Baja designs harness and hi beam relay connectivity
Discussion in 'Lighting' started by Occidentalis, Oct 7, 2021.
  1. Oct 7, 2021 at 5:03 PM
    Occidentalis
    Occidentalis [OP] Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Hey all,
    Probably missing something simple, but I have two ditch lights I want to hook up without a switch in the cab - I just want them to come on with the high beams.
    The harness has three wires for the switch, Blue, White and Red.
    Blue is trigger right? So I should be able to connect that blue wire out of the relay to a high beam wire, like the green one on the H4 headlight connector thing, and have the lights come on with the high beams.
    https://www.bajadesigns.com/images/LP9 LP6 LP4 Instructions and Warranty.pdf
    https://www.tundras.com/threads/2018-tundra-led-headlight-wiring-info-with-diagrams.16225/
  2. Oct 7, 2021 at 5:12 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I was just looking at another diagram, it sure seems like you would connect 86 to the high beam wire. :popcorn:
