Baja Designs: General Discussion Thread
Discussion in 'Lighting' started by Baja Designs, Oct 14, 2015.
  1. Feb 7, 2020 at 7:38 AM
    #1141
    Stig
    Stig New Member
    At some point or situation it's probably better to spend your money on a pathfindir II kit rather than adding more and more lumens. You can find good deals on them if you're patient.
    Just throwing this out there. Not sure why more people don't run one after spending $3k on lighting
    smslavin and HulkSmurf14 like this.
  2. Feb 21, 2020 at 4:57 PM
    #1142
    Stig
    Stig New Member
    Does the wire harness that comes in the plug and play fog light kit use a male or female connector on the end opposite the h11 connector?
    Reason for asking, I want to plug into the factory fog light harness but didn't buy the complete install kit. I only have the brackets and glare shield. The connector on the fog lights is female but all the premade h11 adapters I'm finding are also female when I need male.
    Or am I missing something. Might just buy the female cable and cut it off then crimp on the male connector.
  3. Feb 21, 2020 at 7:48 PM
    #1143
    satosan
    satosan New Member
    Garden State(NJ)
    2016 MGM SR5 Crew cab
    for amber ditch light which one do you suggest? I'm leaning towards the xl sports wc. any pics?
  4. Feb 21, 2020 at 8:45 PM
    #1144
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Yellow outside lights are sports wired to factory fog switch. Middle 3 lights are pros that I had previously mounted and relocated from the ditch light position.
    Pocket kit adapters were long enough and so was the included squadron harness along with short splitter :thumbsup:
    Jman245 and drobb like this.
  5. Feb 26, 2020 at 4:14 AM
    #1145
    Stig
    Stig New Member
    Installed BD Squadron sports with Amber wide cornering last night. Light output is much better than I was hoping for. Any pictures or videos just doesn't show how it is in real life
    Think I'm good for night driving with my RX350 projectors, BD fogs and FLIR
    smslavin likes this.
  6. Apr 17, 2020 at 5:30 PM
    #1146
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Protect Your Investment With Security Hardware!
  7. Apr 18, 2020 at 5:42 PM
    #1147
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    What’s the best way to de-pin this harness??
  8. Apr 20, 2020 at 10:02 AM
    #1148
    Baja Designs
    Bill
    San Marcos, CA
  9. Apr 24, 2020 at 3:18 PM
    #1149
    Baja Designs
    Bill
    San Marcos, CA
    NEW PRODUCT ALERT: Universal S1 Moto Kits
    We are proud to announce the most versatile motorcycle lighting option we have ever conceived. With our recent launch of the S1, we were ready to take advantage of the versatile, light weight and powerful S1 performance. This kit will mount to nearly any motorcycle with our fork bracket clamp design. The fork bracket along with the S1 standard bracket can be mounted in various configurations to accommodate your setup. Using an EPDM rubber material in between the mounting surfaces, worries about scratching the bike are nonexistent. Wiring is a breeze with only a handlebar switch, battery leads, splitter, and a headlight plug. For non-electric start EFI bikes, we will offer this kit without a harness and a bike-specific plug and play harness will need to be purchased separately.
    50-7096 | S1, Moto Kit, Spot
    50-7097 | S1, Moto Kit, Driving/Combo
    These two options are available for all battery-powered dirt bikes which includes our 64-1049 Universal Wiring Harness & Switch which leads connect directly to the battery terminals.
    50-7086 | S1, Moto Kit, Spot w/EFI Kickstart
    50-7087 | S1, Moto Kit, Driving/Combo w/EFI Kickstart
    n0rth likes this.
  10. Apr 28, 2020 at 4:33 PM
    #1150
    Baja Designs
    Bill
    San Marcos, CA
    Sharing a little Toyota love :bowdown:
    n0rth, toyota tom and smslavin like this.
  11. May 1, 2020 at 8:11 PM
    #1151
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Is anyone running the LED rock or dome lights as under hood lights?
    Baja Designs[OP] likes this.
  12. May 5, 2020 at 1:49 PM
    #1152
    Baja Designs
    Bill
    San Marcos, CA
    We have many people use our rock lights and dome lights for this purpose. :) Unfortunately, I don't have any pictures of a Tundra example but hopefully someone can share their install. There's a power and ground coming out of either light. Some guys like to use the dome light because it has a switch built in and they save their in cab switch slots. But all you need to do is put 12v power to it and mount it.
    Damie Street[QUOTED] likes this.
  13. May 6, 2020 at 10:35 PM
    #1153
    Damie Street
    Edsel
    South Carolina
    Can you post pics of a Tacoma or anything? Would like to see. Not sure if one light would be enough or if I would need to mount two lights.
