Bak Revolver x2, who has one?
Discussion in 'Tonneau Covers, Caps and Shells' started by Njmike13, Jan 13, 2018.
  1. Jan 13, 2018 at 2:07 PM
    Njmike13
    Njmike13 [OP] New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Narrowed down my search to the revolver x4. It should be available soon. Anyone have an X2? How do you like it? I'm more interested in what you don't like.
    -Mike
    eccracer104 likes this.
  2. Jan 13, 2018 at 2:30 PM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    I have one. Fit and finish is nice, very easy to install. Not as water resistant at the tailgate as I'd like, but I imagine that could be said of most covers. When it's very cold, I have a hard time rolling it up tight enough to strap down. It usually takes a few tries to get it compact enough to work with the straps they give you. During the warm season, it's super easy. Over all, I have no regrets. I was looking at the diamondback cover as well, but for my use, the roll up makes more sense than having a cross bar in the middle of the bed that I would have to remove to fit big stuff in the bed.
    Njmike13[OP] likes this.
  3. Jan 13, 2018 at 4:23 PM
    Njmike13
    2021 PRO Lunar Rock
    Good info thanks. Bak has an x4 that is about to come out. As far as i can tell the only difference is it's matte black. Just looking for a sale now.
  4. Jan 13, 2018 at 6:08 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I have the x2 on my truck, I love it. My truck is my work truck so I'm am in and out of the bed all day long everyday and it is holding up well so far. Only downfall I could say is when it snowed here last week I was unable to roll the cover because it was iced over.
  5. Jan 13, 2018 at 6:25 PM
    NoDak
    NoDak New Member
    2017 Tundra TRD Pro CM - Super White
    I’ve had mine for over a year. Ditto Jaywhy and Alloutdrs1 regarding the snow and ice affecting roll up, and not being as water tight at the tailgate. In spite of those two issues, I have no regrets. It’s a great cover and the security provided makes it a little harder for some opportunistic POS from pilfering the stuff that I keep in the bed.
    4x4_Angel and Njmike13[OP] like this.
  6. Jan 14, 2018 at 6:06 AM
    Njmike13
    2021 PRO Lunar Rock
    Thanks. Did you guys install it on your own? Did you have to move the factory track system down?
  7. Jan 14, 2018 at 6:07 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I installed my self its really straight forward and easy, if you have the factory rails it does move them down with supplied brackets.
    4x4_Angel and Jaywhy like this.
  8. Jan 14, 2018 at 7:36 AM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    I installed myself as well. Took about an hour and a half, while minding two small children running around and trying to "help". It comes with everything you need to lower the track, asong as you order the correct one.
    4x4_Angel and Sunnier like this.
  9. Jan 14, 2018 at 8:42 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have one as well and I love it. It looks great and works well. It keeps everything pretty dry, some water leaks in at the tailgate but you could find a way to seal it up pretty easily. Install wasn't bad. Moved rails down and got it done in an hour or 2. I have zero complaints. I wash it with regular car wash soap and put on some aerospace 303 to protect it every time i wash.
  10. Jan 14, 2018 at 9:13 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Anyone running a toolbox with this cover? Or some sort of storage with this cover?
  11. Jan 14, 2018 at 9:46 AM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    I have an undercover swing case on the driver's side. Thinking about buying another for the passenger side. They're a bit pricey, but convenient. I do miss the tie down hook that the case eliminated, and am working on a custom solution to replace it.
    4x4_Angel and the_midwesterner like this.
  12. Jan 14, 2018 at 9:57 AM
    Njmike13
    2021 PRO Lunar Rock
    Check out the tool box made by Bak. It's $289 and fits under any of there covers. I think it's called a Bakbox.
  13. Jan 14, 2018 at 11:11 AM
    the_midwesterner
    Luis
    None, yet....
    Realistically, how much room are in those? I’ve kind of thought about getting them but A) I wanted to make sure they fit under a cover and B) they “look” small, but people claim to fit all sorts of crap in them.
    I have a full tool box across the back and I’d like to keep similar storage capacity. I do like that those things take up effectively dead space though. My one concern would be durability Offroad and having it rip through the sheet metal. Any concerns?
    I will look into it, thanks.
