Baja Designs: General Discussion Thread
Discussion in 'Lighting' started by Baja Designs, Oct 14, 2015.
  1. Jan 10, 2022 at 1:07 PM
    #1261
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    @memario1214
    300BLK[QUOTED] and memario1214 like this.
  2. Jan 10, 2022 at 1:25 PM
    #1262
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    So there is unfortunately no yellow spot lens in the XL size, but there is a driving/combo. We've got some on hand.
    300BLK[QUOTED] likes this.
  3. Jan 26, 2022 at 9:11 AM
    #1263
    cclg041994
    cclg041994 New Member
    Zechariah
    Tundra TRD Off-Road Crewmax
    Do you guys have a harness that's plug n play for the RLT 30"? Planning on buying one for my rack. Also which RLT option has the turn lights, reverse, and brake? I know they all have them but I just want to get one for the sake of safety driving regularly.
  4. Jan 26, 2022 at 9:15 AM
    #1264
    memario1214
    Colton
    Missoula, MT
    I can't speak for BD directly, but can tell you that we have sold a bunch of RTLs, and have never seen a wiring harness. This document should help you select which model you need.
    https://www.bajadesigns.com/images/RTL Series Lights.pdf
    We can also help you out in securing one of these as we do have a few of the RTL-S on hand, and can also order whatever you might need :thumbsup:
  5. Feb 14, 2022 at 9:36 AM
    #1265
    stiffler
    stiffler New Member
    2020 Platinum SSM Tundra
  6. Mar 9, 2022 at 3:43 PM
    #1266
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    SO what ditch lights did you go with? I'm too on the fence with the size.
    Baja Designs[OP] likes this.
  7. Mar 17, 2022 at 9:59 AM
    #1267
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Hey Rawb,
    So for the xl and squadron sport there are a few differences and similarities.
    They both produce 3,150 lumens at 26 watts
    For the XL Sport Driving Combo
    -The XL Sport LED light utilizes our High Speed Spot reflectors providing for a longer bigger beam pattern. The reason is the light is bigger so we use our bigger reflectors allowing for a bigger beam pattern. This helps with higher speeds and just all around more lighting needs with no extra power draw
    For the Squadron Sport Driving Combo
    -Sport utilizes 4 LEDs making it ideal for near field, side/backup and scene lighting application.
    -This light being smaller allows for more placement options around the vehicle.
    Those are the major differences!
    Photo difference below
  8. Mar 17, 2022 at 10:29 AM
    #1268
    Wallygator
    So the coupon code BDForums does not work. Is there is an updated coupon code??
  9. Mar 17, 2022 at 8:55 PM
    #1269
    Cfincke
    San Antonio
    From tacoma world
    Wallygator[QUOTED] likes this.
  10. Mar 17, 2022 at 9:02 PM
    #1270
    Okierunner
    Okierunner New Member
    2020 TRD Offroad Crewmax
    Icon UCA Bilstein 6112/5100 Method 17s Ridge Grappler 35x12.50 Trd Dual exhaust
    i cut mine, haven’t found any negative effects so far. Make sure you follow the instructions exactly, the big 3” holes in there have a purpose for airflow.
    bulldog93, AGTundra, YotaBro and 2 others like this.
  11. Mar 18, 2022 at 7:34 AM
    #1271
    Wallygator
    Thanks for posting this. Kind of a bummer though.
  12. May 12, 2022 at 5:42 PM
    #1272
    Burdturger
    Burdturger New Member
    Anyone have some guidance on installing these lights to a switch like auxbeam? Just trying to figure out what exactly would be needed since the BD's have a plug style connector but the auxbeam gets wired directly.
    831Tun likes this.
  13. May 12, 2022 at 7:15 PM
    #1273
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I use these as they mate properly to the BD connectors
    https://www.amazon.com/WEATHER-CONN...i+2+pin+connector,automotive,197&sr=1-18&th=1
    bulldog93 and Burdturger[QUOTED] like this.