  14. May 7, 2020 at 2:05 PM
    #1154
    Baja Designs
    Bill
    San Marcos, CA
    Unfortunately, I don't have anything at my finger tips at the moment. They offer 180 degree beam so it's a decent coverage. I personally run one in my cab, and I feel like it's a perfect amount in a mid size truck. For under the hood, I would try one first.
    Check out our video where we use it multiple applications. https://www.youtube.com/watch?v=eYzeQMKWH-Y&feature=youtu.be
    Flyinryank and Damie Street like this.
  15. May 7, 2020 at 2:54 PM
    #1155
    Damie Street
    Edsel
    South Carolina
    Appreciate it. Yeah I think one with work.
  16. May 8, 2020 at 2:20 PM
    #1156
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Hi,
    I’ve already sent an email regarding my issue. I was just wondering if there is anything that can be done with this coating issue I have on some of my S2 sports and squadron sports.
    thanks!
    574004CE-96C8-413F-9341-FF744C410371.jpg F8E2E100-7527-4B7D-9220-B71DF37D7757.jpg 002F68C9-0182-4C3E-9735-9670CE43FC4E.jpg
  17. May 8, 2020 at 2:28 PM
    #1157
    Baja Designs
    Bill
    San Marcos, CA
    It looks like there's corrosion forming under the powder coat. We can definitely get this covered under our limited lifetime warranty and make them look like new again. PM inbound. Thank you!
    Amnesiac, Sephon and AZBoatHauler like this.
  18. May 20, 2020 at 10:49 AM
    #1158
    Baja Designs
    Bill
    San Marcos, CA
    For those Tundra owners that may have a (19-on) KTM 790, we just released a new kit!
    NEW PRODUCT ALERT: KTM 790 (19-On), Dual Auxiliary Light Kits
    Spice your KTM 790 up with a lighting kit from Baja Designs! This kit includes everything you need such as wiring, lights, bracketry, and hardware. This kit utilizes our S1 series or Squadron series, and will provide ample performance for any adventure you're on. Installation is a breeze, and the fitment is second to none!
    387001 | KTM 790 (19-On), Dual S1 Kit
    497004 | KTM 790 (19-On), Dual Squadron Pro/Racer Kit
  19. May 25, 2020 at 6:38 PM
    #1159
    Stig
    Stig New Member
    I do wonder how many here ride a 790...
  20. Jun 3, 2020 at 10:52 AM
    #1160
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Put on a month and a half ago and no more that 10 hours of use, it that, and two LED’s on my squadron sports are out.......bummer.
  21. Jun 3, 2020 at 10:56 AM
    #1161
    Baja Designs
    Bill
    San Marcos, CA
    Hi Tundracollector,
    I apologize you're experiencing issues with your Squadron Sport, I'll make sure you're well taken care of with my technical/warranty department. PM inbound.
    -Paul M.
  22. Jul 24, 2020 at 4:34 AM
    #1162
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    I am on the website about to order the squadron SAE amber. Are they only available in wide cornering???
    For some reason I thought there were other output options besides wide cornering..
    Thanks
  23. Jul 24, 2020 at 9:22 AM
    #1163
    Baja Designs
    Bill
    San Marcos, CA
    That is correct, that is the only SAE certified setup we have in the Squadron which allows you to turn on the lights on public roads.
    toyota tom[QUOTED] likes this.
  24. Jul 25, 2020 at 10:39 AM
    #1164
    SpeshulED
    Can you tell me the size/spec of both these mounting bolts?
    Thank you.
  25. Jul 27, 2020 at 8:55 AM
    #1165
    Baja Designs
    Bill
    San Marcos, CA
    The bezel bolt is a torx M3x.5x12mm button head. The mounting bolt is an M4 x 25mm flat head socket cap.
    SpeshulED likes this.
  26. Jul 27, 2020 at 9:33 AM
    #1166
    SpeshulED
    thank you!
  27. Jul 30, 2020 at 6:15 PM
    #1167
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    What model is that? size? specs?
  28. Jul 30, 2020 at 6:28 PM
    #1168
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Wait.... that's not a bar, is it? It's 16 individual lights?:monocle:
  29. Jul 31, 2020 at 8:49 AM
    #1169
    Baja Designs
    Bill
    San Marcos, CA
    That would be 16 of our S1 lights, not a light bar. :) Here's a data sheet with all of the specifications. https://www.bajadesigns.com/images/S1 Data Sheet.pdf
  30. Jul 31, 2020 at 9:22 AM
    #1170
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Does anyone have recommendations for security bolts? For both the lateral bolts and also the larger bolt that holds the light mount to the ditch light bracket itself. I just got a set of XL's as ditch lights and am concerned about security.
