Baja Designs Fog Lights Not Working
Discussion in 'Lighting' started by Hanzo, Mar 24, 2022.
  1. Mar 24, 2022 at 1:16 PM
    Hanzo
    Hanzo [OP] New Member
    So I installed some BD SAE fogs that I picked up off this forum along with an OEM switch and relay. After putting everything together I cannot get them to come on. I replaced the fuse in the engine bay and have hardwired them to the factory harness (not yet solder in).
    Any suggestions?
  2. Mar 24, 2022 at 1:18 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I would jump them to the battery with the fuse in place to make sure they come on. If they do you know it's wiring
    des2mtn, Hanzo[OP] and jhardy1979 like this.
  3. Mar 24, 2022 at 1:30 PM
    Hanzo
    How do I jump them to the battery with the fuse in place?
  4. Mar 24, 2022 at 1:34 PM
    alb1k
    Left Coast
    It's good
    got any pics?
  5. Mar 24, 2022 at 1:36 PM
    Hanzo
    I don’t, but I can go take some. What would you like pictures of?
  6. Mar 24, 2022 at 1:37 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    to just simply test the light, take your positive (red) and your negative (black) wires that come off of the BD lights and hold them onto the battery with the correlated terminals (positive and negative). If the light works, it'll come on, you don't need to hold it long, just see if it comes on.
    des2mtn and Hanzo[OP] like this.
  7. Mar 24, 2022 at 1:39 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Silly question, but are the lights properly grounded?
    joseph_womack likes this.
  8. Mar 24, 2022 at 1:41 PM
    Hanzo
    Is there an additional ground needed? I have just hooked up the light wires to the factory harness.
  9. Mar 24, 2022 at 1:42 PM
    joseph_womack
    Joe
    Louisiana
    By OEM switch and relay, what do you mean? relay/wiring harness from Baja Designs?
  10. Mar 24, 2022 at 1:43 PM
    des2mtn
    SW
    Tonto cover
    The wiring harness for the lights will have a black wire coming out of it too. That's hooked up? You may may need to put a ring terminal on it.. That wire will need to be fastened to a metal piece of the body, preferably in the engine bay.
  11. Mar 24, 2022 at 1:44 PM
    joseph_womack
    Joe
    Louisiana
    theres a ground right next to the battery in the engine bay, you can ground it there if you haven't already grounded it somewhere else (like the battery)
    des2mtn[QUOTED] likes this.
  12. Mar 24, 2022 at 1:45 PM
    joseph_womack
    Joe
    Louisiana
    (that is if you have a 2nd gen or 2.5 gen- not certain on the 1st or 3rd gens)
  13. Mar 24, 2022 at 1:46 PM
    Hanzo
    I installed a Toyota factory light stalk with a fog light switch to replace my stalk without one and a relay in the factory fuse box location.
    joseph_womack[QUOTED] likes this.
  14. Mar 24, 2022 at 1:47 PM
    joseph_womack
    Joe
    Louisiana
    and you had the factory wiring run down to where the OEM fog lights would be? (meaning your truck already had the factory wiring too or did you add it yourself?)
  15. Mar 24, 2022 at 1:48 PM
    Hanzo
    I called BDs customer support and the service rep told me all I need to do is connect the two light wires to the two harness wires. Is this incorrect?
  16. Mar 24, 2022 at 1:48 PM
    alb1k
    Left Coast
    It's good
    I think take pics of everything. Does your harness look like this?
  17. Mar 24, 2022 at 1:49 PM
    Hanzo
    My truck was prewired
  18. Mar 24, 2022 at 1:49 PM
    joseph_womack
    Joe
    Louisiana
    yes that is correct, however you could have the wires connected backwards, did you check polarity (positive and negative) of the wires before adding the lights?
    des2mtn likes this.
  19. Mar 24, 2022 at 1:51 PM
    Hanzo
    I tried all possible combinations of wiring just to check and no luck. Right now I have white to white.
  20. Mar 24, 2022 at 1:52 PM
    joseph_womack
    Joe
    Louisiana
    Ok double check the lights work by touching the wires coming out of the BD lights straight to your battery (check my above post)
    Mater likes this.
  21. Mar 24, 2022 at 1:56 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    A picture of how you hardwired them in would be helpful.
    Are you turning on the headlights as well? Just checking....
  22. Mar 24, 2022 at 1:59 PM
    Hanzo
    The rep I spoke with told me on the lights white is power and black is ground. So I hooked up white to positive according to the markings on the connectors I removed (also the white wire).
    Here’s a few pics:
  23. Mar 24, 2022 at 2:00 PM
    Hanzo
    Checked with running, dims, and brights.
  24. Mar 24, 2022 at 2:09 PM
    alb1k
    Left Coast
    It's good
    Now I'm thinking check the wires that are supposed to be powering the lights. Do you have a test light or a multi meter?
  25. Mar 24, 2022 at 2:12 PM
    Hanzo
    I don’t, but I’m going to head to a buddies tomorrow with a meter. Just trying to see if the hive had any suggestions to prep for tomorrow.
  26. Mar 24, 2022 at 2:31 PM
    NoRcptn
    NorCal
    2017 Platinum
  27. Mar 24, 2022 at 2:33 PM
    Hanzo
    I saw that, he had the wires switched. Thanks for the help though.
  28. Mar 24, 2022 at 2:48 PM
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    I'm assuming your lights didn't come with this plug and play adapter?
  29. Mar 24, 2022 at 2:49 PM
    Hanzo
    They did not, I bought them second hand.
  30. Mar 24, 2022 at 3:03 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    All you have to do is plug in the light to the factory harness directly, you dont need a relay. Amazon has little harnesses that connect to your lights to the factory harness connector. I did this with my rigids.
