Bakflip MX4
Discussion in 'Tonneau Covers, Caps and Shells' started by JPritch22, May 1, 2019.
  1. May 1, 2019 at 8:28 PM
    JPritch22
    JPritch22 [OP] New Member
    2018 TUNDRA SR5 Crewmax
    Bought a Bakflip MX4, had it for a month and it leaks a lot more than I feel it should. Anyone have any experience with these or any ideas to make it leak less? I would just send it back but Bakflip won’t let me
  2. May 1, 2019 at 8:41 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I have the mx4 and it does leak but minimal which I expected. Is it aligned pretty good and back seals all the way back?
  3. May 1, 2019 at 9:23 PM
    What the!?
    What the!? New Member
    2017 Pro
  4. May 1, 2019 at 9:25 PM
    AZTundra
    Paul
    Phoenix, AZ
    Mine leaks just a little at all four corners.
  5. May 2, 2019 at 3:53 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    Same as mine leaks very minimal and even when I drive through car wash.
  6. May 2, 2019 at 6:37 AM
    JPritch22
    I expected it to leak at the tailgate a little just due to the function of the cover. I have it pulled back as far as I can on the tailgate without exposing the front of the bed. Mine seems to be leaking at the hinges where it folds. I’m going to try to look at it this weekend and see if I can figure out a way to make it better.
  7. May 2, 2019 at 6:44 AM
    gman31
    gman31 New Member
    New Orleans
    Mine leaks horribly. I expect it to leak a little from the corners, but mine leaks like a waterfall from the sides. I tried adjusting it which didn't help. A waste of money if you ask me. I had a G2 on my last truck which worked as expected.
  8. May 2, 2019 at 6:54 AM
    gman31
    gman31 New Member
    New Orleans
    Video wouldn't load.
  9. May 2, 2019 at 6:55 AM
    gman31
    gman31 New Member
    New Orleans
    Pic was taken after lightly spraying it with a hose.
  10. May 2, 2019 at 7:07 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Looks like it is leaking between the side rail and bedside cap. Mine leaks there too, but not to the degree shown in your pic. I've considered removing it and applying a thin bead of black caulk between. I might have to do it this weekend and report back.
  11. May 2, 2019 at 7:49 AM
    JPritch22
    Gman31 that’s actually worse than mine leaks but not by much. It shouldn’t leak this bad considering what they cost
    gman31 likes this.
  12. May 5, 2019 at 6:20 AM
    JPritch22
    Hammerhead, mine was doing the same thing except I only had mine for a few weeks. I contacted them Friday and are supposed to be sending me a new one as well. Hopefully the next cover doesn’t do the same thing.
  13. May 9, 2019 at 12:25 PM
    JPritch22
    Got my new cover put on. The rails are different than the previous ones. The seals look a lot better on the folding hinges and overall seems like a much better product than the first one. Supposed to rain this weekend so we’ll see if it’s better.
  14. Jun 24, 2019 at 3:26 PM
    dirtbikedad
    dirtbikedad New Member
    I bought one a year ago. Leaks, they sent me new one and its to short for the truck bed! they swear its the correct length. I even sent them pictures. The cover is an inch and a half shorter than the old one.
  15. Jun 24, 2019 at 4:10 PM
    learnem
    learnem New Member
    Bakersfield, Ca
    16 Tundra crewmax
    3 in lift, 2in wheel spacers. Tinted all the way around Stock platinum wheels and tires
    What model truck do you have?
    Length of bed?
    I would make them pay to ship back.
  16. Jun 24, 2019 at 4:17 PM
    dirtbikedad
    2007 crewmax. Bed is 66” and they sent a replacement cover that’s only 64.5”. The old cover is 66”. They swear that’s the correct length. They are full of crap.
