BAKFlip MX4 Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by 2012TundraGRK, Oct 30, 2019.
  1. Oct 30, 2019 at 11:08 PM
    2012TundraGRK
    2012TundraGRK [OP] New Member
    Hi everyone, I am new to this forum, but looking for some help/advice.
    I have a 2012 Tundra Double Cab and recently installed a BAKFlip MX4 Tonneau Cover. Everything installed very easily, but I now noticed that my tailgate does not close flush like it did before. However, it closes easily, not under tension.
    Has anyone had this same problem? Any recommendations or advice to fix this problem?
    Thank you!
  2. Oct 31, 2019 at 4:23 AM
    War Machine
    War Machine SSEM # 5 3MW
    I’d guess the rails are too far back?
  3. Oct 31, 2019 at 6:22 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    That pic doesn't show us much.
  4. Oct 31, 2019 at 6:52 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just move everything forward, tail gate hitting the cover, the cover not even close
  5. Oct 31, 2019 at 6:53 AM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    I have the same cover and the side rails need to be moved forward. Simple fix
  6. Oct 31, 2019 at 9:37 PM
    2012TundraGRK
    Thank you everyone. The rails are pushed back as far as possible, but the tailgate is still not flush. The more I examined everything, it seems like my bed liner is just slightly too thick on both the back part of the bed, as well as the liner over of the actual tailgate.
    I believe I would either need to cut out the bed liner where the trifold rails touch the liner, or, I would need to trim the end of the rails about 1/4” to make up the difference.
    Any suggestions?
  7. Nov 1, 2019 at 6:05 AM
    azTony
    Tony
    Sun Lakes, AZ
