Bad steering rack bushings
Discussion in '2.5 Gen Tundras (2014-2021)' started by trayday, Oct 10, 2016.
  1. Oct 10, 2016 at 5:34 PM
    trayday
    trayday [OP] New Member
    Oregon
    2015 limited CM 5.7
    During an alignment, the shop found that my truck has a worn steering rack bushing. Hopefully I can have it covered under warranty but am unsure if the 7" BDS lift or the 35" tires will void the warranty. Has anyone experienced this? What is the cost of the repair? I had the lift installed at a shop and will find the receipt before my appointment.
  2. Oct 10, 2016 at 5:35 PM
  3. Oct 10, 2016 at 9:16 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    He bushing is different than what I had. I had essentially a seal blow out. Cost me near $2k.
    The bushings won't be more than $50 each. Labor shouldn't be bad either, just depends on what needs to be removed to get them replaced.
  4. Oct 11, 2016 at 9:48 AM
    trayday
    Oregon
    2015 limited CM 5.7
    The shop said they'd have to remove the center piece of the lift and that they didn't have the right equipment to complete the task. They replaced the same bushings on my friends Tacoma for a little over 200$. For the Tundra they recommended to have the dealership to replace the bushings. Do you think the lift and wheels will void the warranty on this part?
    040Tundra likes this.
  5. Nov 9, 2016 at 3:29 PM
    trayday
    Oregon
    2015 limited CM 5.7
    After my appointment at the Toyota, they denied a warranty claim stating that the tires and lift were the cause of the bad bushings and the repair bill would be $2700+ to replace the steering rack. Said to pull the engine to get to the rack and that they don't replace only the bushings. I bought Energy Suspension steering rack bushings for the 2007-13 Tundra instead of replacing the rack and went to an independent shop. You can see where the shop had to cut holes out of the crossmember to drop the bolts to fit a chisel up to get the sleeves out. He then just welded the new piped metal. Something to consider about your Tundra. I should've replaced the stock bushings when I had the lift installed.bushings.jpg .
    equin and ColoradoTJ like this.
  6. Dec 8, 2016 at 5:22 AM
    David P
    David P New Member
    David
    Alabama
    2016 Toyota Tundra 4x4 CM Platinum
    BDS 7" lift with Fox coil overs and 2.5s in the rear, CB shackles w/ poly bushings, CB steering kit, CB poly rack bushings, Dakar rear leaf pack w/ CB poly bushings, Bushwacker paint to match fender flares,, Fab Fours premium bumpers font + rear, Fab Fours modular roof rack with lights all around, ARE Z series shell, BDS Traction control bars, Fuel Nutz 2 piece 22x10 wheels, Toyo MT 37X13.5, Spod overhead lighting control unit, Kenwood/JL Audio, Dynamat sound deadening throughout the cab, Morimoto 40" LED light bar hood bulge, Viper remote start alarm, Bully Dog tuner, S+B CAI, Retro'd HID Headlights, Morimoto 2-Stroke LED Fogs, Undercover tool boxes.
    I have a '16 with that same lift, but bigger wheels and tires (20x12s w/ 38x15.50s). What issues were you having? I have Coaches's poly rack bushings, I just haven't had them installed yet bc the shop that built my truck quoted me $1200 originally to swap the bushings then dropped it to $600. Coach says it can be done as you mentioned in a couple of hours or less.
    Flyin808 likes this.
  7. Dec 8, 2016 at 8:03 AM
    trayday
    Oregon
    2015 limited CM 5.7
    After alignments, as soon as I hit a big hole, the alignment would be thrown off again and when putting the truck in reverse while turning, the truck would make a loud clank every time. It started happening after riding my truck at the dunes and hitting woops hard, now I have rubbing while turning in reverse but it will be fixed.
    To replace the bushings, the notched holes is the only way I can see it completed with out removing the engine or dropping the front suspension. The shop thought he could replace the bushings by removing all tie rods and replacing through the holes for the tie rods but wasn't able. I bought the bushings and the shop charged $450 @ $75/hour to replace and weld.
  8. Dec 8, 2016 at 8:14 PM
    Flyin808
    Flyin808 New Member
    Nick
    2000 tundra trd
    4inch lift ,33 inch tires the
    Had a question on your tire and wheel set up looking to put on 20s with 37" tires but I'm clueless on what kind of offset or back space to get. Do you have any pictures
  9. May 14, 2017 at 11:20 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I like the notch idea. I'm going to have to do this soon.
  10. May 17, 2017 at 6:34 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    I have no lift, but I may have a similar issue. My truck will not hold alignment, and I get a loud metal-on-metal popping/clanking sound after I straighten out from a turn. Advice for me on how to figure out if its the steering rack bushings?
  11. May 17, 2017 at 7:30 AM
    n2deep
    n2deep Pavement Princess
    You may have bent the cam tabs if it won't hold alignment.