  14. Jan 14, 2018 at 1:32 PM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    @the_midwesterner I'm not worried about durability. There's a number of decent size screws holding it in. Feels very solid. As far as space goes, they are small. If you don't mind stuffing it full, it might not be bad, but it's certainly not the same capacity as a real truck box. I *hate* having to move things out of the way to get to other things, so for me, I think they feel even smaller. I keep my ratchet straps and a small tool bag in the one I have, and to me, it's full.
    the_midwesterner likes this.
  15. Jan 14, 2018 at 6:20 PM
    the_midwesterner
    Luis
    None, yet....
    @Njmike13 can you keep this thread posted if you find a deal? I think I'm gonna order one also.
  16. Jan 14, 2018 at 6:27 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I'm looking at this one too, but I'd rather not have to use a wheel chock when I have my dirt bike in the bed.
  17. Jan 14, 2018 at 7:52 PM
    scjb007
    scjb007 Big Blue Nation
    Kentucky
    2017 White Platinum
    2018 led headlights and fog lights, Trd pro grill, rc 30in light bar, iron cross hd steps, trd sway bar, trd shift knob, color matched door handles and mirror caps, Linex bed liner, amber marker lights, led cargo lighting, anytime fog mod, VLED footwell lighting, bak x2 revolver, and FRAC.
    This :thumbsup:, except I didn't install mine.
  18. Jan 14, 2018 at 7:58 PM
    Njmike13
    2021 PRO Lunar Rock
    I plan on waiting to see if maybe there will be a presidents day sale somewhere. Price is just about the same everywhere I have checked.
  19. Jan 15, 2018 at 7:39 PM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    I installed mine about a week ago, like it. I’d give the quality a 9/10; one of the side gaskets wasn’t cut square, and there is some excess glue glopped on that I’ll have to remove. Paid $778, after the $50 rebate.
  20. Jan 15, 2018 at 8:45 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    It took me so long to decide on which cover was best for me.
    Mory @ Tonneau Factory gave me the best advice and price. I use mine with a Tracrac too so I specifically needed something just like the X2. If you need your question answered, he is the gentleman to call.
    I love my X2 ... It's never in my way, and I never have to take it off. It is stiff in the cold but it STILL WORKS!!! I did the install, easy as pie.
    Njmike13[OP] and 4x4_Angel like this.
  21. Jan 16, 2018 at 4:06 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Does that Trac rack install down through the stake pockets?
  22. Jan 16, 2018 at 5:03 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Yes.
    You have to drill the plastic and I used a small router to remove what I needed to install the compression blocks for the rails.
  23. Jan 16, 2018 at 5:08 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Thanks, I'm going to look into this. Would be very beneficial to me when I carry ladders instead of always lugging the trailer around.
    Toyotoholic likes this.
  24. Jan 16, 2018 at 5:11 AM
    Njmike13
    2021 PRO Lunar Rock
    The cheapest I have found so far is $929.58. That is for the Revolver X4 on a DC with a rail system. The X4 just came out the difference between the X2 and X4 is the X4 has a matte black finish and the locking tabs are stronger.
  25. Jan 16, 2018 at 5:20 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Try Mory @ Tonneau Factory.
  26. Jan 16, 2018 at 5:26 AM
    Njmike13
    2021 PRO Lunar Rock
    will do. Thanks
  27. Jan 16, 2018 at 6:14 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Also send @eccracer104 a PM. He works for AutoAnything and is providing a forum discount.
    eccracer104 and Njmike13[OP] like this.
  28. Jan 16, 2018 at 7:45 AM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Thanks for the tag! :fistbump:
    Hi :wave:
    Feel free to ask me any questions you have, I can always call Bak to get some answers direct from the source. I can also get you the best deal on it when it's time to place your order :thumbsup:
  29. Jan 16, 2018 at 7:45 AM
    Njmike13
    2021 PRO Lunar Rock
    Tonneau Factory cheapest so far. $899.88.
    2017 DC w/track system.
    Toyotoholic[QUOTED] likes this.
  30. Jan 16, 2018 at 8:56 AM
    Pudge
    CT
    Try autoanything. You can pull up the chat box and beat down the price a little with the person.
