Baja Designs: General Discussion Thread
Discussion in 'Lighting' started by Baja Designs, Oct 14, 2015.
  1. Oct 17, 2017 at 9:07 AM
    #211
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    We recommend 12 gauge for the wiring on our OnX6 and S8 LED Light Bars.
  2. Oct 17, 2017 at 9:10 AM
    #212
    Baja Designs
    Bill
    San Marcos, CA
    I would not use the economy harness included with pairs. With that amount of power draw you will want 12 gauge wiring and relay for extra protection. Here would be the wiring harness for you:
    https://www.bajadesigns.com/products/s8-ir-wire-harness-w-mode-2-bar-max-325-watts.asp
    Note: You will have to purchase a splitter and change the connections to match our Squadrons. The Squadron uses a 2-pin connectors where the S8 uses a 3-pin.
    Baja Mike[QUOTED] likes this.
  3. Oct 17, 2017 at 4:06 PM
    #213
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Thanks! Sure wouldn't want to start an electrical fire under the hood.
  4. Oct 18, 2017 at 7:42 AM
    #214
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    Bailey,
    Any chance of getting light covers/rock guards for the S2 flush mounts, or is there not enough room to snap one on? I would love an amber rock guard for mine haha
  5. Oct 18, 2017 at 8:10 AM
    #215
    Baja Designs
    Bill
    San Marcos, CA
    Randy,
    Unfortunately we won't make Rock guards for the Flush Mounts as there is minimal room to attach the guard. The lip on the flush mount bezel is very small. We do offer Amber lenses!
    https://www.bajadesigns.com/products/Replacement-Lenses.asp
    *S2 Amber Driving/Combo and S2 Amber Wide Cornering lenses will be on the site soon.
    -Bailey, Baja Designs
    bailey@bajadesigns.com
    enter BDForums at checkout for 10% off and $5 shipping to the lower 48!
    www.bajadesigns.com
    stefan702[QUOTED] likes this.
  6. Oct 18, 2017 at 8:30 AM
    #216
    stefan702
    Randy
    Las Vegas
    IG: 702stefan_
    Thanks bro, I figured there wasn't enough room lol
  7. Oct 22, 2017 at 4:15 PM
    #217
    Baja Mike
    South Bay, Ca.
    Ok, so I have an issue.
    I installed the 40" S8 bar and used the Baja Designs wiring harness. I cut the wiring for the secondary backlight switch since I don't want or need it. Using the toggle switch provided in the kit, the light bar turned on no problem. Everything was fine, except that's an ugly switch and I wanted the factory look. So I wired up this switch: https://www.amazon.com/gp/product/B01G1W7YZ4/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 that I bought a few months ago, and it worked. I the button and the bar turned on, the LED lights in the switch turned on. I could even hear the relay working. I turned the light off, everything went off. I pressed the on button again and nothing happened. The bar didn't turn on, the LEDs in the switch didn't work either. I then removed that switch and plugged in the one that came with the wiring harness. Still didn't work. I checked the fuse and it was intact. I even replaced it with a new one just in case. Is the switch not rated for that bar and amperage it draws? Is the relay fried?
    HELP!
    stefan702 likes this.
  8. Oct 22, 2017 at 6:59 PM
    #218
    stefan702
    Randy
    Las Vegas
    IG: 702stefan_
    Wish I could help dude...electrical isn't something I tackle.
  9. Oct 22, 2017 at 7:45 PM
    #219
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    maybe @1UPPER can help! His truck is like a Christmas tree :D in a good way of course!
  10. Oct 22, 2017 at 8:04 PM
    #220
    Cfincke
    San Antonio
    You may try to temporary bypass the relay and power the light directly from the fused power (just to double check that the light is still working). If it does not power on, you will need to double check the ground and power connections. If the light does power on, then the issue would be the relay or the switch, but you said you put the old switch back in. If you have a volt meter you can check the switch wire has power at the relay. If the switch wire has power and the fused power wire has voltage at the relay, then you may need a new relay.
    1UPPER likes this.
  11. Oct 22, 2017 at 9:31 PM
    #221
    Baja Mike
    South Bay, Ca.
