BajaDesigns harness
Discussion in 'Lighting' started by smslavin, Aug 12, 2017.
  1. Aug 12, 2017 at 10:00 AM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    For the life of me, I can't seem to figure this out. Mounted a S8 bar and now I'm trying to wire the harness. I'm not sure how the clips work. Can anyone give me some direction?
  2. Aug 12, 2017 at 10:25 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Slide the rubber grommet onto wire, crimp that silver prong onto wire, slide grommet back down then push silver prong into harness in the spot you want. It should snap into place and the grommet should be pushed in enough to make it water resistant.
    smslavin[OP] likes this.
  3. Aug 12, 2017 at 10:45 AM
    smslavin
    Hudson Valley
    Some stuff
    Ah. I see it now. Thanks.
  4. Aug 12, 2017 at 11:57 AM
    Cfincke
    San Antonio
    Should look like this before inserting into the connector
    CM-LENNY and Bprose like this.
  5. Aug 12, 2017 at 3:05 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    They actually make a special set of pliers for crimping that, but can get by with standard crimpers and/or solder like the above photos. Good luck Sean :thumbsup:
  6. Aug 12, 2017 at 3:48 PM
    smslavin
    Hudson Valley
    Some stuff
