Baffled...anyone understand this?
Discussion in 'General Tundra Discussion' started by Hymelr, Aug 7, 2022.
  1. Aug 7, 2022 at 12:37 PM
    Hymelr
    Hymelr [OP] New Member
    Hey guys. First post. Hope I do this right.
    I have a 2013 Tundra V6 with 87K. Recently I had a crank no start. Fuses and relays were all good. Thought it was fuel pump. Changed the pump but the issue remained. I was getting power to the Fuel pump control module but no power from the module to the pump. I can direct power the pump and it works, so I changed the control module. The truck fired right up and ran for 9 days. Then the crank no start came back. This time I took it to a local mechanic shop that I have gone to for years. They determined the Fuel pump control module failed and replaced it. 9 days later the truck stalled on the road and is back to crank no start.
    I am not sure what to do now. I really don’t like throwing money at it so I would like to figure out if the computer is locking out the module or if something on the truck is frying these modules. Both new modules were genuine Toyota parts. Both lasted for 9 days, but nowhere near the same mileage.
    Any guidance is appreciated
    Thanks
  2. Aug 7, 2022 at 1:52 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    maybe check the wiring from the control module to the pump....intermittent short drawing too many amps from module and burning it out?
    texasrho83 likes this.
  3. Aug 7, 2022 at 2:00 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    Is it flex fuel?
  4. Aug 7, 2022 at 2:04 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've read about this happening before and they fixed it by replacing their ECU.
  5. Aug 7, 2022 at 2:16 PM
    Hymelr
    it is not flex fuel. I am waiting on new leads for my multi meter to arrive, then I plan on diving in. I tried to plug in the 2nd FPCM in and see if the computer would allow it to run but that did not help. I disconnected the battery in the hope that the ECM would "reset" and maybe that would clear the block. No luck either situation.
