Baja Designs: General Discussion Thread
Discussion in 'Lighting' started by Baja Designs, Oct 14, 2015.
  1. Nov 13, 2017 at 3:59 PM
    #271
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    well, i prefer metric shit ton.
    guess, i should starting thinking before i type now. wouldn't want to embarrass myself
  2. Nov 13, 2017 at 9:23 PM
    #272
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Where would you mount the XL80’s?
  3. Nov 13, 2017 at 10:29 PM
    #273
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    A pillars
  4. Nov 13, 2017 at 10:47 PM
    #274
    Eclipsed & Floating
    Voluptuous Whitey
    Squadron Sports (driving combo) in fog locations
  5. Nov 14, 2017 at 11:37 AM
    #275
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
  6. Nov 14, 2017 at 3:40 PM
    #276
    Eclipsed & Floating
    Voluptuous Whitey
    @Baja Designs @BlueBottle @dcsleeper408 @joonbug
    Mounted the S2 PROs on my A Pillars and Squadron Sport work/scene lights as reverse and overall visibility lighting.
    A couple little hiccups I'm having to remedy. The leads to the ditch light locations are about 10 inches short of ensuring all connections are under the hood but I made it work. Also, I failed to order wiring long enough to make it to the bed rack lights but easily solved that problem by grabbing a 12 foot extension. Final product should be complete the day the wire arrives. I could've made my own but it would cost the same amount money by the time I purchased all the supplies I need
    Newm, dcsleeper408, 4x4_Angel and 4 others like this.
  7. Nov 14, 2017 at 4:23 PM
    #277
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Damn u BD whore. Looking good!
  8. Nov 14, 2017 at 6:41 PM
    #278
    Eclipsed & Floating
    Voluptuous Whitey
    DISCLAIMER: terrible location for output shots but these obviously outshine parking lot lighting
    S2 PRO wide cornering output from A Pillar
    Having 5% tint makes turning difficult in my neck of the woods
    MDJK, dcsleeper408, 4x4_Angel and 3 others like this.
  9. Nov 15, 2017 at 4:09 AM
    #279
    Eclipsed & Floating
    Voluptuous Whitey
    I vote squadrons for that location
    TRD15559 likes this.
  10. Nov 16, 2017 at 4:31 PM
    #280
    Baja Designs
    Bill
    San Marcos, CA
    UPDATE:
    Baja Designs is offering Black Friday Cash Back Rebates to retail customers that make a purchase between 11/20/2017 and 11/27/2017! Orders placed directly through Baja Designs, or through authorized dealers are both eligible. Simply place a qualifying order, fill out the rebate form and mail it back with a copy of your invoice within 30 days and we will send you a check for said value!
    Mail to:
    ATTN: Black Friday Rebate
    185 Bosstick Blvd.
    San Marcos, CA 92069
    Please see the below link for more details:
    https://www.bajadesigns.com/home/blackfriday.asp
    Let us know if you have any questions!
    -Bailey, Baja Designs
    www.bajadesigns.com
  11. Nov 16, 2017 at 7:21 PM
    #281
    Eclipsed & Floating
    Voluptuous Whitey
    @sdhq_offroad is an authorized dealer. You could order from them but it's just the same as ordering from BD direct. Both are great resources to help you with your needs. I know from experience
    4x4_Angel likes this.
  12. Nov 16, 2017 at 7:22 PM
    #282
    You can verify with BD, but @sdhq_offroad and @ToyTec Lifts sell them. Both are vendors here.
  13. Nov 16, 2017 at 7:22 PM
    #283
    Eclipsed & Floating
    Voluptuous Whitey
    Anyone know the gauge of wiring used on squadrons or S2s??
    I'm about to get creative :D
  14. Nov 16, 2017 at 7:57 PM
    #284
    BlueBottle
    '16 Platinum 4x4
    See fine print
    These lights only consume less than 2amps each. If you are splicing them together in 1 run, I would use 14ga. If you are running them independantly than 16ga should be fine.
  15. Nov 16, 2017 at 8:03 PM
    #285
    Eclipsed & Floating
    Voluptuous Whitey
    I'll probably get both.