    Well I feel like an idiot. I got to work just now and decided to pop the hood and take another look, to make sure nothing came loose/ grounded out. Weeeeellllll.... one of the wires supplying the power wasn’t fully plugged in. It works now.
    Let that be a lesson to ya kids, always check your homework before starting a thread on the internet that’ll make you look like a twit. Guess I should of got more than 4 hours sleep before doing this. Oh well.
    BlueBottle and 4x4_Angel like this.
  12. Oct 22, 2017 at 9:37 PM
    #222
    MotoTundra
    MotoTundra The Ocho
    Don
    No worries. Glad you got it figured out!
  13. Oct 23, 2017 at 8:20 AM
    #223
    Baja Designs
    Bill
    San Marcos, CA
    :cheers:
  14. Oct 23, 2017 at 3:10 PM
    #224
    Baja Mike
    South Bay, Ca.
    Hey Bailey, would that switch that I linked still work for long term use even thought the wiring to it (about 3") isn't the same gauge as the rest of the harness?
  15. Oct 23, 2017 at 3:32 PM
    #225
    Baja Designs
    Bill
    San Marcos, CA
    I haven't personally used those switches so I can't say how the quality is but one thing I just noticed is they're rated at 3.0 Amps. All of our upgraded harnesses have switches rated at 30A. Even though you're using a relay the switch is seeing some load. How much? I'm not exactly sure but It's significantly reduced compared to a no-relay setup.
  16. Oct 23, 2017 at 8:56 PM
    #226
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    what fog lights for my 2017 tundra? I looked at ur webaite but i cant figure it out.
  17. Oct 24, 2017 at 8:10 AM
    #227
    Baja Designs
    Bill
    San Marcos, CA
    Take a look at our compatible Squadron Series LED Aux. Lights!
    www.bajadesigns.com
    Squadron Sport, PAIR - $206.95
    https://www.bajadesigns.com/products/Squadron-Sport-LED-Light-Pair.asp
    1800 Lumens each - 20W/1.4A
    Squadron Pro, PAIR - $386.95
    https://www.bajadesigns.com/products/Squadron-Pro-LED-Light-Pair.asp
    4900 Lumens each - 40W/3.5A
    What kind of driving are you doing at night or plan on doing with the truck? Happy to figure out the best lens/pattern combination for your application.
    Don't forget to enter BDForums at checkout for 10% OFF and $5 shipping to the Lower 48!
  18. Oct 24, 2017 at 8:17 AM
    #228
    fisherman951
    Tony
    2017 crewmax 4x4
    Just city driving i just want something bright. I see the links are they plaug and play or what else do i need?
  19. Oct 24, 2017 at 8:49 AM
    #229
    Baja Designs
    Bill
    San Marcos, CA
    The Squadron Sport in Wide Cornering (Amber or White) would be considered street friendly (not street-legal) and will provide at least 2-3x the usable light over OEM. We have many customers running these without issues and the kit is 100% Plug and Play when you purchase the following:
    https://www.bajadesigns.com/product...-Current-Tundra-14-Current-Fog-Pocket-Kit.asp
    Here is a nice DIY by forum member @MotoTundra
    https://www.tundras.com/threads/diy-baja-designs-squadron-r-sport-14-mount-kit-bezel.15967/
    MotoTundra likes this.
  20. Oct 24, 2017 at 9:58 AM
    #230
    MotoTundra
    MotoTundra The Ocho
    Don
    If you want great quality plug and play bright lights, the Squadron's will not disappoint. They are bright, very bright.
    My retro's light up well enough for city driving so I reserve my Squadron's for back roads when there's nothing oncoming or inclement weather. It's unreal how much they light up the night.
  21. Oct 24, 2017 at 10:20 AM
    #231
    Cisko213
    Cisko213 New Member
    So Cal
    2016 Tundra TRD Pro
    Retrofit Headlights, Baja Design Fogs
    I have the combo sport kit and it is perfect. Won't disappoint. Make sure to get the bezel kit with it. This set up integrates with your stock switch but won't be able to use when your high beams are on. I think I might install a bypass switch to do this.
  22. Oct 24, 2017 at 12:26 PM
    #232
    Baja Designs
    Bill
    San Marcos, CA
    NEW Products! Squadron-R and XL-R Rock Guards!
    Hey Everyone! We are excited to offer Rock Guards for our Squadron-R and XL-R series lights. These will work with the Round models and are available in Clear, Black, and Amber.
    Don't have a Round light? No problem! We have a wide variety of protective Rock Guards:
    https://www.bajadesigns.com/Products/Light-Covers-Rock-Guards.asp
    Squadron-R (Round) Rock Guards
    - Black (sku 668007) - $9.95ea
    https://www.bajadesigns.com/Products/squadronr-rock-guard-black.asp
    - Amber (sku 668009) - $9.95ea
    https://www.bajadesigns.com/Products/squadronr-rock-guard-amber.asp
    - Clear (sku 668008) - $9.95ea
    https://www.bajadesigns.com/Products/squadronr-rock-guard-clear.asp
    XL-R (Round) Rock Guards
    - Black (668011) - $10.95
    https://www.bajadesigns.com/Products/xlr-rock-guard-black.asp
    - Amber (668012) - $10.95
    https://www.bajadesigns.com/Products/xlr-rock-guard-amber.asp
    - Clear (668010) - $10.95
    https://www.bajadesigns.com/Products/xlr-rock-guard-clear.asp
    Don't Forget! Enter BDForums at checkout for 10% OFF and $5 shipping to the Lower 48.
    www.bajadesigns.com
    Baja Mike likes this.
  23. Oct 24, 2017 at 12:37 PM
    #233
    Red@9k
    Red@9k New Member
    Erik
    2015 Super white Crewmax Tundra
    Anyone have any pics of the flush mount s2Pro's installed on the OEM rear end caps?
    BlueBottle likes this.
  24. Oct 24, 2017 at 5:35 PM
    #234
    stefan702
    Randy
    Las Vegas
    IG: 702stefan_
    Let me give a shout out to Steven and Bailey for their customer service!! They went above and beyond! You guys rock! :)
    Baja Designs[OP] and MotoTundra like this.
  25. Oct 24, 2017 at 5:59 PM
    #235
    stefan702
    Randy
    Las Vegas
    IG: 702stefan_
    Hey dude if you check the last page of my build I have S2 Sports in the black plastic of my rear bumper.
  26. Oct 24, 2017 at 7:36 PM
    #236
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    The squadron sports should outshine those though. Has double the led counts.
    Red@9k[QUOTED] likes this.
  27. Oct 24, 2017 at 8:01 PM
    #237
    Cisko213
    Cisko213 New Member
    So Cal
    2016 Tundra TRD Pro
    how do i find your build post
  28. Oct 25, 2017 at 8:09 AM
    #238
    Baja Designs
    Bill
    San Marcos, CA
    Here are a couple pics from @stefan702 build:
    [​IMG] [​IMG]
  29. Oct 26, 2017 at 11:17 AM
    #239
    Baja Designs
    Bill
    San Marcos, CA
    https://www.bestop.com/WinAMillion
    If off-road racing icon Casey Currie wins at the Baja 1000, you could win $1,000,000, his personal, customized Jeep®, or one of ten $5,000 premium product packages from Bestop Premium Accessories Group.
    Grand Prize - One grand prize winner of the drawing will receive $1,000,000 Cash
    First Prize - One first-prize winner of the drawing will receive Casey Currie's personal, customized Jeep ($100,000 Value)
    Second Prize - 10 second-prize winners of the drawing will receive product packages of their choice from Baja Designs, Bestop, Tuffy Security Products, and Currie Enterprises ( up to $5,000 Value)
    If Casey Currie does not win the Baja 1000, 10 consolation prizes will be awarded to promotion entrants drawn randomly. Each prize will be the consumer’s choice of one product from Bestop, Baja Designs, Tuffy Security Products, or Currie Enterprises (maximum retail value of each product $5,000).
  30. Oct 29, 2017 at 7:52 PM
    #240
    fisherman951
    Tony
    2017 crewmax 4x4
    Do you guys have a black friday sale? Want fog lights but not sure if i should wait.
