BAK Flip G2 Tonneau Cover Anyone?
Discussion in '1st Gen Tundras (2000-2006)' started by Glock 40, Dec 20, 2020.
  1. Dec 20, 2020 at 8:06 AM
    Glock 40
    Glock 40 [OP] I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
  2. Dec 20, 2020 at 8:12 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Schcoman and Darkness like this.
  3. Dec 20, 2020 at 8:37 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I have no experience with BAK but my Extang isn’t 100% dry; though it doesn’t flood either.
    I think to get a good, dry seal I’d need to add some trim or foam around the corners...
    Torriciano and Glock 40[OP] like this.
  4. Dec 20, 2020 at 8:42 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    caulk & paint can make it what it aint?
    two2cal and Tundra2 like this.
  5. Dec 20, 2020 at 8:48 AM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Keep us posted as to what you decide. I'm looking at the BakFlip MX4 for my '20. The reviews I've read thus far are positive. https://bakindustries.com/bakflip-mx4/2020/toyota/tundra
    For me, an important feature is that it has to allow easy access to haul dirt, gravel, and allow me to load and unload bikes and dog kennel. I've previously had canopies on my former trucks, but this is why I'm avoiding a canopy on the new truck.
    Glock 40[OP] likes this.
  6. Dec 20, 2020 at 8:53 AM
    AZTundra
    Paul
    Phoenix, AZ
    I went with the Bakflip MX4. It does leak a tiny bit mainly at the corners, but nothing major. I've had mine a little over 2 years now and no issues whatsoever. Let me know if you have any questions or need some pictures.
  7. Dec 20, 2020 at 8:59 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I can accept minor water intrusion, maybe even remedy it. BAK also offers a couple of other models for the gen 1 that incorporate fiberglass. The one I linked is aluminum. Not sure I see much advantage to fiberglass.
  8. Dec 20, 2020 at 9:07 AM
    AZTundra
    Paul
    Phoenix, AZ
    Fiberglass probably won't ding like the aluminum.
    Tundra2 and Glock 40[QUOTED][OP] like this.
  9. Dec 20, 2020 at 9:45 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Good point.
    Tundra2 likes this.
  10. Dec 20, 2020 at 12:15 PM
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    TRD Sway bar, Lomax Tonnueau cover, Bed rug, Havoc HS2 Steps, Tech 12 Volts stereo upgrade, Yakima bed extender, misc trim and bling,
    A lot and I mean a lot of good choices out there. I went with this for similar reasons, a little security, only get a dribble of water when its sitting still in rain and keeps the snow out.
    https://www.youtube.com/watch?v=aYFQj3mf_V8
  11. Dec 20, 2020 at 1:12 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I looked at their site and tried to enter vehicle. Nothing for gen1 yota.
  12. Dec 20, 2020 at 1:25 PM
    Professional Hand Model
    Hand Protectors
  13. Dec 20, 2020 at 1:33 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I'm leaning toward the F1. That's the most heavy duty core and has the fiberglass skin.
  14. Dec 21, 2020 at 1:20 AM
    Robbob
    Robbob New Member
    2002 wht v6 access cab orig owner
    I’ve had the fibermax for a couple years now on my 02 .
    Leaks a little guess i could fix 1 day.
    Sure is nice to put stuff in the back and not worry about it missing or
    getting ruined .
    Aluminum on the underside does get dinged up if not careful.
    Dif stuff on top frp skin maybe plastic.
    All that flipping forward does get heavy
    After a while from the side.
    Maybe the f1 is lighter.
    Love the full access to the truck bed when flipped all the way forward.
    Wish the snap clips were metal .
    Plastic breaks in the cold im down to one clip.
    Time to order clips or rig something different.
    Beware of other people slamming your tailgate shut with last panel not lifted .
    It Will mess up the weather strip if it happens to many times.
  15. Dec 21, 2020 at 4:11 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    My previously-owned 2015 I have now came with the BakFlip G2 hard cover, quad-fold cover.
    It is durable. Can secure the goods in the bed when the tailgate is locked, keeps the goods inside dry, but...
    DANG, it is heavy to fold back to the window!
    I think the site said it is 250 Lbs. I would probably get 2-3 mpg better without it.
    I had a soft, roll up cover on my Sierra.
    Much easier to work with and easy to maintain. Probably less expensive, too.
    That one came with the truck also.
    Definitely evaluate what works best for you. Pros/Cons to both.
  16. Dec 21, 2020 at 4:16 AM
    War Machine
    War Machine SSEM # 5 3MW
    x2. Same experience over about the same amount of time. One thing I’ll add is that when you get it, take the time to put Cerakote on it. It will keep it looking good longer and make it easy to clean.
  17. Dec 21, 2020 at 4:20 AM
    Haggis777
    SW Michigan
    Good point!
    I use Chemical Guys Bare Bones Dark Shine detailer for the same reason...
    I may need to try Cerakote next!
    https://smile.amazon.com/dp/B001XSJI38/ref=cm_sw_r_cp_apa_fabc_wlj4Fb2G3S91F?_encoding=UTF8&psc=1
  18. Dec 21, 2020 at 4:28 AM
    War Machine
    I haven’t done my entire cover yet, but I did a test spot of Cerakote on mine at the beginning of September. As of two days ago it hadn’t degraded at all.
  19. Dec 21, 2020 at 6:08 AM
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    Bummer, I've been extremely happy with mine, durability and flexibility of loading water toys and traveling.
  20. Dec 21, 2020 at 10:52 AM
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    I don't think there's any folding cover that is waterproof. It just depends upon how much water you're willing to tolerate. For the least amount of water seepage, you have to go with a solid cover (I'm an Undercover fan myself). But I understand the advantages of a folding cover.
  21. Dec 23, 2020 at 7:46 AM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    You just missed bakflips Black Friday and cyber Monday deal. 15% off.
    The only BakFlip folding covers that will fit the 1gen is the G2 and F1.
    I had a G2 on my 07 tundra and I’ve had MX4’s on two others. I’ve had good experiences with them all. Minimal leaking and with a bed mat nothing ever got wet. The leaking was always down the sidewalls of the bed and usually only small drips that would just run under the bed mat.
    I was looking at the F1 for my 05 to replace the leer that’s currently on it.
  22. Dec 23, 2020 at 9:58 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I might be ok with a solid cover, although the folders seem more practical for my uses. I looked at the Undercover site and they have nothing to offer for the 2000 Tundra, solid or folding.
  23. Dec 23, 2020 at 9:40 PM
    Captain Tenneal
    NNV
    Are the beds different between 2000 and 2005? I tried to put in 2000 and nothing came up, but I used 2005 (my year) and I got a hit...
    https://undercoverinfo.com/undercover-classic/2005/toyota/tundra
    Glock 40[QUOTED][OP] likes this.
  24. Dec 24, 2020 at 5:54 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Thanks but I'm not a gamblin' man.
  25. Dec 24, 2020 at 10:11 AM
    jrd347
    jrd347 New Member
    2018 Tundra Limited 4x4
    I had the bakflip f1 and after about 18 months the fiberglass top surface started to breakdown bad they warrantied it out for me and even allowed me to change it to the MX4 model so far so good on that one very little water gets inside my bed. 6.jpg
  26. Dec 24, 2020 at 10:33 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Yikes.... leaning back toward the G2.
  27. Dec 25, 2020 at 9:21 PM
    Sandy01
    Sandy01 New Member
    New Mexico
    2001 Ext cab 4x4
    Very soon
    Love mine.
  28. Feb 17, 2021 at 5:29 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Conclusion:
    Picked up a fiberglass cap from c-list for $350. In excellent condition, lock and closures work well. Struts are nice and peppy. Was off a gen 1 (from factory?)... perfect fit.
    It was a purty metallic teal blue but I sanded it down and gave it the bedliner treatment to match my roof and bonnet.
    [​IMG]2021-02-17_06-13-44 by GhostCreekMine, on Flickr
    [​IMG]2021-02-17_06-12-28 by GhostCreekMine, on Flickr
    [​IMG]2021-02-17_06-13-16 by GhostCreekMine, on Flickr
    [​IMG]2021-02-17_06-11-58 by GhostCreekMine, on Flickr
  29. Feb 17, 2021 at 7:51 AM
    back9k9
    back9k9 New Member
    That's a good lookin' truck!
  30. Feb 17, 2021 at 7:56 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Thanks! It was a sad little panda when I got it. I've done a lot of work to it, still more to go.
    This is the day I picked it up about a year ago from a good friend who was the original purchaser. Truck only cost me a box of my hand tied flies (about $400 worth). Good project vehicle.
    [​IMG]2020-11-19_02-45-42 by GhostCreekMine, on Flickr