    @BaileyJ do you know if this harness will give me capabilities to utilize squadrons when turning on my brights and independently when necessary? I have the harness. I just haven't decided how to use it yet
    -Upgraded Wiring Harness w/ Longer Leads (Not required but is recommended with the extra length of wire)
    https://www.bajadesigns.com/products/squadron-s2-wire-harness-3-light-max-325-watts.asp
  16. Nov 16, 2017 at 8:11 PM
    #286
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I thought you got the SP? If your running the SP's you don't need those harnesses. You only need to run 1 wire to the SP and ground it to the closest ground to the light. Thats the beauty of SP, simplifies wiring once you install the unit. I believe you can program the light functions of when you can use it. Anytime/ignition/park lamps etc.. @dcsleeper408 programmed his SP and can shed more light.. I said LIGHT! ha
  17. Nov 16, 2017 at 8:15 PM
    #287
    Eclipsed & Floating
    Voluptuous Whitey
    That would still mean a 3 way switch of some sort (unless I'm mistaken) to use the lights under 2 separate functions. I very well could be wrong though. If Mark programmed his to work separately then it would be great to hear him chime in.
  18. Nov 16, 2017 at 8:20 PM
    #288
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    a BJ?
    BlueBottle likes this.
  19. Nov 16, 2017 at 8:23 PM
    #289
    4x4_Angel
    Bree
    Funky Town, Texas
    I feel my truck is inadequate.....
  20. Nov 16, 2017 at 8:25 PM
    #290
    Eclipsed & Floating
    Voluptuous Whitey
    Fixed your spelling, but your truck is incredible. It's hard to judge an above average truck to some guys on here. These guys like @BlueBottle have nothing to do put spend money and play with tools
  21. Nov 16, 2017 at 8:25 PM
    #291
    4x4_Angel
    Bree
    Funky Town, Texas
    o_O this a like "mines bigger than yours" contest....but with lights?
  22. Nov 16, 2017 at 8:27 PM
    #292
    4x4_Angel
    Bree
    Funky Town, Texas
    Thank you and I have no money....that's why no big mods....
  23. Nov 16, 2017 at 8:29 PM
    #293
    4x4_Angel
    Bree
    Funky Town, Texas
    o_O there is!such a thing as TOO BIG
    BlueBottle[QUOTED] likes this.
  24. Nov 16, 2017 at 8:37 PM
    #294
    BlueBottle
    '16 Platinum 4x4
    See fine print
    you guys a hilarious @4x4_Angel @Almaboy .. if I feel like getting a laugh, just have to search your posts...
    Hermel, WatTundra, 4x4_Angel and 2 others like this.
  25. Nov 16, 2017 at 8:48 PM
    #295
    4x4_Angel
    Bree
    Funky Town, Texas
    I'm lacking aparently.
  26. Nov 16, 2017 at 8:50 PM
    #296
    Eclipsed & Floating
    Voluptuous Whitey
    Agreed, but is it fed through an SP?
  27. Nov 16, 2017 at 9:25 PM
    #297
    Not-required
    Not-required New Member
    Kawehi
    2016 MGM Crewmax 4x4 Tundra
    Thule racks, Philips LED headlights and fogs, TRD pro grill and hood buldge, front window tint 35%, ESP under seat storage.
    For my RTL-M I was going to run a SPDT switch and wire it do be turned on with the reverse lights and also activated by itself with a switch.
    Eclipsed & Floating likes this.
  28. Nov 17, 2017 at 8:10 AM
    #298
    Baja Designs
    Bill
    San Marcos, CA
    Please contact us directly at 800-422-5292 if you have concerns a dealer isn't authorized. Like posted above me @sdhq_offroad , @ToyTec Lifts , and others on this forum are Authorized Dealers of ours.
    bailey@bajadesigns.com
    TRD15559 and Eclipsed & Floating like this.
  29. Nov 17, 2017 at 8:12 AM
    #299
    Baja Designs
    Bill
    San Marcos, CA
    XL / LP9 / S8 / OnX6 - 12
    Squadron / S2 Aux Lights - 16
  30. Nov 17, 2017 at 8:16 AM
    #300
    Baja Designs
    Bill
    San Marcos, CA
    The above harness (613600) does have the option for splicing into the OEM high beams or another trigger for the relay.
    Note: @BaileyJ is my personal account. You won't get any lighting responses from that account. Please direct them towards @Baja Designs :thumbsup:
