess I was tired.
    TX-TRD1stGEN, bmf4069 and shifty` like this.
  21. Jun 24, 2025 at 2:52 PM
    #81
    Aerindel
    Montana
    On facebook yesterday I was talking with a guy who did the uniball conversion after the originals failed, he then had the uniball fail a year later.
    shifty` likes this.
  22. Jun 24, 2025 at 3:36 PM
    #82
    Aerindel
    Montana
    Trying to take my time today and put together an order with toyota.....can't sign in.....being told the service is down....
  23. Jun 24, 2025 at 3:51 PM
    #83
    Aerindel
    Montana
    Toyota parts says these do not fit my vehicle.
  24. Jun 24, 2025 at 4:31 PM
    #84
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Ok, glad you're getting it under control. I'm down in Beaverhead County.
  25. Jun 24, 2025 at 4:33 PM
    #85
    MT-Tundra
    Montana
    Best thing is to call or email a real person at a Toyota parts dept and give them your VIN. I may have been lucky, but the dealership parts guys in Helena have been great to me, and Ourisman Toyota online parts people have treated me well and always found my parts when I couldn't find them through the website.
  26. Jun 24, 2025 at 4:35 PM
    #86
    Aerindel
    Montana
    I called up Kalispell, the closest parts dealer to me. Put together an order...$400 but it is what it is, Uppers, lowers, bolts, they say they should be able to get it within about 50 miles of me by thursday. Probably could have figured out something cheaper by dealer shopping, but I need to get the truck home, I can spend the rest of the summer figuring out the rest.
  27. Jun 24, 2025 at 5:24 PM
    #87
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Good to hear you’re going oem. Should be problem free for another 100k. As someone mentioned earlier, check you bottom shock bushing. Looked shot in the picture.
  28. Jun 24, 2025 at 6:05 PM
    #88
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    @Shifty is changing the lbj’s at 100k miles for all generations? I have a 2019
  29. Jun 24, 2025 at 6:08 PM
    #89
    Only for trucks with LBJ-under designs. I know it’s a thing on 1st gen tundras and some tacomas. Not sure about your gen of Tundra. The issue is really the extreme load on the LBJ with that design.
    But it’s worth noting, any joint is a wear item. So there is definitely a life span on any joint. U-joint, ball joint, cardan joint, CV joint, steering joint, they all wear over time.
  30. Jun 24, 2025 at 8:13 PM
    #90
    MT-Tundra
    Montana
    $400 ain't nothin when it comes to truck parts. Assuming this gets you back on the road, that's cheap.
    Tundra Texan and The Black Mamba like this.
