Bakflip and Cargo Divider
Discussion in 'Tonneau Covers, Caps and Shells' started by HBdirtbag, Mar 22, 2017.
  1. Mar 22, 2017 at 5:18 AM
    HBdirtbag
    HBdirtbag [OP] New Member
    Walnut Creek, CA
    2017 limited cm
    Anyone here using a bakflip (specifically MK4) and still able to use the OEM cargo divider?
  2. Apr 11, 2017 at 2:17 PM
    NoDak
    NoDak New Member
    2017 Tundra TRD Pro CM - Super White
    I was wondering the same thing. I've talked to the dealership and they can't tell me. I don't want to spend 380.00 on something that won't fit.
  3. Apr 11, 2017 at 2:51 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I wanted to do the same but it doesn't look like it will fit because the MX4 drops the util rail pretty low.
    If you want a cover that works with the divider, look at the ones that don't relocate the util rail.
    ChucklesToy likes this.
  4. Apr 11, 2017 at 3:20 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    What I ended up doing is getting the bed extender and using it as a divider when it's folded In.
  5. Apr 11, 2017 at 3:31 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    undercover flex doesn't relocate. but the knobs will hit the cover.
    oem tie downs won't fit unless you do a wing nut mod to them.
  6. Apr 11, 2017 at 3:32 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Which means that the divider will most likely not fit huh...
  7. Apr 11, 2017 at 3:36 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Yeah knobs for divider are almost flush with bed rails. Only covers that would work are ones that sit on top
  8. Jul 18, 2017 at 9:41 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Did you by chance ever try this setup? i still want a divider if it can work on my MX4
  9. Jul 19, 2017 at 6:51 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    I haven't, it's an expensive "experiment"
  10. Jul 19, 2017 at 7:48 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
  11. Jul 19, 2017 at 4:18 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
