Bag spacers with 1” shackles?
Discussion in 'Suspension' started by BarcelonaSX, Sep 15, 2020.
  1. Sep 15, 2020 at 10:30 AM
    BarcelonaSX
    BarcelonaSX [OP] New Member
    2019 Barcelona red SR5 SX
    Bilstein 6112 front coilovers @2.5”. Bilstein 5100 rear shocks with toytec shackles @1”. 20x9. Xd grenade wheels with 295/60/20 ridge grapplers. Tinted windows. Gibson single side dual exhaust.
    Hey guys. Wondering if anyone has run the firestone bags with the toytecs out back set at 1”? Did you need the spacers? From what I read. If you’re under 1.5” lift you’re good without them. I’m just looking for any first hand experience. I contacted firestone. They couldn’t give me a solid answer. Thanks guys.
  2. Sep 15, 2020 at 11:12 AM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    I have Firestone airbags with 1-1/2" shackles. I measured and was right at the edge of Firestone's specs for ride height(which I didn't like). I made my own spacers out of 3/4" aluminum plate stock. Your probably fine at 1" but I would measure and check the install manual as it gives a range for ride height specs. The pacer they sell would certainly be to much in your case.
    BarcelonaSX [OP] likes this.
  3. Sep 15, 2020 at 12:16 PM
    BarcelonaSX
    Thank you. I’m looking to keep the height I have now. We’re you able to keep the height you had or did the bags at min PSI raise the rear up a little ??
  4. Sep 15, 2020 at 1:01 PM
    TrooperDC4x4
    Nor Cal
    The airbags did raise the height a little at 10 psi, I keep mine about 6 psi and check them once a month. Shouldn't be to noticeable.
  5. Sep 15, 2020 at 1:24 PM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Instead of spacers, couldn't you just put daystar cradles in? Seems like that would give you the same effect. And then the bags don't anchor on the bottom, and more or less just float in the cradle.
  6. Sep 15, 2020 at 1:28 PM
    TrooperDC4x4
    Nor Cal