  14. Oct 14, 2022 at 3:11 PM
    #1274
    Krusher22plat
    Krusher22plat New Member
    22plat
    Anyone try a 20” OnX6+ Straight LED... install in the lower grill on a 3rd gen? I know the an S8 kit exists for the lower slot but really like the X6. It is a little taller but think with some mods to the opening it should work. Other issue is need to make own brackets and attach to the front crash beam.
  15. Oct 14, 2022 at 7:19 PM
    #1275
    greentrbo95gst
    greentrbo95gst New Member
    Huntington Beach
    Just finished my setup today
  16. Oct 17, 2022 at 8:21 AM
    #1276
    Baja Designs
    Bill
    San Marcos, CA
    Hey greentrdbo95gst, the truck is looking sweet.
  17. Nov 7, 2022 at 8:55 AM
    #1277
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    For the lightbar , did you drill the 3 1/2 inch underneath the hood?
  18. Nov 7, 2022 at 9:00 AM
    #1278
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    just saw the #1273 .
  19. May 22, 2023 at 8:39 PM
    #1279
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Hey BD, what can be done to squadron sports and S2 sports housing’s where the coating has bubbles and chipped off?
  20. May 22, 2023 at 9:12 PM
    #1280
    greentrbo95gst
    Huntington Beach
    I have the same issue.
  21. May 23, 2023 at 11:44 PM
    #1281
    SpeshulED
    hopefully they can chime in with a great option
  22. May 23, 2023 at 11:51 PM
    #1282
    greentrbo95gst
    Huntington Beach
    They did tell me to send them back, but it would be great to have them ship another set and then me ship the damaged ones back so I don't have downtime.
  23. May 24, 2023 at 12:18 AM
    #1283
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Lol
    bulldog93 and AZBoatHauler like this.
  24. May 24, 2023 at 11:11 AM
    #1284
    Baja Designs
    Bill
    San Marcos, CA
    Send those lights in under warranty that are having issues with the powder coating. This is covered under warranty and we will get them replaced for you. You can reach me directly at brandonk@bajadesigns to get this taken care of.
    Best,
    Brandon
  25. May 24, 2023 at 11:24 AM
    #1285
    AZBoatHauler
    So.Arizona
    Pretty good considering most companies won’t warranty powder coat getting from their facility to your door when purchased new.
    AZ Red Nek likes this.
  26. May 24, 2023 at 1:35 PM
    #1286
    greentrbo95gst
    Huntington Beach
    Do you have an option to send new ones and then once the new ones get to me I can send the old ones back? Happy to give you the credit card info for the exchange. I just want to do one shop trip instead of two. Thanks
  27. May 24, 2023 at 1:58 PM
    #1287
    Baja Designs
    Bill
    San Marcos, CA
    Hey @greentrbo95gst, we typically on do a warranty this route within 30 days of purchase. Go ahead and send me an email with the lights you are having an issue with and I will see what I can work out.
    brandonk@bajadesigns.com
    Best,
    Brandon
    bulldog93 likes this.
  28. May 24, 2023 at 2:45 PM
    #1288
    alb1k
    Left Coast
    It's good
    I hope everyone appreciates that Brandon is going way above and beyond for even considering this. It’s why I laughed earlier. BD has the best customer service and product support in the industry. Pretty much every other company would reply politely with nope, and laugh to themselves. Bravo BD.
  29. May 25, 2023 at 12:56 AM
    #1289
    SpeshulED
    I’ve always appreciated what BD does for their customers. I’ve been one since 2015 and living locally to their location they’ve always taken care of me. After BD was purchased by a bigger company I was afraid that this would change but it hasn’t and because of this I’m a life long customer.
  30. Oct 28, 2023 at 12:50 PM
    #1290
    Todd34
    Todd34 New Member
    I've had the same experience. Great customer service. That's harder and harder to find with a lot of other companies these days.
    bulldog93 and Mater like this.