  12. May 17, 2017 at 8:59 AM
    trayday
    Oregon
    2015 limited CM 5.7
    with someone behind the wheel and a person on the ground while looking at the steering rack. Turn the steering wheel both ways, if you can see play in the rack where the bolts are, the bushings are bad.
  13. May 17, 2017 at 12:00 PM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    probably need to do that on a flat surface or on a lift correct?
  14. May 17, 2017 at 5:42 PM
    trayday
    Oregon
    2015 limited CM 5.7
    Id think as long as the wheel height is the same, it'd be alright.
  15. May 17, 2017 at 5:50 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    So what is it about the bds lift and bigger tires that blows the steering rack if someone doesn't mind me asking? Just the added stress?
    zcarpenter92 likes this.
  16. May 17, 2017 at 6:52 PM
    cd121082
    cd121082 New Member
    chris
    Washington State
    none yet
    What side do you get it from? I get the same sound but my alignment seems fine and I have no lift. My noise is coming from right tire.
  17. May 18, 2017 at 7:53 AM
    trayday
    Oregon
    2015 limited CM 5.7
    Added stress from any lift and oversized tires. Ive read more seals than bushings going bad, the seals were corrected in 2013. I dont blame the lift or tires for my bushings going bad, just my driving style.
  18. May 18, 2017 at 10:06 AM
    n2deep
    It's not just BDS. I am on my 4th rack one blew on spacers and the other 2 on 5100's with 35's. No issues since I went to Long Travel and I drive harder. Dealer replaced PS pump and all lines but mine is a 2010
  19. May 18, 2017 at 10:37 AM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    What about long travel you think made a difference?
  20. May 18, 2017 at 11:57 AM
    n2deep
    The geometry is better and within spec is my guess. Plus its the new design PS rack. I have a brand new 5th rack sitting in my garage as a backup - but don't want to go there.
    I also told her I was gonna ditch her for a Raptor is she gave me any more problems.
    papasmurf likes this.
  21. May 18, 2017 at 2:07 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    nahhh the BDS kit has super skookum cam tabs .. thats not it
  22. May 18, 2017 at 2:14 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    OP not at all, the BDS kit specifically had an issue with its first gen spindles they tried to change it but didnt get much better, adding CB tie rods helps save the rack a bit, but honestly @n2deep is right there was issues with early racks, but if your truck is 2014 or newer you should have the new rack, you have to get a specific rack model. Also the shop did a cool move on the bracket with the pipe great idea, Ive swapped two racks on my truck personally and the dealer has done two. and you do not have to pull the engine thats just what the book says. I have the BDS kit so speaking from experience
    equin likes this.
  23. May 18, 2017 at 4:14 PM
    n2deep
    But I replied to Russell who has no lift and can't hold an alignment - Cause I don't know chit about BDS other than I don't have it on my truck.
    Get off the interwebs cause you have work to do. Ripping out that BDS kit.
    papasmurf[QUOTED] likes this.
  24. Oct 3, 2018 at 8:06 PM
    Spvrtan
    Kris
    San Diego, CA
    Dumb question.. but I don't need to get an alignment after swapping the bushings, right?
  25. Oct 3, 2018 at 9:24 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I would to be sure...
    If you disconnected tie rods or disassembled or loosened Any lower control arm bolts
    absolutely
    dcsleeper408 likes this.
  26. Oct 3, 2018 at 10:30 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    I didn’t need one
  27. Oct 3, 2018 at 11:39 PM
    Spvrtan
    Kris
    San Diego, CA
    Yea, i get it to be safe. At the moment, I'm just not keen on spending another ~$100 on alignment because I just got the truck aligned less than a week ago after I put new OEM LCAs and spindles in.
  28. Oct 4, 2018 at 9:38 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    where do you get your alignment? some places if no adjustments are needed they will just throw it up on the rack and check it for free.
    you could at least call them and ask.
  29. Oct 4, 2018 at 10:13 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Not sure if you have a Firestone near you and if it can handle your tire size, but I got the $200 lifetime alignment at the Firestone near me and have already used them twice. My tire size is smaller than yours, though, at only 285/75/17. I know some shops claim their "drive-up" shop lifts can only handle up to a certain tire size (the one in DeSoto, TX was like that). Thought I'd throw that out there as a possible option.
    By the way, your Tundra is one of my all-time favorites.
  30. Oct 11, 2018 at 6:47 PM
    Spvrtan
    Kris
    San Diego, CA
    Finally finished the bushings. I was able to keep the upper shaft of the steering column from rotating to avoid breaking it. However, as I moved the rack itself around to get to the bushings, the lower shaft of the steering column rotated a bit. I rotated it back by hand to match my matchmarks up with the upper shaft. Is that okay or did I fuck something up?
